Question about Air Intake & Fuel Delivery for Honda Pilot
I smell gas when the weather is cold
When the weather is cold I get a gas smell inside the car. Does not happen in warm weather. When I first start the car it is usually fine. Then I drive a little ways(0.5 or 1 mile) and stop at a stoplight and I get the gas smell. I open the hood and can smell the gas so it's not from the tank or a leak in the line. I had a mechanic look at the injector seals last winter and they said they were all good.
  • rob_peterson
    rob_peterson Nov 24, 2012
    Finally found the problem.
  • rob_peterson
    There is a square copper part that the fuel regulator fits into. There is a hose coming out the front with a factory crimped on connector. This connection was leaking a few drops of fuel in cold weather.
    Master:
  • 450 Answers
Winter (or rather cold weather) can cause fuel leaks, You should go over the fuel system and check all connections and clamps to be properly fitted and secured. Some vehicles are worse about this than others. I have an older Nissan, and there's a saying when it gets closer to Christmas- Tis the season for fuel leaks! Check your hoses.
Posted on Dec 10, 2014
Cool mornings it doesn't want to start ,i have to turn the key to start and let it off several times and it will eventually start after that it starts fine all day and starts fine on warm days
How to Start a Car in Freezing Cold Winter Weather
www.wikihow.com > ... > Cars > Car Maintenance and Repair
wikiHowFreezing cold weather can take a toll on car batteries. ... It's much more difficult to start a cold car with a mostly-empty tank, so do yourself a favor and gas up ...
Why is it so hard to start a car in the winter? - HowStuffWorks
auto.howstuffworks.com/car-driving-safety/.../start-car-in-winter.htm
To start a car in winter, your engine has to work extra hard. Learn the top 3 reasons your car is hard to start in cold winter weather.
Debunking 5 Cold-Weather Car Myths - Popular Mechanics
Nov 21, 2015 | Cars & Trucks
1998 oldsmobile aurora cold weather will not start battery good
spark plugs,fuel filter,battery can have V but no power.
Feb 21, 2013 | 1995 Oldsmobile Aurora
Why tracker transmission lock in cold weather?
You have valves inside the transmission and electronic controls inside the transmission. When cold, valves do not work because the fluid is too thick. Once warm the fluid thins out and allows tranny to shift OK. You can burn your tranny up by not letting it warm up.
Feb 18, 2013 | 2002 Chevrolet Tracker
1997 Villager gas smell when outside temperatures are hot and vehicle has been driven.
A common problem with Nissan products, which this van is a Nissan Quest with Mercury trim.
There are several small rubber fuel hoses around the intake. When the air temp is cold these hoses can leak and then stop leaking when the air temp warms up.
When the air temp is cold, look around the intake with the engine running and you should see one of the hoses wet with fuel.
Just tighten the clamp.
Dec 12, 2012 | 1997 Mercury Villager
Engine turns but won't start when temperature id around freezing or below.
Possible bad cold start valve or the sensor that tells the valve to activate when cold. Start by replacing the cold start valve first.
Sep 17, 2012 | 1990 Dodge Caravan
FUEL RELAY?
If your smelling fuel, whether just driven, or after sitting. your have a fuel leak somewhere!
Mar 23, 2012 | 1999 Ford Escort
I started my Malibu in really cold weather. I smelled gas and opened the hood. Gas was running out from somewhere but it was night and i ccouldn't see where thee gas waas running from.A week later I...
Gas would leak out of a cold, hard, rubber fuel line. When the car warms up, the rubber line swells and seals itself up until it gets cold and leaks`again. Find that leaky fuel line asap or you're risking an engine compartment fire every time your car is started, when it's cold out.
Mar 09, 2011 | 1999 Chevrolet Malibu
1995 bmw 525i vehicle having difficulty starting in cold weather vehicle cranks strong but sometimes wont turn over. Also vehicle hesitates and cuts off while driving intermittently. sometimes smells like...
Air intake not adjusting correctly or is there a manual cold weather lever on the air intake pipes on these?
lamda sensors on exhaust? you might get an answer from the ecu if you plug it into a diagnostic machine. I'd take it to a garage
Dec 22, 2009 | 1995 BMW 5 Series
I get a sulphur smell once in a while, not all the time,
Exhaust cat converter smell as they require heat to work properly, warm up as quickly as possible if still a problem have it tested
Mar 10, 2009 | 1993 Suzuki Swift
Gas fumes only in cold weather
its normal its because its so cold my 93 chevy does the same
Jan 17, 2009 | 1996 Volkswagen Golf
Air Intake & Fuel Delivery for Honda Pilot Logo
98 people viewed this question
Top Honda Vehicle Parts & Accessories Experts
rlev_7
Level 1 Expert
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Honda Vehicle Part and Accessory Expert? Answer questions, earn points and help others
