Question about LG LRG30855ST Stainless Steel Gas Range
I am having problems with my stainless steel lg range the oven will not turn on IT IS A LSB5682SW/SB/S electric range
4 Suggested Answers
  • 1214 Answers
SOURCE: LG Electric Range Oven Keeps Shutting Off
When you say "Just shut off" do you mean the circuit breakers would trip, or fuses would blow? If so, I would have an electrician check that the circuit is properly fused/breakered and wire sized for the amount of power required by the oven. If the installation directions say it needs a 50 amp service, it better be a 50 amp service.
If shutting off is just something within the oven, then get LG back out again, and let us know of what they say is wrong.
Posted on Jan 24, 2009
dmftrucker
  • 1922 Answers
SOURCE: LRE307555SW/SB/ST\03 Nothing works, nothing.
Donna:
Have you checked the main power input terminals first? they do carry a lot of current and are subject to burning off,then if electronically controlled,it could be an electronic fuse in the ovens control panel/keypad shutting things down,somewhat unlikely though...let me know and thank you for using this site.....Dan
Posted on Nov 04, 2009
SOURCE: LG Electric Range Oven touchpad buttons not working
The lock and unlock works well for the 4 - 5 button problem. However the "start" button failure is another problem altogether. I had this problem and found that the ribbon connector attaching the membrane switches to the circuit card (PWB) is where the problem lies. The ribbon cables (two of them) are connected by a pressure contact connector mounted on the PWB. This connection method is less than robust. the fix is to pull the ribbon from the connector, clean it carefully with a paper towel and some alcohol, and reconnect it. To remove the cable the connector has a small flange that pops up about .05 inch whn you pull on the connector. Once it pops up gently pull the ribbon cable out of the connector. To replace it just push the ribbon back into the slot on the top of the connector and snap the flange back down. I strongly suspect this connector will get dirty again every couple years as the oven vent fumes are not properly prevented from partially passing over the PWB right where these connectors are mounted.
Posted on Dec 05, 2009
My LG electric range overheats every time it is turned on
If the sensor you changed is the rod type one in the oven itself then the only other thing possible is the control board where you set the temperature. The sensor works with that board to control oven temp.
Mar 31, 2015 | LG LRE30453ST (Electric) Stainless Steel...
Lg oven lost power during self clean want turn back on have power to the unit
Disengage the self clean closure and open and close oven door. Then start self clean cycle again.
Aug 11, 2014 | LG LRE30757ST (Electric) Stainless Steel...
LG LRE30453 (Electric) Range Problem is front left burner is shut off but the burner remains hot ... Range won't stop beeping. ...
I have a lg electric dual convection range (Model # lre30757st) and the front left burner turns on and off on its own. (It will not remain off.)
Jul 15, 2010 | LG LRE30453ST (Electric) Stainless Steel...
Need oven rack position for cooking meat position A,B,C,D,E,F, ?
Depends on what kind of meat you are cooking and if your roasting or broiling the meat?
Jul 19, 2009 | LG LRE30453ST (Electric) Stainless Steel...
Does not hold oven temperature
I have the same problem. I had a repairman come out and they told me it was the control panel and thermo sensor. Replaced both and still didn't fix the problem! Can't return the parts and now into the stove for over $370! I wish I had put that money towards a new stove :-(
Mar 29, 2009 | LG LRE30453ST (Electric) Stainless Steel...
LG LRG30855ST Stainless Steel Gas Range Logo
154 people viewed this question
Top LG Kitchen Ranges Experts
JP Services
JP Services
Oloyede Monsuru
Are you a LG Kitchen Range Expert? Answer questions, earn points and help others
