I have a sharp lc-32af10n lcd monitor, I got a double problem in it. K symbol appeard in the upper left corner of the screen, and the volume metter change to just 3 parts? What should I do?
I didn't understand what is the problem to do so, and I also didn't find any software on the net to update the program of the screen. So I really need your help. Thank you in advance.
J have a sharp lcd 32af10n the ecrant was broken screen but I changed it but not Limited Time Offer smith as you press your power lamp red after green do nothing without sound or picture can I do? like this block has a code
Posted on Dec 07, 2012
SOURCE: Sharp LCD LC-46D64U
Try resetting the TV. Here's how to do it - Unplug the TV's power cable. Keep the Channel Down and Volume Up buttons on the TV pressed and plug the power cable back into the outlet. You will hear a click when you plug it back in if the reset is successful. Hopefully this should restore your video and audio.
Posted on Feb 06, 2008
SOURCE: Purchasing an internal circuit board part for a sharp LC 20S1E LCD TV
send me the model and serial number and i will be able to advise you
Lou Margo
Allied Electronics
loumargo@verizon.net
Posted on Dec 24, 2007
zjut
  • 106 Answers
SOURCE: sharp aquos lc - 42d43u lcd inside cracked
Normally warranty does not cover this kind of physical damage to your lcd screen. First check with your vendor to confirm. To replace the lcd panel is very expensive, may cost you as much as to buy a new one.
Posted on Jan 13, 2008
Fix-4U
  • 293 Answers
SOURCE: Picture Problem with Sharp LCD Model LC-42D43U
Hi...there,
It's seems your backlight inverter are busted... Need to replaced a new one.
Posted on Oct 15, 2008
  • 479 Answers
SOURCE: Loss Sync
According to SharpUSA the problem with the "Loss of Sync" error message is that (most probably) the cables (between the box and the display) are not connected properly (so remove and reconnect them carefully, on both units) or a cable is defective.
Also, after you reconnect the cables try turning on the unit, if no success then depress the "clear" button on the external box (under the door on the front and on the bottom left and try turning on the TV again).
It is, most likely, that the cables are not seated properly. Reseat the cables on both the display and the external box.
Hopefully, this will clear the problem
if still does not solves your problem just replace all the cables connected between .u can get the new cables at radioshack web site.just place an order they will provide you. thanks.
Posted on Dec 14, 2008
Sharp lc-32d4ou screen blacks out
I do have a work around that I have used on this model for the past3 years. if the sceen goes black. Turn off the tv. Grab the upper left and right hand corners of the tv with your hands. Flex the tv slightly back and forth. then turn it back on. my will usually run for hours after I do this. I do this 4 times a week. I works 100% if the time for me. Sharp lost a customer. good luck.
Aug 31, 2010 | Sharp Aquos LC-32D40U Television
My sharp aquos has low volume
my sharp aquos flat screen has a low volume, even when turned up to max. how can i increase the volume
May 24, 2010 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
I am getting a black square in the upper left corner. How do I get rid of it?
Press CC button on the remote control until you see CC/TT OFF.
Closed Captioning or TeleText is the cause of the problem.
Dec 28, 2009 | Sharp Aquos LC-20B4U-S 20 in. LCD EDTV
Monitor comes on for a few seconds then goes blank.
Your looking at profesional repair. It could be DC/DC convertor, Monitor unit or PC/IF unit. (last two are expensive)
Jan 22, 2009 | Sharp LC-M3700P 37 in. HDTV-Ready LCD...
Volume Control is horrible - Sharp LC-32SB24U
If your using a remote control, try to replace the battery. if your just pressing the little buttons at the front of your tv, the buttons that your pressing is the faulty one. you must replace all those buttons in order for your volume to work perfectly. if you do not know how to do these, just have your tv repair by a professional tv technician. by the way, the little green k that your referring maybe the volume indicator
Jan 19, 2009 | Sharp LC-32SB24U 32 in. LCD TV
Sharp Aquos LC-37D62U Audio Warning
Usually the settings can't be turned off and the audio settings are searching for whatever is being outputted from the program itself whether mono or stereo. It is nuisance I know.
Jun 28, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I get white dots upper left corner across the screen of set now I have a Sharp LC-37D40U LCD TV. Is it the pixels?
Hi Yabby,
If the dots are very narrow and jump about and you're receiving an analogue signal it could be teletext information. This is normal but is usually hidden off the top of the screen. You need to adjust the picture height to take them off the top.
Regards
Andy
Jun 26, 2008 | Sharp Televison & Video
Televison & Video Logo
129 people viewed this question
Top Televison & Video Experts
Electro Med Services...
