Question about Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl
How do I clean the macerator - Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl
  • 41 Answers
Here is a nice link for your saniflow maintenance.
http://www.plumbteamltd.co.uk/sanifloguide.html
This will may help.
Posted on Feb 07, 2013
Sanislim macerator very noisy. It may be blocked. how do I check?
Check the masserator is clear also check the outflow pipe , maybe a good clean see this link for more info
This will may help.
Oct 27, 2012 | Saniflo & Saniplus& Macerator Pump
3yr old saniflo + started making loud vibrating noise and smells also small black particles come out - husband opened top and looks like a mesh thing has disintegrated. Toilet is at end of sink, bath /...
Unfortunately the systems are desiged to pump out. The disintegrated screen thing is part of the maceration end of the system. Your going to have to clean the thing out and replace the macerator.
Jun 20, 2011 | Saniflo 002/003/005 Saniplus Toilet with...
Whining noise after the flush is filled and the noise keeps on but if the macerator is given a gentle kick the noise stops! Do I need a new Macerator?
sounds like there could be a blockage inside which is effecting the pump or the float switch look on the saniflo website for instructions how to clean etc or phone there tec department
Dec 09, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
Pump cycles often
The following are the possible problems and solutions:
  1. The tank flapper (Flush Valve) leaking allowing water into bowl. Make sure flapper is fully seated. If flapper is fully seated and still is leaking replace flapper.
  2. Faulty Non-Return Check Valve, water leaking back into Macerator. Clean and Inspect check valve replace if after clean water still flows back into Macerator.
I hope this answers your question and gives you a few more places to look. Please rate the answer on it's helpfulness. Good Luck and have a great day. Jeff
Apr 06, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
Pump wont stop
  3. Check micro switch, the micro switch turns on pump when the water level reaches to a determined level. Location of switch is in the pressure chamber. Check to see if switch is sticking. Note: For safety Macerator should never be operated with lid open
Mar 27, 2010 | Saniflo & Saniplus& Macerator Pump
My turboflush macerator does not take all the
indicates that the unit may need cleaning /descaling. alternatively the 22mm pipework (outlet) may be partially blocked
Dec 27, 2009 | Saniflo & Saniplus& Macerator Pump
Saniflow keeps on macerating after flushing, and I have to isolate it from the mains
Sounds like a stuck float switch .. probably due to gunk inside the macerator. You'll need to empty all of the water out of the WC, cisterm, isolate the electricity and disconnect the saniflo (i.e. take out WC and cistern), open up the saniflo and give it a good clean
Good luck
Dec 26, 2009 | Saniflo SaniPlus-Round SaniPlus Macerator...
Have just had our macerator cleaned out as we had a blockage now on reconnecting, we find that it is working again but will not switch off - any ideas?
it might be that pieces of your blockage have gone into the shut off valve and stuck it open if there is a way see if you can clean the valve out
Dec 17, 2009 | Saniflo SaniPlus-Round SaniPlus Macerator...
Saniflo Macerator Noise
If it's a one shot cleaning and not an ongong additive, bleach can be used to dissolve the tissue.
Charlie
Aug 03, 2009 | Saniflo & Saniplus& Macerator Pump
My macerator turns off and stops working for 10 - 15 minutes
the macerator is over heating.check the maintenance opening and clean it ,but you may need a more powerful macerator,some are made only for flushing systems (as in toilets) a pro-longed use may be making it overheat.. good luck
Jul 02, 2009 | Saniflo & Saniplus& Macerator Pump
Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl Logo
195 people viewed this question
Top Saniflo Home Experts
Paul Carew
Tim Whalen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
