Question about YouTube Videos
Vauxhall fault code p1607
Gear box actuator problem will not start.
Vauxhall insignia 2.0 petrol turbo engine management light started coming on and fault reads p000b what do I change ( engine doesn't miss a beat when light comes on)
code p 000B refers to cam shaft position (CMP) actuator , exhaust/right/rear bank 1---slow response ===causes wiring---CMP actuator--ECM
this is the unit that advances the valve timing at higher rpms and will not affect the engine performance noticeably under normal engine rpms
you may see it as increased fuel consumption
However that said it is advisable to take it to an accredited service center that has experience on your make of vehicle and have the matter investigated and fixed
Oct 29, 2016 | Vauxhall Cars & Trucks
My 2010 Vauxhall astra combo van has F showing on gears selected dashboard panel and i cant get gears
You need to have a fault code test run on the transmission control module (TCM) as a first step to seeing what is going on here.
Sep 21, 2016 | Vauxhall Cars & Trucks
Can you tell me what is the fault for code number p2075 on a Vauxhall ventral on a 2007 plate
code p 2075 refers to intake manifold air control actuator position sensor/ switch---circuit malfunction=== causes ---wiring---intake manifold air control actuator position sensor / switch
check the connections for corrosion or replace the sensor /switch
Jun 19, 2016 | Vauxhall Cars & Trucks
Thinking of buying vauxhall miriva what commen faults do they have if any
These are the most common reports:
- hard starting when hot, usually a fuel injector fualt
- steering rack rattle
- gearshift linkage looseness preventing gear engagement
- excessive oil consumption in the 1.0 L engine
- power steering failure, again a steering box fault
There have been 2 recalls
http://www.vosa.gov.uk/vosa/apps/recalls/searches/expand.asp?uniqueID=A9836539A223C7078025732C0049230A&freeText=Blank&tx=
http://www.vosa.gov.uk/vosa/apps/recalls/searches/expand.asp?uniqueID=E0CDDAC22D96D748802577C00034A75D&freeText=Blank&tx=
Mar 05, 2016 | Vauxhall Cars & Trucks
What is fault code 10171 vauxhall zafira 1.6 petrol 2008
www.vauxhall.co.uk/.../vauxhall.../zafira.../technology....
Jul 05, 2014 | Optics
Vauxhall astra 1.8 auto will change up the gears starting off but when in d4 wont change down have to put it into 3 2 1 manually aalso the light with the spanner is on
take the vehicle to your local fault code reader and plug the vehicle in to diagnostic equipment and go into the gear box control unit just like the E.C.U but for the gear box this should tell you any faults if this does not come up with any thing then try draining the oil and refilling with fresh I have known auto boxes play up just from old box oil if you are saying you hav a light on the dash then to save your self time messing with gear box oil (witch has a really nasty smell) get it plugged in first to eliminate electrical faults first hope this help good luck
Aug 24, 2013 | Cars & Trucks
I just got my car scanned and a few codes pop up
Error Code: P0130
Fault:
Oxygen Sensor (O2S) 1, Bank 1 - Circuit Malfunction
Possible Cause:
Malfunction Indicator Lamp (MIL) Triggered on first occurrence.
-Wiring harness.
-Oxygen sensor (O2S).
-Engine control module (ECM).
Error Code: P0505
Fault:
Idle Speed Control (ISC) System - Malfunction
Possible Cause:
-Wiring harness.
-Idle speed control (ISC) actuator/Idle air control valve (IAC) valve.
-Throttle motor.
-Throttle valve tight/sticking.
Error Code: P0100
Fault Location:
-Mass Air Flow (MAF) Sensor/Volume Air Flow (VAF) Sensor - Circuit --Malfunction
Possible Cause:
-Wiring harness.
-Mass air flow (MAF) sensor.
-Volume air flow (VAF) sensor.
Error Code: P1491
Fault:
Exhaust Gas Recirculation (EGR) Valve Insufficient Lift
Possible Cause:
-Wiring harness.
-EGR Valve.
-ECM
Error Code:P1607
Fault:
-Engine Control Module (ECM)/Powertrain Control Module (PCM)
Error Code: P0966
-Pressure Control (PC) Solenoid B - Circuit Low
Possible Cause:
-Wiring short to earth.
-Pressure control (PC) solenoid.
-Engine control module (ECM)/Powertrain control module -(PCM)/Transmission control module (TCM) .
Apr 30, 2013 | 2004 Honda Civic
Is my gear box gone?
it could be a lose plug on the gear box ecu. if the seal gets broken any water can get in even damp and make this happen. usely dose this in the mornings. just need to clean the plug out and replace the seal.
Apr 05, 2013 | Vauxhall Cars & Trucks
I have trouble starting my van and later on the check light came on (P1607). The car can no longer start but sometimes when I fiddle with the battery it would start up again and when it does it runs fine....
P1607 means "powertrain control module (PCM) internal circuit malfunction". According to the factory service manual, a low battery condition can cause this. This code can also pop up after the battery has been jump started.
You need to reset the PCM. To do this, turn the ignition switch off. Remove the No. 13 fuse (7.5Amp) from the passenger's under dash fuse/relay box for at least 10 seconds. Put the fuse back in. That should complete the reset.
Now to check again for the code: turn the ignition switch to on (not start.) Wait 30 seconds. If the check engine light stays OFF, turn the ignition switch off and wait 10 seconds. Turn the ignition switch back to on (not start). Wait 10 seconds. If the check engine light stays OFF, you had an intermittent fault and it has now been reset--everything is fine. If the check engine light comes back on during these checks, have the code that set read out. If the code is P1607 again, then you may have to have the PCM tested at the dealership for an internal fault.
Feb 04, 2011 | 2002 Honda Odyssey
Diagnostic Trouble codes...Hyundai xg300
P1191 ETS Limp Home Valve On P1193 ETS Limp Home - Low Rpm
P1607 Vacuum Sol. Valve Stuck On or Vacuum Solenoid. Valve Stuck On,
I believe you have aproblem in the electronic throttle control motor/actuator, all three code's are related.
Mar 17, 2009 | 2001 Hyundai XG300
YouTube Videos Logo
154 people viewed this question
Top YouTube Computers & Internet Experts
Rizwan Hanif
Level 1 Expert
Michael Terence...
Michael Terence...
Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
