Question about Craftsman Garden
Want to download manual for Craftsman Model 315.797600 hedge trimmer
This is a 14 inch gas powered model. Model number could also be 315797600
5 Suggested Answers
sparksflyin
  • 47 Answers
SOURCE: fuel line replacement
pull the lines off do only one at a time one should stick in the tank 1/4 inch which is your return the second one is your pick up which has a filter in the tank attached to it take a piece of stiff wire or a clothes hanger and bend a tight hook on the end just big enough for the fuel line to fit in it fish the wire in the tank and try to hook the fuel line then pull it out of the tank to take the filter off it might take a few tries but you will get it after that pull the line out from the top not the filter side take the new line and feed it through if you cut a 45 degree angle at the end of the line it makes it easier to feed once you get it in all the way use your piece of wire to hook it through the filler and pull it out then attach your fuel filter then shove it back in the tank like i said it may take you a few times but you will get hope this helps
Posted on Feb 08, 2009
SOURCE: I'm having problems figuring out how to change or
remove screws on both sides of plastic housings, remove spark plug, pull off plactic cap on the bottom side of the clutch plate. stick a wooden stick in that hole to keep the crank shaft from turning when you put an adjustabloe wrench on the clutch, unscrew clutch to get other half of housing off to get to the pull rope.
Posted on Aug 13, 2010
SOURCE: craftsman hedge trimmer fuel line replacementa craftsman
My Sovereign SHT 26 hedge trimmer has a damaged fuel pipe which needs replacing; please advise
Posted on Jul 16, 2011
dan5268
  • 542 Answers
SOURCE: My craftsman push mower won't start, I changed the spark plug, I need to download the owners manual for help. The model @ is 917.373981
Here is the manual for your Craftsman
Posted on Apr 11, 2012
Craftsman 22 in. electric Bushwacker hedge trimmer handle is broken where can I get part number?
Call your local sears store for their national parts department 1/800 toll free phone number.
Then write down the MODEL number [and a serial number if available]. Then call the parts department, give them the model number and they should be able to give you the part number.
Just to be as fully prepared as possible, have the actual trimmer with you during the calol so that you may be able to answer ID questions the parts tech may ask.
Apr 23, 2014 | Craftsman 22 In. Electric Hedge Trimmer
I have a 14 in. electric chain saw I bought last year and need to download a manual
A hedge trimmer is a type of agricultural or garden tool. And as the name suggests, it is used to trim hedges. There are mainly two types of hedge trimmers - manual and electrical. Amongst these there are some below mentioned variations.
Stand Alone: A stand alone hedge trimmer could be either power driven or manual. The power driven stand alone hedge trimmer uses gasoline or electricity to operate. However, the manual or hedge trimmer driven by human force is best when you consider environmental factors. They are cheaper and easy to operate. Generally gas powered hedge trimmers or electrically powered hedge trimmers are equipped with safety devices. The mechanism is such that they operate only when the operator has both his hands on the handles.
Tractor Mounted: This type of a hedge trimmer is more suitable for pruning of plants and crops. Tractor mounted hedge trimmers either have a movable arm or they do not have a movable arm. The ones without movable arms depend only on rotating blades on a couple of central pivots placed on the tractor's side. Now, these hedge trimmers are best for growing grapes, more specifically for making wine. Small tractors driving between the grape vines are mounted with these type of hedge trimmers, without a movable arm.
Well, this was about hedge trimmers in general. Now lets get down to business. Here's a low down on a few best hedge trimmers. The following is an overview of electrical hedge trimmers comparison.
Hedge Trimmer Reviews
Stihl Hedge Trimmer HS81T: Well, this one is surely up for grabs. Stihl HS81T is a great option for keeping your hedges in a perfect shape. Stihl HS81T is lightweight with balanced design and low vibration levels. It has 24 inch or 30 inch double sided blade length. It's also equipped with rear swivel handle for enhanced comfort at different speeds. The engine power is 0.7 kW and this hedge trimmer weighs between 5.2 kg and 5.4 kg, depending on the blade size. It is good especially for shaping and sculpting your hedge. It does not start on the first pull sometimes, still Stihl is a good option for hedge trimming.
