Question about Empire Comfort Systems Toshiba FT-7807 Cordless Phone Battery 1X3-2/3AA/B - 3.6 Volt, Ni-MH
FT-7807 will not charge new battery - Empire Comfort Systems Toshiba FT-7807 Cordless Phone Battery 1X3-2/3AA/B - 3.6 Volt, Ni-MH
    Problem Solver:
  • 13 Answers
If your from the northern area where temperatures are colder, you may need to change the type of acid in your battery. You will need to drain it completely being sure to be very careful and weat at least some latex nursing gloves. After you have drained the acid, properly dispose of it by pouring it down your bathtub drain. Now go buy some special northern cold-resistant acid called Muratic Acid which can be found at most hardware stores. Fill up the acid reservoirs on the car battery, reattatch the cables and fire 'er up. All should be good now.
Posted on Oct 31, 2012
I bought a new battery (FNB-RG-67LI) that arrived with 7.6 volts. I installed to the radio and conected to the ac outlet. After 12 hours charging is in 7.6 volts. my radio is the yeasu FT 60 with the...
That is about the nominal full-charge voltage on that battery pack. If the radio works, use it, let the battery run mostly down and recharge it. The FT-60 is a great radio, and mine shows between 7.4 and 7.8V with a fully charged battery, so yours is probably OK.
Sep 02, 2011 | Vertex Yaesu Radio FTH2070 Compatible...
Hi i bought a used power wheel by fisher price and it is a kawasaki ninja, i charged the battery then installed it. it ran for about 10 ft then shut off also the battery seems wheak and may be...
Most likely the battery is shot. These SLA batteries are really only good for a couple of years. You should be able to find a new on at any store that sell these battery powered toys, or you could search online.
Jun 30, 2011 | Fisher Price Power Wheels Rechargeable...
I have a service code CS541 for a Savin 2522 - I need to repair it
Ricoh copier service code SC541 refers to the fuser assembly having a problem.
Sometimes they code can be temporarily reset, however, it will eventually come back
and not go away!
While the printer is on do the following:
  1. Hold down both of the arrow keys for 10 seconds
  2. Press ENTER
  3. Select Option 2 for Engine
  4. Choose 7 Data Log
  5. scroll down to 7807 and execute it. click OK
  6. press the escape button until you get to the engine option
  7. then select option 3 to end
  8. restart the printer by pressing the power button.
If the above does not work, repeat the procedure but instead of 7807 look for SC calling, something like that, and reset the whole thing.
The reality is that the problem is fixable though, and do not need to purchase a new fuser, after clearing the code, the printer should work fine again
Jan 31, 2011 | Savin 2545DP Black and White Copier
I need a new battery for a yaesu ft 26
Try "Batteries Plus" either online or possibly a local outlet. I found the batteries for my FT51 there and half the price of the factory ones.
May 19, 2010 | Vertex FNB-27SM,...
Error code SC541 on a Nashu Aficio 1018, how do l clear this error
Hi ,
U can try this ...........
  2. Press ENTER
The reality is that the problem is fixable though, and do not need to purchase a new fuser, after clearing the code, the printer should work fine again.
AKPC_IDS += "1172,";
Mar 29, 2010 | Office Equipment & Supplies
Yaesu ft-50r HT getting very hot and not charging battery
From the description your battery has one or more shorted cells. Replace the battery.
Mar 15, 2010 | Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R,...
FT-11r no longer powers up with a known fully charged battery ? The battery was left in the unit a couple of months with a discharged battery. Could this have damaged the unit ?
It's unlikely leaving the battery pack attached ruined the radio, unless it leaked and corroded the contacts. Be sure they're clean and bright. Double check to be sure the battery pack really is charged to rated voltage.
Oct 09, 2009 | Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R,...
Battery will not stay charged Acer one will perform perfectly with the battery charger, the computor will not turn on with out the charger. I installed a charged battery and the unit works as advertised....
Before you replace the battery, put the charged on back in again to see if that on charges. If it does then the original problem will have been a defective battery.
Regards.
Aug 20, 2009 | Acer Aspire One AOA110-1588 Notebook
Infotec IS 2220D Copier (same as aficio 1022 i think) SC551 Error
Start by pressing clear modes, 1, 0, 7, and press and hold clear/stop. enter copy sp, select 7 fot data log, scroll to 7807, and execute. exit all the way out, and recycle the power. See if that does not fix your problem.
Mar 25, 2008 | Ricoh Aficio 1022 All-In-One Laser Printer
Empire Comfort Systems Toshiba FT-7807 Cordless Phone Battery 1X3-2/3AA/B - 3.6 Volt, Ni-MH Logo
93 people viewed this question
Top Empire Comfort Systems Electronics - Others Experts
Are you an Empire Comfort Systems Electronics - Other Expert? Answer questions, earn points and help others
