Question about Panasonic SC-HC30 Audio Shelf System
REMOTE NOT WORKING
REMOTE 1
    Master:
  • 444 Answers
Put new batterys in it.
Posted on Oct 27, 2012
The number 2 remote control do not work the remote
ramoshummer,
I would need more information to provide you a specific resolution, but below I have included basic steps to programming your remote to both your TV and your DISH Network receiver.
Link for codes if needed: http://www.dishnetwork.com/SupportSection/remote-setup
Addressing Remote to TV:
1.) Press and hold the clear TV button until all mode lights light up.
2.) Release and TV light will be blinking.
3.) Enter code and press #. The TV button should flash 3 times.
4.) Try functions (Volume, Power, etc..) and see if working.
5.) If no function, repeat steps 1-4 with another code.
Addressing Remote to Receiver:
1.) Go to System Info screen.
2.) Hold down the SAT button until all mode lights light up.
3.) Enter a number between 1 and 15 using the numeric keypad on the remote.
4.) Press the pound (#) button.
5.) Once the SAT button blinks three times, press record.
6.) Test remote and see if works.
If those don't solve your problem or you're experiencing a different issue let me know here or at thomas.faust@dishnetwork.com and I will check it out!
Tommy Faust
DISH Network
Sep 08, 2011 | DISH Network IR Remote Control
#1 remote in IR Mode, #2 remote in UHF mode, dual HD receiver model 722; #2 remote works perfectly, #1 remote works for a while then stops working. Have to hold the remote within an inch of the IR on the...
bp22911,
It sounds like it may be an interference issue with the IR. Some LCD TV's can cause interference with an IR signal which will cause problems with the remote. Something you can try to fix is disabling the Auto Back-Lighting feature on the TV itself and see if that helps. If not, the easiest way to fix would be to make the TV1 remote UHF.
This would require a 21.0 remote as a 20.0 is IR only. Look on the back of the remote at the top to see what model you have.
With a 21.0 go to System Information. On the back of the remote inside the battery cover is a switch that says IR And UHF and make sure the green 1 is showing. Flip it to UHF and press Record 3 times. The Primary Address should now have UHF in it. Try the remote and see if it works.
If it doesn't or you continue to have problems you can post here or email me at thomas.faust@dishnetwork.com
Tommy Faust
DISH Network
Apr 13, 2011 | DISH Network IR Remote Control
Program sony remote to operate dish vip722
The Sony RM-YD029 Remote control will work with the Dish Network VIP722 DVR HD Satellite Receiver, but the Dish Network VIP722's Primary remote address must be set to 1.
The procedure below will allow Sony RM-YD029 remote control to operate Dish VIP722.
Using the Dish Network Remote Control -
1. Press menu 2 times to get to system info page
2. In the system info page the primary remote address is in a white box (bubble) followed by a Green TV (1)symbol that says IR and indicates you the channel your remote control one is configured. The Sony RM-YD029 will work when this primary remote address number (in the white box) is set to 1.
If the Primary Remote Address of your VIP722 Remote control 1 is not set to channel 1, here is how to change it:
1. While displaying the system info page, press and hold the SAT button on your dish network remote until all other modes are flashing, about 3 seconds.
2. then press the '1' button on the numeric pad of your dish remote
3. then press the '#' button on the numeric pad of the dish remote
4. then press the 'record' button (red dot button - stores setting)
5. At this point you should see a number 1 in front of the primary remote address on the dish system info page
Ensure you enter the corresponding IR code into your Sony remote control per the instructions in the manual or Sony's web site. My 722 works with Sony IR code - 01775.
Sep 08, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
I have 2 fans 1 stopped working 1 remote
Look at the remote code on the remote which is broken, then copy the code on the fixed remote, then you can control anoher fan.
Jul 12, 2009 | Universal Remote Control Hampton Bay...
Cannot control Vip222 with sling classic
I have read elsewhere that Slingboxes required the Dish Network receivers to be set to Primary Remote Address 1.
To try a fix:
2. In the system info page the Primary Remote Address is in a white box (bubble) followed by a Green TV (1)symbol that says IR and indicates the channel to which remote control 1 is configured.
If the Primary Remote Address of your Dish VIP722 Remote control 1 is not set to channel 1, here is how to change it:
Ensure you enter the corresponding IR code into your slingbox remote control per the instructions in the Slingbox documentation.
Feb 05, 2009 | Sling Media Slingbox AV Remote Control
Remote malfunction - panasonic dvd stereo system
The remote control and main unit are factory-set to “REMOTE 1”
mode.
If your remote control affects other equipment during operation, you
can switch to operate in “REMOTE 2” mode.
To switch to “REMOTE 2” mode
1 While pressing and holding [AUX] on the main unit
Press and hold [2] until “REMOTE 2” appears on the
main unit display.
2 Press and hold [ENTER] and [2] for at least 2
seconds.
The main unit and remote control are now set to operate in
“REMOTE 2” mode.
To return to “REMOTE 1” mode
Do steps 1 and 2 above but use [1] instead of [2] for both steps.
(“REMOTE 1” appears on the main unit during step 1.)
The remote control cannot work with the main unit if their
modes are different.
“REMOTE 1” or “REMOTE 2” appears on the main unit display when
you operate the remote control.
If “REMOTE 1” appears (The main unit is in “REMOTE 1” mode.)
Press and hold [ENTER] and [1] on the remote control for at least
2 seconds.
If “REMOTE 2” appears (The main unit is in “REMOTE 2” mode.)
Press and hold [ENTER] and [2] on the remote control for at least
2 seconds.
Feb 21, 2008 | Audio Players & Recorders
Directv remote code for polaroid tv
Slide top button on remote to tv. Press and hold mute and select button until the green light on the remote blinks twice. Then press 991. Then press 1. Then press the tv power button once. If the tv doesn't respond hit the channel up button on the remote. If that works press select to store the code and slide the switch back to the left. If it doesn't work keep hitting channel up until it does. It can take up to 30 minutes but it works.
Jan 16, 2008 | Directv RC23 Remote Control
Remote not connecting
If you still have the original remote for the DMR-E80H, you can switch it back to operate with "1 CHK REMOTE" codes by holding down the "Enter" button on the remote and then press the "1" key.
If you don't still have the original remote, you can try the same steps on your universal remote (assuming it also has an "enter" key that worked with your recorder) and it could work.
Oct 02, 2007 | Panasonic DMR-E80H DVD Recorder
Panasonic SC-HC30 Audio Shelf System Logo
35 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Kovalik III
Michael Kovalik III
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
