Question about Sharp CD-C3700 Shelf System
Sharp CD-C3700. Only hear sound from cntr speaker. Are there fuses inside?
    Master:
  • 444 Answers
Only 1.End that would not cause that problem. Some has blowin on it.
Posted on Oct 27, 2012
2 Suggested Answers
SOURCE: sharp model cd-c3700
I need a manual for a sharp 3 drawer cd model cd-c3700
Posted on Jan 09, 2010
Speakers aren't emitting sound
The fuses are on the power board at the bottom of the unit. Fuses 901, 902 and 903 are for the left, right and sub speakers. The service manual is here, remember to unplug it from the supply. Page 62 shows PWB C1. The speaker terminals was the answer to your original question.
http://diagramasde.com/diagramas/audio/Sharp%20CD-PC672.pdf
Sep 06, 2017 | Sharp CD-PC672 CD Shelf System
My Sharp XL-HP500 CD Shelf System turns on, but shuts off immediately.
No! you have short in the system, remove speaker wires from back and plug headphones in, if okay it means there is a short in the speaker wire or speaker, if no change the audio output ic's should be suspect.
Jun 16, 2012 | Sharp XL-HP500 CD Shelf System
I have a sharp tv with the volume at its highest but i can't hear anything
Hello
Check its speaker first. If voice coil of the speaker or tis cone paper has damaged, speaker will produce a dull low sound output. If the speaker is found OK, check the audio output section of the unit. This section circuits can be located inside the TV circuit board. look for any loose or bad soldering terminals at the audio output IC. It is best to resolder all the suspected solder points by applying a little more solder, withut making any solder bridge short in between adjecent solder terminals. If this also does not help you, replace the audio output IC. It is damaged. OK.
Dec 26, 2011 | Sharp 13VT-R100 13 in. TV/VCR Combo
The horn works but not the 15" you can hear the
Hi, problem can be solved. The problem can be from two places,
From the speaker and,
also the cross over.
I might be from the speaker if the wire connected from the cross over inside the speaker has cut or has removed.,it can make the speaker (15),not to make any sound..
The cross over might also be the fault too. The cross over is located inside the speaker and it makes the 15 speaker makes sound..
'There are capacitors on the crossover that control and makes the 15 speaker make sound.If the capacitor gets damaged it can make the sound stop. Also you will need to check the fuse inside the speaker, you will find the fuse on the cross over of the speaker.
Troubleshoot the above, and problem solved,...
Hope that helped..
Thanks fro using fixya.....
Oct 29, 2010 | JBL EON 15-G2 Powered DJ Speaker With EQ...
How do I get the "change oil" message off my 2008 f 450 superduty?
Message center cluster
#1 press and release setup button until mess. cntr. displays"press reset to begin system check"
#2press and release reset button until cntr. displays"hold reset if new oil"
#3press and hold reset button for 2 sec. and release oil life should read 100%
#4 center displays"setup menu hold reset"
base cluster
#1 press and release trip/reset button until mess. cntr. displays"setup menu hold reset"
#2press and hold trip/reset button 2 sec. until mess cntr. displays"reset for system check"
#3 press and hold trip/reset button 2sec. until mess. cntr. displays"oil life XX% reset if new"
#4 press and release trip/reset button until mess.cntr.displays"hold reset if new oil"
#5 press and hold trip/reset button for 2 sec.and release to reset to 100%
#6 mess. cntr. breifly displays oil change set to 100%.
HOPE THIS HELPS
Feb 10, 2010 | 2008 Ford F 250 Super Duty 4WD
I have a Sharp XL-MP60. It powers up, shows a
Sometimes got fuses for the speakers check that but if they don´t got it the audio amplifier IC maybe are fried
Jun 11, 2009 | Sharp XL-MP60 Shelf System
Sharp model cd-c3700
Nov 16, 2008 | Sharp CD-BA2600 CD Shelf System
No sound whatever
when you switch the unit on make sure that you hear two clicks, this will tell you whether the protection relay is working. Should you hear the two clicks this will indicate that the audio ic`s are working. There are fuses inside the main component box, four on the transformer. Let me know the outcome
craig:)
Jan 20, 2008 | JVC MX-J900 CD Shelf System
Volume
Check for any blown fuse on the board with the power transformer.
Jan 03, 2007 | Sharp CD-XP5500 CD Shelf System
Sharp CD-C3700 Shelf System Logo
60 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
