Question about Kenmore Oasis 27042 Top Load Washer
How can I bypass lock?
My lock is broken, which I didn't like in the first place. So I want to be able to bypass it if possible.
Pu ta new lid lock on but still want wash or lock
Posted on Jan 30, 2013
Legacy 1000w 2 channel amp worked awesmoe then just stopped working after a few songs. Didn't turn up too loud. Didn't have the settings too high. still getting power (amp light on, led lights...
Open your speaker box up most likely the jumper from the inside of the box to the subwoofer itsself is broken free, Usally when they have lights around the sub woofers there seperate leads, bet 10-1 you have loose wires inside the speaker box
Mar 25, 2013 | Legacy Audio ICON LA2770BK 1000W 2-Channel...
I didn't solve my problem, " unlock N8"?!!!!!!!!!!!!!
Your phone is under network lock or security lock?
If, your phone is locked to security lock, dial 1234 or 0000.
And, if your phone is lock to network use unlock code.
Get the unlock code from this site Simpleunlocking.com
Here, you need to specify country & network provider it is locked now.
Then, get the unlock code. & unlock it.
Dec 09, 2012 | Nokia N80 Cellular Phone
Motor spins but drill doesn't
Sounds like you have a broken transmission. Another remote possibility is the pinion gear on the end of the motor is stripped or broken. You didn't include which model you have but you are looking at approximately $40 to $60 for either the motor or the trans assembly.
Mar 08, 2012 | Dewalt Drills
Memory card locked
You didn't specify the make and model of your camera, so I'm going to assume it uses SD/SDHC cards.
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Feb 07, 2012 | Cameras
My security light is on and my radio gets locked sometimes while I'm driving. Does anyone one know why this happens?
yes, the anti theft system runs thru the radio. Either the radio is going bad and causing the antitheft to kick in, or the antitheft is bad and faulting the radio. I just went thru this in my girlfriends 01. Ended up installing after market radio and bypassing the security system. I bypassed thee antitheft security first, and the car worked just fine, but I didn't get any radio till I installed a new radio. Here Is a link to help with the antitheft http://vatspasslockpasskeysecurityhelp.yolasite.com/
Oct 11, 2011 | 2003 Chevrolet Impala
Replaced old brake pads with new ones and now my drvers side brake caliper is rubbing on the inside of the rim this is on 1998 Hyundai Excel
You didn't get it set in place correctly. Possibly a bolt came out also. Check this right away. I have seen these rub the rim and lock the tire up. No fun on the highway.
Aug 28, 2011 | 1994 Hyundai Excel
My car - Dodge Stratus, 2001, engine 2.4L DOHC started making a grinding noise... I took it to a mechanich and they said I had to change the timing belt and water pump... I did that and it cost me a lot......
1996 DODGE STRATUS 2.4L 2429cc 148cid L4 MFI (X) [EDZ] DOHC : Heat & Air Conditioning : A/C Compressor Bypass Pulley Wiki Price DORMAN Part # 34227 moreinfo2.png
us.gif ca.gif 34227-007.jpg $30.79
This was found at rockauto.com. this will take the place of the AC compressor and allow the use of the original serpentine belt.
Jul 20, 2011 | 1996 Dodge Stratus
I have a problem with toshiba e studio 181: i've changed a new toner cartridge but the indicator of toner is still flashing, and the machine didn't give any acces.
first check if the cartridge is original usually "have a serial & par code"
& Shake it will & clean carefully the green ship at the end off cartridge
check if the cartridge is already opened
turn the cartridge upside down " open the wight square tab & turn the Shield the Opposite Hand
[ check if broken ] while turning it .. you must see tone Flipping or moving at the square tab window
if not that's mean shield broken
try to fill its toner to an empty cartridge..
Jul 06, 2011 | Toshiba 1360 Black and White Copier
I am getting memory card error - card locked when I switch on my Canon SD 990. It was recently repaired by unauthorized dealer for switch on problem and then on I am facing this problem. I veirfied the...
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Jul 04, 2011 | Canon PowerShot SD990 IS / Digital IXUS...
How to unlock my restriction code? my phone is nokia 3220. my emei is 357059008185477
I can't give you the code because you didn't give the country and the network provider.
anyway here's DIY method
Here's the way :
* download this link : http://www.uploadmb.com/dw.php?id=1306822616
extract the file and place it on your desktop
* open the application
* choose your country and provider
* enter your 15 digit imei located at the back of your phone or just type in *#06#
* press calculate
just follow the code flashes on screen.preferably 1 & 7 is effective...
Best regards,
Jun 24, 2011 | Nokia 3220
Kenmore Oasis 27042 Top Load Washer Logo
489 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
