Question about Iolo Technologies System Mechanic Professional: Windows
IOLO boot time defrag is not working
I have System Mechanic Pro (11.x) loaded on my Vista pc which has the latest service pack installed. In the "Individual Tools" section I select boot time defrag and choose to defrag the registry hive, system page file and MFT, but those check boxes are cleared after I click exit and the boot time defragger does not appear to run at boot. The boot time defrag does not work when the registry compacter and disk optimizer are set to defrag locked files on next reboot, either. I've also tried "hand jamming" pagefile.sys into the "Custom List" but the system won't let me because it's a system file.
ziraffa
  • 827 Answers
SOURCE: System Mechanic causes Registry problems
I use nCleaner and have had absolutely no problems for over a year now. I find System Mechanic has too large a 'footprint' and, like you said, is pretty incomprehensible to use out of the box.
The only thing that took me unaware with nCleaner was that it cleaned out My Received Files by default, so all the photos I had been mailed through Messenger were deleted, so make sure you copy them into another folder first :)
I have never had any software problems after using it though, and I install and uninstall programs pretty regularly!
So it comes highly recommended. It's a bit like CCleaner (if you have heard of that) but with more functions like Registry Clean.
I would reinstall XP first though as SM seems to have messed up, and you want a clean start. Also remember to reinstall all the XP drivers for your motherboard too.
Hope this helps
Chris (ziraffa)
Posted on Dec 26, 2008
edwin270
  • 308 Answers
SOURCE: Iolo system Mechanic 8 causes registry problems
yes. tune up utilities 2009.
download the trial version from
http://www.tune-up.com/products/tuneup-utilities/
then enter the information below to make it full version
Organisation: vistasoft
Serial: AQKA2P-HY7FQF-8M0930-DW4H4V-1EJPRC-16CHPN
let me know the outcome.
enjoy
Posted on Dec 27, 2008
BNUTZBCRAZY
  • 130 Answers
SOURCE: i installed system machanic from a friends disk
this one may work 1057-1009-0504-8782-7911-9677
Posted on Jan 14, 2010
  • 2340 Answers
SOURCE: I have uninstalled and reinstalled many times per
These problem usually occur when you are using a trial versions that have expired or a "half-cracked" version of a software. In order to reinstall the program you have to do some Registry editing. If you are a "novice" don't try to edit the registry, any errors you may make might render your system unbootable. (Do at your own risk)
Alternatively you can use a commercial uninstaller like 'final installer' or 'perfect uninstaller', etc...an many more in the market. Reinstall the program and use the uninstallers to remove the program and its remnats from the registry.
Posted on Jun 13, 2010
drifterK
  • 4924 Answers
SOURCE: Hi I have a new computer
yeah ..If you need to use something from iolo ..you should get into the McAfee firewall ..and add it as a exception ...other wise it might keep blocking it ...This is an issue cause this antivirus software it sees this particular utility ..as a spam or ..a possible insecurity issue..
If you do not have the license for the anti-virus..and you do not want to keep it ...a good alternative it is the free AVG anti-virus ..They released a new edition this year..and it is pretty good...and it will work with the utility you mentioned..
This ..just in case you do not have bought a license for the McAfee .. cause in this case it best to keep i t..and make the adjustments in the firewall.. or exceptions ..in blockage
Posted on Jan 12, 2011
How do I get iolo system service?
The iolo provides free and licensed anti-virus called System Mechanic And System Mechanic professional u can log into smpro.iolo.com for System Mechanic Pro and sm.iolo.com for system mechanic ... and either go for trial version for 30 days or can purchase it.
Sep 26, 2014 | IOLO System Mechanic Professional Full...
Tip
"the component IoloSystemService" Error on Iolo System Mechanic Pro
The "the component IoloSystemService" Error message shows up due improper installation of the System Mechanic Pro. Some of the Iolo dependencies failed to get activated and that is the problem.
Now the only solution to fix it is to follow a thorough uninstallation of the System Mechanic Pro.
For WinXP, you can uninstall it from the "Add or Remove Programs".
Next, once its unistalled do not RESTART the PC.
Now, go to the Registry (press "windows" + R to open the run command and type "regedit").
OR
Click the Windows start button and select RUN. Type REGEDIT on the openfield.
