Question about Sewing Machines
Bernina activa 230 pe foot peddle not working
Foot peddle not working
  • Sewing Machines Master
  • 1,564 Answers
They do burn out sometimes. Just locate and purchase a replacement.
Posted on Nov 12, 2012
bargainbox
  • 1388 Answers
SOURCE: Bernina Activa 130/131
Because you say all was working for a while before this latest event, it will be the supressor that has failed, they are generally in the foot control (some machines have them in the main body near the power inlet) and it needs to be removed, it only stops interference to Radio & TV and is not necessary for correct function...............your nose will tell you if it is in foot pedal or inside the machine..
Unplug from mains, undo cover/s and find the electronic looking item which is cracked, burnt & probably oozing brown goo and smelling like burned plastic only worse.... Simply remove this from the circuit, clean the region with some denatured spirit, methanol or similar, wait until completely dry and re-assemble....this should fix the problem of the machine "running on" by itself....as to whether you have done a good job of the initial electrical repair, only you will know that.
By the way, how's the dog ? Guess the machine was not plugged in at the time !!
Posted on Feb 10, 2008
  • 619 Answers
SOURCE: Bernina Activa 135 sewing machine
Hi , the pedal micro switch are stuck , you may visit fixya repair service just , (enter zip area), you can find sewing machine repairman near you
Posted on Feb 22, 2008
  • 13 Answers
SOURCE: Bernina Activa 135 foot pedal problem
If you can get acess to or borrow another foot pedal to try I would do this first any of the Activa, Artista range fit to try. The fault may not be in the foot pedal but in the main CB of the machine. This can give a fualt of lights on but no motor drive. In this case the board would need replacing by a technician. Hope this may help.
Posted on Jun 23, 2008
RickE1
  • 202 Answers
SOURCE: I don't know how to use a Bernina foot I have
There are videos on the Bernina website on how to use the feet. #61 -#69 are all hemming feet. Look on this page of presser feet videos. Click the one that says #64.
http://www.berninausa.com/content-n401-sUS.html
hope this helps.
Rick
Posted on Mar 22, 2009
  • 980 Answers
SOURCE: Old model Bernina 830, running ok, then kept
There is a thing called a suppressor which is normally located in the foot control which has fused, you need to open the foot control and you should see a a small thing that looks liuke a fuse connected to the two terminals which you need to take out and discard because you don't need it any more, if you don't have on in the control then it will be on the motor which means you will have to take it in for repair.
Posted on Jun 27, 2009
Why won't my Bernina Activa 230 P.E. start when I turn it on?
it sounds like a computer problem. I suggest taking the machine to some other repair shop and see what they say.
May 05, 2014 | Bernina Sewing Machines
Bernina activa 230 sews a stitch then stops?
sounds like you bought someone else's problem, it could be mechanical or if the machine has a computer, that could be the problem, it would be a good idea to have the machine checked since it is used...
May 04, 2014 | Bernina Activa 130
Can Bernina walking foot with soles and seam guided used on Activa 210 be used on 16 yr old Bernina Activa 230????
Please be advised that the newer machines (Classic models) such as the 130-180 and up, have a totally different geometry. This is to say that the older machines have a shorter distance from the center of the presser bar to the needle center. The newer machine design was increased to provide space for needle threaders etc. Older machines will use an older Walking foot model (still available).
Feb 27, 2014 | Bernina Activa 130
Attachments for 140 activa
Do you mean a presser foot to sew rolled hem or shell hem edges?
If so, the Bernina website lists the accessories here:http://www.bernina.com.au/product_detail-n25-i61-sEN.html
Bernina feet 68 and 69 are rolled hem/shell, just different widths. However, I think the feet for the Activa are the new 3 digit numbered feet? I know there is the old style and new style attachment system for Bernina feet, if you look at the presser feet you got with the machine, they will have a code on the front of the foot; buy any new feet with same code format.
As to where to buy, I always start with the manufacturer/distributor in my country first. So start with www.bernina.com, go to your country, then "contact us" page and give the local office a call. They should be able to confirm the exact foot code you need and sell it to you or direct you to a local dealer who can.
Nov 14, 2011 | Bernina Activa 140
Bernina Aurora 440 knotting below my fabric and into bobbin area.
Are you sure you have the bobbin the right way round in the holder....when you look at the bobbin and tug the thread, the bobbin should move clockwise.
Pull out the foot pedal and use bsr2 with the start/stop button.
Bring bobbin thread to top of work before starting to sew. This may help knotting problem
May 25, 2009 | Bernina Activa 140
Bernina Activa 135
Is it plugged RIGHT into the machine? Is there something caught underneath the foot pedal? might be time for a check up at your local sewing machine mechanic.
Oct 24, 2008 | Bernina Activa 130
Jun 11, 2008 | Bernina 1008
Sewing Machines Logo
115 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
