When i turn my dvd it displays oc rr1 the after a while it will automatically turned off my remote even don't work even if i change its battery
  • 3 Answers
The Laser eye need to clean with a soft cotten.
Posted on Oct 27, 2012
5 Suggested Answers
Golferdon
SOURCE: DVD DMR-E50 Doesn't Work
As it's been 5 months I suspect problem's been solved - how? I have similar problem, E50 recorded DVD-r's lock up after playing about an hour. RAMs and commercial DVDs play fine.
Posted on Jan 12, 2008
SOURCE: dsc-363 displays code " oc err 1 "
It's output power amplifier ic problem. change ur output ic
Posted on Jan 27, 2010
  • 6771 Answers
SOURCE: remote control will not operate dvd player.
The remote has probably quit working, to be sure take it to a tv repair shop, they should be able to check it while you wait.
Posted on Dec 31, 2010
brandonbmw
  • 31 Answers
SOURCE: When I turn my DVD
The remote could be broken. What happens when you press play on the DVD player this should start the movie. You can buy a cheap univesal RCA remote if you need to replace the old one.
Posted on Mar 12, 2011
I have a JWIN VD519 DVD player that has worked fine till this evening. The remote suddenly stopped responding even after changing for new AAA duracell batteries. Nothing has been spilt on the remote...
Hello
you can test your remote with a mobilephone camera like this:
open camera on the phone an hold the remote front against the camera
(approx 10cm from it) press a button and look in the display on the phone.
if the controller works you should se a blue light in the display coming from the remote front.
if no light: try other batteries again note the battery polarity. no light= controller broken.
if there is light= the remote is working. try to disconnect power from the DVD for a few minutes,
and try again. if it still not works the player is propably broken.
Good Luck
Sep 05, 2011 | Jwin JD-VD149 DVD Player
When I turn my DVD player on and put a DVD in, the DVD plays automatically until the menu screen comes up on the TV. At this point, the display on the DVD player shows "root" and I can not...
Mar 12, 2011 | RCA DRC212N DVD Player
Problems with Sony RDR-GX300 DVD Recorder....I HAVE THE ORIGINAL REMOTE FOR THIS UNIT AND IT WILL NOT CONTROL IT...BNUT WHEN I POINT IT AT A SONY T.V. IT WILL WORK ON THAT UNIT????
Try changing the "command mode" switch on bottom right corner of remote. Setting 3 is the default code. This setting must match the setting in the system setup menu.
Feb 20, 2010 | Sony RDR-GX300 DVD Recorder
Jvc dvd player not playing
Even you don"t have a remote you can play it manually and DVD player play it automatically.Just try this open the tray put the DVD disc on the tray and close it then turn it off for 30 seconds then turns it on then it play automatically if not then there's something wrong to the player.
Hope it may help you:
Regards:
VOTIT
Mar 23, 2009 | Audio Players & Recorders
Dsc-363 displays code " oc err 1 "
Mar 08, 2009 | Pioneer DV-363 DVD Player
Panasonic dvd video recorder DMR-E55 remote does not work
THe problem was not with the remote but with the hookup of the player.
Dec 22, 2008 | Panasonic DMR-E55 DVD Recorder
TV w/ built in DVD
Hi maybe this might work on your dtv,try load a post card the size of a dvd and hold it in then try the source button to change to tv mode.It worked on my dtv-265-d now all i need is to get a remote control.
Aug 09, 2008 | Mintek DTV-263 26 in. LCD Television
Remote won't work
hi, see if the right funtion is selected, tv, vcr, dvd.then if that does not help, get a universal remote. they don't cost alot or some don't good luck. hope this helps.
Apr 15, 2008 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Panasonic DMR-ES20
For the remote to work, make sure "video" is selected (instead of "tv"). It's the little button on the remote under the red button at the top that turns on the TV ("TV/Video")
As for the split screen, I've had that happen numerous times (when I lose power or revert to default settings). YOu have to go to Setup, Display, and select 4:3.
I hope I have helped you. I'm having other problems - with the audio. Some channels have no audio (maybe 3 or 4) and 2 channels are in SPANISH!!! (??) Weird that it's not uniform. I even tried reverting to default settings (and got that split screen!), but didn't help. It "jumped" a few times to the input type screen. I'm thinking some chip got fried or something. I've had it almost 2 years, and guess that's the "built-in" obsolescence!! :-)
Sep 26, 2007 | Panasonic DMR-ES20EG DVD Recorder
Aug 12, 2007 | Panasonic DMR-E50 DVD Recorder
Televison & Video Logo
Top Televison & Video Experts
