Question about Simer A5000 Ace In The Hole Battery Back Up Sump Pump System
I have a Simer A5000 Battery back up sump pump system and the breaker on the unit is tripping everytime i test it.
2 Suggested Answers
gary1121
  • 332 Answers
SOURCE: hammering sound at shutdown
it has a check valve to keep the water from going back into the pit when it shuts off, depending on how high the pipe goes up when it stops pumping the water closes the check valve in which the noise, unfortuintly there is no quick fix, even changing the check valve it could still make the sound
Posted on Jun 23, 2009
WHY THE PUMP WONT TURN ON,
It is possible that the pump itself has failed.
May 08, 2014 | Simer A5000 Ace In The Hole Battery Back...
The flood light stays on and the pump will not work
Can anyone help? My Simer backup sump pump flood light is on continuously. All the rest of the lights seem to be working fine and the pump looks like it is in working order. When I toggle the lood light button it just gets brighter. tHANKS...SCOTT!
Jan 14, 2013 | Simer A5000 Ace In The Hole Battery Back...
Alarm won't shut off
This system does not have an alarm. The accessory alarm is something else. Check it's sensor and make sure it didn't get knocked into the pit.
Jun 30, 2012 | Simer A5500 - A5500 - Super...
Mark II The unit ran for 30 minutes and shorted blowing the circuit breaker
I don't have too much advice for you. The pump only draws 6 amps and most breakers are 15 amps or more. There is also a thermal overload that if the pump gets hot it will open the circuit, preventing the circuit breaker from opening.
Did the pump actually short? Maybe it is finished. How old is it?
Gary
Aug 23, 2011 | Simer 2905 Mark I 14 HP Submersible...
My simer ace in the hole a5000 will not charge my 2.5 year old battery. The battery voltage reads 10.75 volts. I replaced the twelve volt charger and it originaly lit the yellow charging light , but it no...
I does sound like a controller issue. Try testing the charging output (be careful, who knows what the voltage may be coming out) I would say it is the battery but the yellow light thing has me thinking you are right. That thing has been sitting there maintaining the battery for 17 years, it is probably tired. The other bad news is if your battery has been sitting at that low volta.ge it may have a greatly reduced capacity now. Hope this helps some. .
Jun 09, 2011 | Vacuums
My backup battery for my sump pump is telling me to recharge the battery. These things are all new to me never had to have one. My model is ace in a hole A5000. Have no manual from the previous owner....
yes but it has to be disconnected before you charge it. also check the battery for water level in all cells. basement watchdog is a better unit. yours on a good battery might run for 4 hours when the powers out. it should have a large deep cycle battery for it to work well
Nov 22, 2017 | Simer 3/4 Hp Stainless Steel Sump Pump
Hammering sound at shutdown
Apr 15, 2009 | Simer 3/4 Hp Stainless Steel Sump Pump
Simer A5000 Ace In The Hole Battery Back Up Sump Pump System Logo
134 people viewed this question
Top Simer Plumbing Experts
Renee Knafel-Bullock
Tom Chichester
Bill Boyd
Are you a Simer Plumbing Expert? Answer questions, earn points and help others
