No volume Turned on radio after factory reset no volume
    Master:
  • 444 Answers
Don,t crank it up so loud.Just because the vollume might go up to 65. Does not mean to turn it up that far, Any good surround reciever will be putting out it,s maxs watts at 45. You are just asking for trouble turning it up past that. End for shure after a while of doing that you will fry the (Reciever) Live end learn.
Posted on Oct 27, 2012
I just bought a used ZTE N9130 cell phone when I charged / powered it up the screen is pattern locked. How do I factory reset this phone ?
To perform a hard reset, or factory reset, then there are a number of methods to try:
1) From the home screen, press Menu - Settings - Privacy - Factory data reset - Reset phone. It may ask for a password. Then select Erase everything
If the phone is totally unresponsive, even after a reboot, then try the following methods.
2) While the phone is turned off, press and hold the Volume Up and Volume Down buttons together. Then, while holding these, press and release the Power button (keep holding the volume buttons). The phone should turn on and a menu will appear. Press the Volume down button to navigate to the Recovery option. Press the Volume Up to select (if that doesn't work, use the Power button to select). A yellow triangle and an Android logo will appear. Press the Volume Down and Volume Up button together and a recovery menu should appear. Use the Volume buttons to move to the Wipe data/Factory reset option and then press Power to select. Again, use the Volume Down key to choose Yes and press the Power button again to select.
3) While the phone is turned off, press and hold the Volume Down button. Then, while holding, press and release the Power button. A menu should appear. Use the Volume down key to go to Clear Storage. Use the Power button to select the option. Then when asked to confirm, press Volume Up for Yes.
4) While the phone is off, press and hold down Volume Up + Home + Power buttons at the same time. Then release the buttons when you see the Logo. Use the Volume Down button to go down and the Home or Power key to select. Choose the Wipe data/Factory reset option. Then Select Yes to delete all user data. Then choose to reboot the phone.
5) A final method is to enter the code into your phone's dialer: *2767*3855# This method will not give you an option to reverse the process, so be careful! This method will only work if you can boot into your phone. - See more at: http://www.phonetipsandtricks.com/tips/zte-warp/how-to-hard-reset-factory-reset-31/#sthash.9JNbyTkc.dpuf
Sep 06, 2015 | CELLULARVILLA Wallet Case For ZTE Speed...
Tip
How to format a HTC desire
<span> <p>Warning : the following will erase everything on your phone, your settings, your data, etc!<br /> <p>The most convenient way to do a factory reset is via the phone settings.<br /> <ol> <li>From the Home screen, press MENU and then tap Settings.</li> <li>Scroll down the screen and then tap Privacy &gt; Factory data reset.</li> <li>On the Factory data reset screen, tap Reset phone, and then tap Erase everything.</li></ol> <p>Performing a factory reset using phone buttons<br /> <p>If you cannot turn on your phone or access the phone settings, you can still perform a factory reset by using the buttons on the phone.<br /> <ol> <li>With the phone turned off, press and hold the VOLUME DOWN button, and then briefly press the POWER button.</li> <li>Wait for the screen with the three Android images to appear, and then release the VOLUME DOWN button..</li> <li>Press VOLUME DOWN to select CLEAR STORAGE, and then press POWER.</li> <li>Press VOLUME UP to start the factory reset.</li></ol></span>
on Nov 24, 2010 | Cell Phones
Can I reset my htc pd53100 without turning the phone on?
Performing a factory reset while phone is turned off
1. Press and hold the VOLUME UP, VOLUME DOWN and POWER/LOCK SCREEN buttons.
2. When prompted, press VOLUME DOWN to perform the factory reset, or press any other button to cancel the reset.
3. When prompted, press VOLUME DOWN to turn on the phone.
If your phone hangs or freezes, remove the battery, wait for a few seconds, and then put it back in. After reinserting the battery, turn the phone back on.
Jan 01, 2013 | HTC Freestyle F5151 Pd53100 Unlocked...
How do i do a master reset?
Performing a factory reset via settings The most convenient way to do a factory reset is via the phone settings.
