Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
I have a external hard drive and i was using it tonight and all of a sudden it just stopped working
  • 728 Answers
First thing you need to do is to determin if the drive is working or not.
Either the drive itself failed or you did not stop your external hard drive safely in your PC or Macintosh before unplugging either the power or data cable.
1: Determine if the drive itself has failed
For purposes of testing, connect the power adapter directly to the wall. If you do not hear or feel the drive spin up when you connect the power, the drive will need to be replaced. If the drive spins up, but nothing shows up in My Computer or in Disk Management, change the USB cable and connect the new one to another port on your Computer. If it still doesn't show up in Disk Management, try the drive on another PC to see if it shows up on that computer. If that computer still does not detect the drive by showing you the system tray icon or by listing the drive in the Device Manager after you plug in the drive, the drive is bad and needs to be replaced.
If you require data recovery services on your failed drive, here's a list of authorized preferred data recovery partners
If you find that you do need to replace your drive, here's a link to WD to replace it.How can I replace a product under warranty?
2: Determine if the drive can be used again
If the computer does detect the drive, you can test the drive by using WD's Windows Data Lifeguard Diagnostics. For more information on how to use the software to test the drive, Click here: How to test a drive for problems using Windows Data Lifeguard Diagnostics
Now If the software reports an error for the drive, you will need to look up what it means here: Data Lifeguard Tools 11 Error Codes .
If the software shows no errors for the drive, and you do not wish to send the drive for data recovery, you can partition and format the drive so you can use it again. For step by step information on how to format the drive click below:
IMPORTANT: To avoid corrupting or losing the data on your external hard drive you should always shut down the drive correctly before you disconnect the data cable from the drive or computer, or the power connection from the drive or the wall outlet.
I hope this helps and Good Luck!
Mark
Posted on Jan 04, 2009
The light on the hard drive is on but my laptop isnt recognizing that it is connected? I have no problems for the last 12 months then suddenly it stopped working
Have you try to use other cable or test it to other computer?. If the problem still the same then their is a chance that your external drive are already deffective. Try to visit a store catering hard disk recovery for any possible chances of recovery. Just a thought hope it helps thanks.
Sep 23, 2011 | Western Digital My Book Essential 1TB...
My WD external hard drive has suddenly stopped being recognised by my computer
Unplug the power supply from the hard drive, leave for 15 seconds.
Plug power supply back in.
Try another USB cable if that does not work.
Aug 08, 2011 | Western Digital Elements powered by WD 320...
External HDD no longer recognized by new win7 PC
Probably not the right answer for your problem. Mine is an external 1 TB Simple Drive. Mine wouldn't respond at all. I unplugged the power cable from the back of the hard drive and replugged it in and instantly it worked. I had tried rebooting the computer, plugging/unplugging over and over into the computer and that didn't work.
Jun 19, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
Suddenly stopped working
i think your hdd is dead,Because your hdd light not even turn's on....
Apr 09, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My hard drive suddenly started beeping and stopped working
Your drive has failed. to try to get back some of your items put the drive in the freezer for a day. the chill will make the heads condense enough for about 3 hours of use for emergency backup.
Nov 07, 2009 | Hitachi 500GB External USB 2.0 Hard Drive
WD 500GB external hard drive won't load on new macbook
Dear Sir,kindly note this problem usually caused by a firmware damage,so you need find a dr company to use tool to repair the firmware,you can contact with me :honglake@gmail.com
Mar 19, 2009 | Western Digital 500GB My Book Pro-External...
I bought a Western Digital 640GB external hard drive about 6 weeks ago and installed it just fine. Have been using it (only used about 50GB) for 6 weeks with no problems. Today a notice appeared from Memeo...
This trial software expiration shouldn't prevent the external drive from working. The drive should be visible in "My Computer", Windows Explorer etc. A quick way to determine if the drive does have a problem, is plug it into another system- if it works there, then you have some sort of problem on the first machine- likely a software bug- or maybe some virus has fouled things up.
Jan 07, 2009 | Western Digital 320GB MyBook External USB...
Computer suddenly not recognizing relatively new WD MyBook 640GB
Just a shot in the dark, but ..., shut down your computer and unplug the drive. Turn the hard drive off, then back on. Plug it back into the computer and restart. If it doesn't pop up, restart your computer this time with it plugged in.
Is there any noise coming from the drive? Is the green light on the front?
The same thing happened to me and the same drive, but 500gb. I did the above and it fired right back up again. You may have to delete the trial version from the drive if it on there, or from your computer if you had originally installed it.
STECH 320GB Corrupt Boot file
sure..take it to a recovery expert..they love this sort of work..not cheap..but highly effective..
and you may wish to consider backing up that external drive in future.
May 25, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
165 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