On the left-hand side, expand HKEY_CURRENT_USER by clicking the + symbol next to the entry.
Expand Software.
Expand the iolo folder.
Navigate to the System Mechanic Professional folder.
Right-click on the System Mechanic Professional folder and select Delete.
Click Yes to confirm the deletion.
On the left-hand side, expand HKEY_LOCAL_MACHINE by clicking the + symbol next to the entry.
Expand Software.
Close the Registry Editor.
Click Start>My Computer and then navigate to your Local Disk (usually the C: drive) then Program Files\iolo\System Mechanic Professional.
Click Yes to confirm.
on Jun 16, 2010 | Computers & Internet
How to install SystemMechanicPro
First thing first I'd check if my machine meets the requirements. [To run SM Pro your computer must meet the following requirements: run Windows 7, Vista, or XP/CD or DVD drive (for CD-based installations)/ 120 MB free hard drive space/at least 256 MB RAM/Internet Explorer 6 (Service Pack 2) or later/Internet connection (required for license activation)]
If all are OK than you can move on and download and install the software.
Here are the instructions and the developer provided:
http://www.iolo.com/customercare/kbarticle.aspx?id=KBA-02212&utm_source=rss&utm_campaign=ten&utm_content=326&max=29
I hope it will work for you!
[please RATE if my answer was helpful for you!!! THANK YOU!]
Mar 07, 2011 | Iolo Technologies System Mechanic: Windows
How do I fix problems created by iolo System Mechanic? I had no problems until after I installed iolo. I have iolo System Mechanic installed on 4 computers. After installing it problems started showing...
Normally with these programs you can set back time within the program. If this option is not provided go back in time with windows.
Start> all programms > desk accessories > systemset > System repair
Jan 13, 2011 | Iolo Technologies System Mechanic: Windows
My System Mechanic Professional not is too good: "the component"iolosystenservice" is required for System Mechanic Professional to operate properly and could not be started please let me know some...
OR
Expand Software.
Expand Software.
May 19, 2010 | Iolo Technologies System Mechanic: Windows
Program won't start. Get message "the component IoloSystemService" is required for system mechanic to operate properly and could not be found. System Mech 9.5.6 is installed and looks good. Running XP,...
OR
Expand Software.
Expand Software.
Reinstall the System Mechanic Pro
Mar 06, 2010 | Iolo Technologies System Mechanic: Windows
Having freeze up and very slow loading of
i suggest you 3 different ways to handle this.
1.if tou have a windows cd. just insert it and select windows repair and proceed to the instructions.
2.purchase any any good registry repair and computer optimisation software suchas IOLO SYSTEM MECHANIC ,REGISTRY MECHANIC, ADVANCED SYSTEM CARE etc.
3. to be cheap and effective, you may use trial version of IOLO SYSTEM MECHANIC.
these will optimise your pc automatically.
CHOOSE ANY METHOD YOU LIKE
Mar 02, 2010 | Dell OptiPlex GX280 PC Desktop
Error message"iolosystem"service is required to operate and could
I have the same issue where ioloSystemService is required... on a 64bit Vista Home Premium system. Iolo Tech (NO) Support's solution is for me to pay them another $200 dollars so their Certified Microsoft Systems Engineer can look at my system (no guarantee it will work after he looks at it either) or take it to Best Buy, Geeksquad, or Staples and pay them $300 dollars to look at it. It's a shame because I have been using their product since the first beta version. I guess they have just gotten too big for their own good because they sure do not care about the customer.
Jan 03, 2010 | Iolo Technologies System Mechanic: Windows
I have a simple question.
System Mechanic 8 is compatible with Windows 7, Vista, XP and 2000. I am sorry to inform you that it is not compatible with Windows 98.
If you go to the page below and look under purchase now, you will see a windows logo and a list of all versions of windows System Mechanic is compatible with.
http://www.iolo.com/system-mechanic/standard/
Jun 19, 2009 | RTO IOLO System Mechanic Pro 08 Full...
Iolo Technologies System Mechanic Professional: Windows Logo
993 people viewed this question
Top Iolo Technologies Computers & Internet Experts
Jax Planet
Jax Planet
Alun Cox
Are you an Iolo Technologies Computer and Internet Expert? Answer questions, earn points and help others