  1. On the Home screen's Settings tab, tap Menu > All Settings > System > Clear Storage.
  2. Enter 1234.
  3. Tap YES to perform the reset, or tap NO to cancel the reset.
Performing a factory reset using phone buttons If you cannot turn on your phone or access the phone settings, you can still perform a factory reset by using buttons on the phone.
  1. With your phone powered off, press and hold the VOLUME UP and VOLUME DOWN buttons.
  2. While holding the volume buttons, press the END/POWER button briefly and then release it.
  3. When you see a warning message on screen, release the VOLUME UP and VOLUME DOWN buttons.
  4. Press the VOLUME UP button to perform the reset, or press any other button to cancel the reset.
Ref: http://www.htc.com/www/howto.aspx?p_id=297&id=182
May 03, 2011 | HTC HD2 Smartphone
How to reset HTC Inpsire with a passcode lcok
Steps to Perform Hard Reset with Phone turned OFF
A Hard reset restores the original factory settings and will erase all downloaded content, including ringtones, contacts stored in the handset memory, etc. Back up all necessary data on the device memory before proceeding.
  1. With the phone turned off, press and hold the VOLUME DOWN button, and then briefly press the POWER button.
  2. Wait for the screen with the 3 Android images to appear, and then release the VOLUME DOWN button.
  3. Press VOLUME DOWN to select CLEAR STORAGE, and then press POWER.
  4. Press VOLUME UP to start the factory reset.
Apr 23, 2011 | HTC Inspire 4G Smartphone
Why does my htc wildfire randomly shuts off and on ?
Try to reset it and see if it fixes this problem but backup your data before doing this.This process will erase everything.
  1. Press HOME > MENU, then tap Settings.
  2. Scroll down the screen, and then tap Privacy > Factory data reset.
  3. On the Factory data reset screen, tap Reset phone, and then tap Erase everything.
  4. When asked to confirm, press VOLUME UP.
Mar 14, 2011 | HTC Desire Cell Phone
My HTC HD2 is stuck on the homescreen, It want let me get in the start menu to get in settings to do a factor hard reset
You can do factory hard reset for HTC HD2 even when it is turned off. But it will erase all contacts,downloaded contents and user informations. The phone settings will be reset to factory default.
These are the steps to hard reset HTC HD2.
  1. With the phone turned off, press and hold the VOLUME UP and VOLUME DOWN buttons, then press the END/POWER button shortly and release it.
  2. Release the VOLUME UP and VOLUME DOWN buttons.
  3. Press the VOLUME UP button to perform the hard reset, or press any other button to cancel the reset.
Mar 06, 2011 | T-Mobile Cell Phones
How to format HTC WILDFIRE A33333
Factory reset is not a step to be taken lightly. It will permanently delete all your data and customized settings, and will also remove any applications you've downloaded and installed. Be sure to back up any data and files you want to keep before you do a factory reset
Performing a factory reset via settings:
From the Home screen, press MENU, then tap Settings.
Performing a factory reset using phone buttons:
Press VOLUME DOWN to select CLEAR STORAGE, and then press POWER.Press VOLUME UP to start the factory reset.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Feb 25, 2011 | HTC Computers & Internet
My htc hd2 refuse to respond to my screen password, can you help me to do factory reset
  2. Enter 1234.
By the way, do remember to backup your data first before hard reset
Feb 12, 2011 | Cell Phones
Change language from german to english
If you do a hard reset it will go back to factory default settings.
With the device turned off, press and hold the VOLUME UP and VOLUME DOWN buttons, then briefly press the POWER button.Continue pressing the VOLUME UP and VOLUME DOWN buttons until you see this message on the screen:
Warning! Your device will be set back to factory default settings. Please ensure any additional installed programs and/or user data have been backed up before a hard reset is performed.
Release the VOLUME UP and VOLUME DOWN buttons, press the VOLUME UP button to perform the hard reset, or press any other button to cancel the reset.
Jun 11, 2010 | HTC Touch HD Smartphone
323 people viewed this question
 Grubhead
Grubhead
