Question about Vizio VW37L 37 in. LCD HDTV
Vizio vw37L hdtv20a Vizio light turns on white but will not turn off. Screen stays black and no sound. No back light. Has any one a solution for this problem?
  • 3 Answers
SOURCE: 32 inch vizio will not turn back on, just stays orange in front
Try unplugging the tv and holding down the power button for 30 seconds than pluuging it back in and if it does not come back on the tv will need a repair to the power supply, just call tech support and make sure to have the serial number and the reciet handy so they can get you registered on the support system. Hopefully your tv is still under the one year mark than the repair will be free if not it can get expensive fast. Me personnaly have worked for vizio for about a year now and honestly this is a very common problem with theses tv's.
Posted on Mar 26, 2009
  • 92 Answers
SOURCE: Plasma does stay powered on
Your sustainer board is probably bad. You need to get the Y & Z sustainer boards replace then it should be okay.
Posted on Feb 09, 2009
  • 10 Answers
SOURCE: I CAN TURN THE POWER ON. THE SCREEN STAYS BLACK.
This TV has 2 main circuit boards (2 LCD backlight controlers): the Power Supply board may have fried the video board on it's way out ...
You can either arange to have the TV replaced under warenty if not have it serviced. In any case best of luck with Vizio support line.
Everyone bought this TV because it was so cheap... now we find out why: Vizio cuts corners on everything from engineering to support!! All brands are not created equal. Sometimes you get what you pay for.
Posted on Feb 25, 2009
  • 92 Answers
SOURCE: I went to turn on my Vizio and the scrren was
Do you have back light when turning on the TV? if you do then just replace the main board should resolve the problem. if you do not have back light, you will need to replace the inverter board(s) depending on your model. The inverter board(s) is located on the left side of the TV facing back of TV. you may have two inverter boards depending on your model. the other is located on the right side of the TV. Both mount vertically.
Posted on Jun 18, 2009
budmrtn
  • 11361 Answers
SOURCE: I have a Vizio VX32L and when I turn it on the screen flashes and
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Vizio+VX32L+
Please post back what you find.
Posted on Dec 16, 2009
Testimonial: "Thank you. I was checking them out."
Color problems vizio lcd hdtv
If your tv has a custom settings area, first turn all color down on set so picture looks black and white. Now in color settings look for red blue and green color bars. Use the bars until the picture looks as true to black and white as possible. Also, try changing color temp.
Dec 21, 2013 | Vizio VW37L 37 in. LCD HDTV
I have a vizio vw37l hdtv20a. A few years ago shortly after getting it the TV made a sound almost like something popping, then just turned off. When i plug it in no lights come on or anything. It's been a...
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sep 01, 2017 | Vizio VW37L 37 in. LCD HDTV
Vizio vw37l hdtv20a standby light on but wont turn on
you either have a faulty power supply or faulty main board. Vizio power supplies on the older sets are pretty decent. It's usually the main boards that go. These older main boards tend to be pricey so it may be better to buy a new set.
Mar 27, 2013 | Vizio VW37L 37 in. LCD HDTV
WHAT IS THE REMOTE CODE FOR A 42' VIZIO MODEL NUMBER VW37L HDTV20A
0116
0117
1126
0113
0115
0114
Please try those codes. These are from a Vizio manual.
Sep 06, 2011 | Vizio 42 in. LCD TV
I have a vizio vw32l hdtv20a it dont turn on now the vizio light is amber when plugged in turns white when you press the power button but the screen stays black as it does when its off NOT black as when...
If you lost the control when trying to use the switches on the TV, it means that the Main board is not functioning, this can be due to bad processor, bad unsteady DC. The main board send the ON signals to the Power supply and the backlights inverter board.
You should inspect the power supply module first since unstable DC can cause a lot of problem, if the voltages and components checked out OK , then you may ahve to change the main board. It will require in-depth troubleshooting to really narrow down the cause of the problem.
Please read my guide first to see if you will want to DIY repair or not.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Aug 06, 2011 | Televison & Video
I have a vizio vw37L and after about a min or so the picture goes out but it still has sound
Does the screen go black or does the screen turn off? To determine this, cup your hands place them against the screen with your face in your hands. This effectively blocks all other light out, if the screen appears to be lit even though it is black, the screen is still on.
If the screen in on but black, 1. Check the cables that are attached. If there are separate cables for the video and audio, make sure the video is properly inserted. 2. There is an internal problem with wiring. Check your warranty and try and return it or get it repaired.
If the screen is off, 1. The lamp is burned out inside the tv. This is usually a free fix if the tv is under 2 years old. Contact the establishment where you purchased it or the manufacturer for details.
Mar 08, 2011 | Vizio VW37L 37 in. LCD TV
I have a Vizio VW37LHDTV10A LCD t.v. set that was built in august 2007. The power will come on and I can see the back light turn on. However, the screen stays black and there is no picture or sound. Then...
My friend, I recently fixed a vizio vw37l with the same problem but it was the lcd controller.
hope this helps a bit to diagnose your problem
Aug 27, 2010 | Televison & Video
My son changed the preset password on my vw37L tv i need to reset it plz help me
Well i just want to start off linking you the link to your tvs manual in case you have lost it
vizio VW37L HDTV20A User Manual
YOUR TVS MANUAL
vizio contact info if im unable to assist.
For assistance, please call (949) 428-2525 or email
us at techsupport@vizio.com.
IF its not the parental password option this will work
Under the Menu
Reset All Settings
Press Down the button to highlight the Reset All Settings selection.
Press Arrow poiting right button to reset the TV to the default factory settings.
Press either the MENU button to return to the previous menu display or the LAST key to return to your
program if task has been completed.
Note: This does NOT reset the Parental Control Password.
Their is no instructions on how to reset this.
Oct 11, 2009 | Vizio VW37L 37 in. LCD HDTV
Jun 17, 2009 | Vizio L32 32 in. LCD HDTV
Vizio VW37L 37 in. LCD HDTV Logo
165 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
