Question about Ingersoll Rand 5 HP Stationary Compressor SS5L5
What oil (weight, etc) should be used to fill compressor motor of 5 hp compressor?
  • 7,482 Answers
Hi William Hunter
That is a very hard question to answer, because they make so many different kinds of oil for compressors.
You failed to mention your manufactures name of the compressor so
I will guide you to the following webpage and you will find your answer there.
Please rate me
Bud
http://compressorparts.com/index.php?route=product/category&path=46&utm_source=adwords&utm_campaign=Compressor+Oil+Generic+Sitelinks&utm_term=compressor+oil&utm_medium=cpc
Posted on Oct 28, 2012
HDC 2HP 5 Gal Pancake Air Compressor - replaced pressure switch - now takes long time to pump tire - motor runs long time - slow recovery - actually overheated and melted off the plastic part on muffler....
Barb:
Your compressor takes standard 30 weight compressor oil or 30 weight motor oil... you need to put in the correct amount. The slow recovery is due to a leak somewhere. after adding the proper amount of oil, run the compressor and use a soapy solution to check for leaks. Check especially the tube that runs from the compressor head to the tank, and also check the air connection at the pressure switch. When you find the leak, you can disconnect the connection and use Teflon tape on the male end connector.
Aug 15, 2013 | Air Tools & Compressors
My compressor throwinng oil from breather andair.
It is normal to feel air coming from the breather. It is there to relieve pressure in the crankcase. If it is also throwing oil then make sure it is not over filled and also make sure you are using NON-DETERGENT oil. That is very important as you should never use regular motor oil.We use 30 weight non-detergent for all the compressors that we service.
Jul 27, 2011 | Air Tools & Compressors
What type of oil do I use in model CPLDC 2541S
If you mean the CPLDC2541S (Porter Cable air compressor), you need to fill it with an air compressor oil. The recommended weight is SAE-30 (API GC/CD heavy duty motor oil). You can use a SAE-10 oil in harsh winter condiions. The manual is available from Manage My Life: http://www.managemylife.com/mmh/owner_manuals/20237/PORTER-CABLE-Air-compressor-L0309172 .
I hope this helps.
(note standard motor oils designed for cars are not appropriate for a compressor.)
Jun 21, 2011 | Porter Cable Garden
I have a 5 HP Coleman air compressor. I was using it to provide air to my plasma cutter which requires 60 psi to operate. Basically, air compressor's motor keeps running, but it's stopped creating air...
You did not list model number, however if you have oilless type check the cylinder/piston by manually turning crank until piston is at top and examine cylinder for wear or scratches. If worn replace cylinder kit for full pressure. If ok check reed valves /valve plate for wear or broken reeds. If oil bath type, problem is usually air leak or reed valves / valve plate. As a general rule, you can keep track of wear by noting how many minutes it takes to fill the tank to cut-out. As the compressor wears it will take increasingly longer to fill. When new, and depending on tank size/ hp, most compessors fill within 2 ~ 5 min. Good luck
Sep 24, 2010 | Coleman Air Tools & Compressors
Recommended oil for Emglo KU air pump and quantity used.Serial # FO325100201
30 weight non detergent oil .fill up to fill plug. Important do not use regular motor oil
Aug 20, 2010 | Air Tools & Compressors
Just got a1999 jeep wrangler sport with a 4.0l 6cyl and 124,000 miles,what is the best oil and oil filter to use. anthony
There are several different oils to use. I would run a high mileage oil if possible, the brand really doesn't make a difference, but on the oil fill cap it will recommend the proper weight such as 5-30 or 5-20 or 10-40, etc. Proper weight in a high mileage oil is best. Oil filters are about the same way. FRAM being probably the most popular and widely used.
Chip
Apr 11, 2010 | 1999 Jeep Wrangler
What grade oil doI use to change the oil?
Your comressor comes from the factory filled with Jenny Synthetic Blue Compressor Pump Oil. This is a 30 weight oil.
The picture below is Ingersoll Rands version of this oil.
I use it and have no complaints about it. It's also a lot easier to get.
That said any 30 weight oil will work. Although I would recommend synthetic because that is what the motor was broke in with.
Hope this helps.
Nov 17, 2009 | Jenny Products Inc AM780-HC2 1.5 Gallon...
What kind, weight,and how much oil is to be used?
YOU CAN USE 30 WT OIL AND YOU FILL IT UP TILL ITS IN MIDDEL OF THE BUBEL
Oct 23, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
What weight oil do I use. New compressor not used
30 weight non detergent. Sears has this oil on the shelf or you can get the same at any auto parts place.
Non detergent is the key.
Refer to your owners manual for further information
Thank you for your service.
Oct 12, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
I have a Sanborn 60 gallon vertical compressor ( Blackhawk 5 hp ). What weight oil goes in the crankcase?
there is actually air compressor oil available at most hardware stores be sure it is compressor and not air tool oil
Jul 23, 2009 | Makita MAC5200 Electric Powered Air...
Ingersoll Rand 5 HP Stationary Compressor SS5L5 Logo
125 people viewed this question
Top Ingersoll Rand Air Tools & Compressors Experts
elunsford
Eddie Tucker
Level 1 Expert
John Trevino
Are you an Ingersoll Rand Air Tool and Compressor Expert? Answer questions, earn points and help others
