Question about Psion Series 5MX
I'm looking for psion 5mx circuit diagrams - do you know if they are available anywhere?
  • Anonymous Mar 11, 2009
    A block diagram would be great - I haven't managed to find anything yet. I'm considering putting linux onto mine and accessing the hardware directly.
  • John LeFebvre May 11, 2010
    There are a few block diagrams around on the net that I have seen, but no detailed circuit diagrams - these would be considered Psion's intellectual property.
4 Suggested Answers
  • 155 Answers
SOURCE: Psion 5Mx
Only suggestion here is to try a cold reset. Make sure you have an up-to-date backup. Take all the batteries out and leave for a couple of hours. Re-install batteries and check the Psion. If all looks good, do a restore. If things look bad again, your system was corrupted so reset again but do not do a restore. You will then have to trial-and-error reloading parts of the backup.
I would suggest re-installing any third party software from scratch.
Posted on Feb 03, 2009
  • 154 Answers
SOURCE: I am trying to obtain a Manual for t5he Psion Series 5mx.
try downloading from link below--
http://www.garethjmsaunders.co.uk/psion/downloads.html
Posted on Mar 04, 2009
SOURCE: Tranfer data from a Psion 5mx to an iMac by infrared
Will take this up with Apple. Thanks RH
Posted on Sep 01, 2009
Psion Revo replacement restore
What do you do if you no longer have access to a Psion, but need to access some data from an old Psion backup on your PC? Native Psion files can't be read on a PC, but fortunately, there are some solutions:
  • Use the PsiWin PC connectivity suite to convert the Psion-format files to a format that can be read on the PC.
  • Download and install the Psion ER5 emulator - this gives you a Psion machine on your PC, and will allow you to access your old data on a PC - See our emulator setup page. From the emulator, you may be able to print or export your data to a text file, or use a third -party Psion converter
  • Consider borrowing or buying an old Psion machine, loading the files onto the Psion, then printing the documents or data as a text file
  • Find another friendly Psion user that may be able to convert the file into a format that can be read by a PC for you. If you don't know of another user, try asking for help in our Psion forum
also
Data conversion for the Psion can be quite complicated, due to the file formats used by Psion / Symbian. You should find that the PsiWin program supplied on CD with your Psion machine can help you with most of your conversion needs. If your PC is connected to your Psion, dragging files from "My Psion" to the PC should prompt you to convert to a PC format, otherwise you can convert files that are stored on the PC, using the Psion File Converter. This program is installed with PsiWin and is located in c:\program files\Psion\PsiWin - the application filename is Cpycnv.exe
psiwinconv.jpg For more help on file conversion, see our dedicated conversion page.
Agenda and Contacts databases: Note that these can't be converted using the Psion File Converter - PsiWin supports synchronisation of these files, but not direct conversion. See our suggestions in our Backup FAQ. The most common solution is to load up the files in the Psion Emulator, and either use Print to save the data as a plain text file, or use a Psion-based converter, as detailed on our Conversion page
Sep 17, 2008 | Psion Computers & Internet
Is there a way of refurbishing the faded white legends on the keyboard of my Psion 5mx PDA? Or is there a repair company which undertakes such work?
You either need to buy a broken Psion with a good keyboard and replace the keyboard in your machine yourself. Look on Ebay.
The other way would be to trade-in your machine with one of the resellers that deal with Psion machines.
Problem made worse if you live outside the UK.
Hope this helps
Mar 15, 2010 | Psion Series 5MX
I was using my Psion 5mx This evening "Playing the bombs game" when suddenly the game froze. It didn't freeze completely as the game timer was still going and I was able to switch the PDA off. After that...
Unfortuately after taking the machine to my local Psion Teklogix Retailer, I was told that my only solution wast to perform a "Hard Reset" on the machine. Thankfully the PDA still works fine, but my data is all gone. I've managed to restore my data up to July 2009, but the rest I'll have to write off to a learning experience. Needless to say, I'll never play the "Bombs game again". :-)
Dec 02, 2009 | Psion Series 5MX
The touch screen isn't working properly
Go to Psionflexi.co.uk. You will find the answer there.
Nov 01, 2009 | Psion Series 5MX
Aug 31, 2009 | Psion Series 7
Psion 5Mx
Feb 01, 2009 | Psion Series 5
Circuit diagram
i need circuit diagram of 107e61/94 model.
Feb 19, 2008 | Philips 107E61 17" CRT Monitor
Psion 5 fc card
The formatting is supposed to be identical on Psion and PC but in practice they are not. You should never try to repair a CF card on a PC for instance as it messes with the filesystem making it unusable on the Psion. Try to format the card on the Psion if you can, or if possible find or borrow a camera which takes CF cards and use that to format the card - that should do the trick.
Dec 11, 2007 | Psion Series 5
Psion Series 5MX Logo
46 people viewed this question
Top Psion Computers & Internet Experts
Lee Michel
Level 1 Expert
Are you a Psion Computer and Internet Expert? Answer questions, earn points and help others