Black & Decker NHT518: Now you would perhaps love this, if you do not want the whole baggage of fuel and electric wires and so on. It is cordless and runs on a battery and 22 inch blades that give a smooth and level cut. It does a neat job of branches less than 1/2 inch thick and you get optional extra battery packs. However, it gets a thumbs down from users with regards to poor battery life. On the other hand the users like the cordless design. Again, they say that it is not as powerful as corded trimmers. Nevertheless, it is lightweight and makes minimum noise. So you can go for it.
Echo HC-150 Petrol Commercial Grade Hedge Trimmer: Well, hopefully most of the users would echo my statement that, Echo is a very efficient hedge trimmer. This is a high performing, commercial grade hedge trimmer powered by petrol. It is a smooth and **** free hedge trimmer and is great for pruning and trimming. Durability is apparently the forte of this Echo hedge trimmer. Superb double reciprocating blades cut on their return and forward strokes, which give a smooth, uniform finish to your hedges. Not a bad choice either!
Makita UH6350 Electric Hedge Trimmer: This is a well designed tool with a great cutting action, according to a magazine on mechanical products. It is light weight and can deal very well with branches upto ½ inch of diameter. Although one of the disadvantage is that you have to bear with a cord and has a single blade operation. A fairly good option if you are thinking of buying a hedge trimmer.
Well, there you go, this was a small list of best hedge trimmers. I hope the hedge trimmers comparison was useful for you.
Take your pick according to your requirements and any hedge trimmer is good so far as it helps you keep your plants in good shape! What say!
for mannual download go to
http://www.stihl.de/safety_manuals/en/heckenschere_englisch.pdf
Jun 15, 2011 | Homelite Garden
Manaul for Craftsman electric trimmer 358.783522. I went on the Sears Parts website and could not find the manual. Do you have any other suggestions on where to locate it? The Craftsman webiste was of...
I see the manual listed after part number 25 in this Sears Parts Direct.com website. It is inexpensive and if you can view a complete parts breakdown of the unit here, maybe you won't even need to order a manual. Usually they are a free download. Here is your model:
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Grass-trimmer-weed-wacker-Parts/Model-358783522/0247/1503820/10059474/00001?blt=06&prst=0&shdMod=358783522
Apr 13, 2011 | Craftsman Garden
I am looking for a parts schematic for a sears hedge trimmer modle 636.796670 20.3cc engine also has anyone know or a repair for plastic gas tank
An illustrated parts list is readily available at www.searspartsdirect.com . Just input your model number and select model search.
The gas tank is located in the "crankcase" section.
As for gas tank repair, I have tried many times to repair these tanks. I have not been successful, even with the epoxies that are specifically made for it.
Good luck.
Oct 20, 2010 | Craftsman 22 in Hedge Trimmer
I'm having problems figuring out how to change or repair the string pull on a craftsman 22 inch gas hedge trimmer. It looks to me like you have to remove the clutch. How do you do that?
Jun 06, 2010 | Craftsman 22" Gas Hedge Trimmer
How to sharpen craftsman 14 inch hedge trimmer?
Unless you have a surface grinder they are difficult to do without causing more harm than good, take the trimmer to a pro with the right equipment.
Jun 02, 2010 | Garden
Craftsman model 358.796354 quits running after 5min. (coil poss.)
it could be getting the wrong fuel mixture or the engine is getting hot
Apr 19, 2009 | Craftsman 22" Gas Hedge Trimmer
Craftsman Hedge Trimmer model 358.796353 that won't operate
The problem you are experiencing is the coil. I had the same problem and confronted a freind that works on small engines. I asked him if the coil could be the problem and he gave me one to try out of another trimmer he had for parts. It is running well. The problem I now have is the blade tang that moves it back and forth broke. Now I'm trying to locate one of them.
Mar 28, 2009 | Craftsman 22" Gas Hedge Trimmer
Garden Logo
56 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
