Honda EU6500iS Inverter Generator Logo
Posted on Oct 27, 2012
Battery type Honda eu6500is
What type of battery does my generator take"
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 02, 2012
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1016
Points
Yuasa YTZ14S is what mine takes
Error code E-05 on Honda eu6500is generator
GCU internal failure or inverterunit internal failure.
https://www.manualslib.com/manual/2167496/Honda-Eu65is.html?page=58#manual
1helpful
Hello I have a generator honda inverter eu6500is and after 30 min aprox without load it stopped and Oil and overload alarm stay on. I let cool down for 15 minutes and he start again and stopped in 30...
The two alarms simultaneous is questionable. My first thought is faulty control board but requires further troubleshooting. Check for loose cable connections and grounds.
As a test; check oil level. If oil level is safe, disconnect oil level sensor and see if problem goes away. If problem reoccurs, troubleshoot oil warning circuit.
What is the gap between the module and flywheel on a eu6500is Honda generator
I don't know.
The air gap isn't usually critical. It needs to be a small gap for best efficiency but must not be so close it will touch if expansion brings it closer at operating temperature.
The last air gap I adjusted was on a Briggs engine and that was 0.008", 8 thou which I believe is fairly typical for that type of application.
My honda generator eu6500is is flooding out.
Alfred,
Try checking the float 1st. Much like it is done in this video (different generator but same princible.):
What connector is needed for a remote start?
talk with an accredited electrician as there will have to be a special relay/ breaker in the fuse board of the house
the problem is that your genset cannot be running when utility power comes back on as it will destroy the genset
the electrician can wire the board so that when utility power is available the gen set can be started but not connected to the house
when the utiltiy power fails the relay switches over to the gen set and allows it to start and power the house
when utiltiy power is restored the relay disconnects the gen set and reconnects to the utiltiy power supply
This is not a job for anyone except a fully qualified electrician
What controlls the rpm on a eu6500is
The inverter signals the throttle motor, which is really just a small servo motor on the top of the carb. When the inverter senses more load, it increases the throttle to compensate.
Service manual required
I can't find a free download on the internet, most are Owner's manuals or are not for the exact model you want - I don't know how similar similar models are. You might try the following:
http://cdn.powerequipment.honda.com/pe/pdf/manuals/00X31Z376011.pdf (from Honda, EU7000is owner's)
Honda EU7000i Model Info Super Quiet 7000 Watt Inverter Generator Honda...
This is the shop manual for the EU6500is model ($44)
Honda EU6500is Generator Shop Manual
owner's for the EU6500is
http://www.freeproductmanual.com/honda-eu6500is-manual
Finally a link to the search results most of the were taken from
https://uk.search.yahoo.com/search;_ylt=A9mSs2tVBShVngQA_xZLBQx.;_ylc=X1MDMjExNDcxNzAwMwRfcgMyBGZyA2FsdGF2aXN0YQRncHJpZANyOTBfV1hQeVNvT0twcW5oS3NxWlFBBG5fcnNsdAMwBG5fc3VnZwM0BG9yaWdpbgN1ay5zZWFyY2gueWFob28uY29tBHBvcwMwBHBxc3RyAwRwcXN0cmwDBHFzdHJsAzMwBHF1ZXJ5A0hvbmRhIEVVNjUwMGlzQSBzZXJ2aWNlIG1hbnVhbAR0X3N0bXADMTQyODY4NjQ3NQ--?p=Honda+EU6500isA+service+manual&fr2=sb-top-uk.search&fr=altavista
You could try contacting Honda (relevant division) also; if they will provide the manual you want, it might be free
10.April.2015
Where can I buy a hard copy owners manual Honda generator eu6500is?
The manufacturer would be an excellent place to start... and they have superb paper manuals.
1helpful
What e 21 fault code mean on a Honda generator eu6500is
I have a brand new Honda EU6500 flashing starts but then quits and gives error code E-21. Turns out the rubber batter hold down was undone and blocks air intake so engine quits. Put strap back in place and now runs fine.
1helpful
Top Honda Electronics - Others Experts
ADMIN Andrew
ADMIN Andrew
Larry Ng
Larry Ng
Are you a Honda Electronics - Other Expert? Answer questions, earn points and help others
