Question about Lenovo ThinkPad R51
Removable Drive i've reinstall my windows and the problem comes, my flash drive doesn't appear on windows explorer, i have to go to 'device manager' and go to the disk management, right click at my flash drive that doesn't have a drive letter, i change the drive letter and then i can right click and click 'open' so i can 'open' the flash drive, if i 'browse' the flash drive it'll automatically closed the explorer. any clues are welcome... thanks
    President:
  • 2,961 Answers
If you have reinstalled windows you will need to install the driver for your flash drive, because there are no built in drivers. install the driver and the drive should then be recognised and then show in device manager
Posted on May 14, 2007
Not recognice by usb hard
A USB hard drive is a portable external storage device that works just like a conventional hard drive.
The device is simply plugged into a USB port on your computer as you would connect a flash drive.
Unlike a flash drive, however, a USB hard drive can store a much larger amount of data.
If your computer will not recognize your USB hard drive, you can try troubleshooting steps to resolve the problem.
Plug one end of the USB cable into the port on your hard drive and plug the other end into the USB port of your computer. Ensure that both ends of the cable are connected securely.
Open "My Computer" (Windows XP) or "Computer" (Windows Vista/7).
The USB device should be listed as "removable disk" once it is plugged into the computer.
If it is not listed among the available drives on your computer, proceed to the next step.
Ensure that the data cable is working properly.
Try another USB cable if you have one available.
Disconnect all other USB devices from the computer as they may interfere with the operating system detecting the external hard drive.
Reboot the computer if the USB hard drive is still not recognized.
Plug the USB cable into another USB port and check to see if the device is detected.
If you are using a USB hub, remove the device and plug the external hard drive directly into a USB port.
If the computer still fails to recognize the device, the external hard drive itself may be experiencing a hardware problem.
Check the status of the hard drive in the "Device Manager" window. Under Windows XP, right click "My Computer" and select "Device Manager."
For Windows Vista and Windows 7, click the "Windows" button in the lower left corner of the screen, then type "Computer Management" in the search bar and press "Enter."
Select "Device Manager" in the "Computer Management" window. In the Device Manager window, click the "+" sign that appears beside "Disk Drives."
If the external drive is not listed, click "Other Devices" in the Device Manager window and see if an "Unknown Device" appears.
The external hard drive may have been detected but the device is not working properly.
If it is still under warranty, take the device to the computer store where it was purchased to have it repaired or replaced.
Hope this helps
Nov 07, 2012 | Computers & Internet
Hp pavilion dv 6910us with windows 7 ultimate 64 bit doesn't recognize my installed dvd rw drive by pioneer model kd08... sometimes it will appear in devices with removable media but will later...
this could be a registry issue
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
hope this helps you
Sep 08, 2011 | Pioneer DVR-KD08 DVD±RW Dual Layer Burner
I have 2gb verbatim flash drive.It worked fine when i first used but next time my computer recognizes it as a removable disk. After some hours i tried again and for some reason it worked. While i was...
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
click start click on my computer you should see your drive
right click then select format
another way is to control panel administrive tools computer management disk management right click on your drive select format
hope this helps
Jul 03, 2011 | Verbatim CORPORATION 94933 USB 2.1GB...
My memory card does not format and has msdc error.how can i format it in windows xp because when i try to it brings windows can not format the disc.
Hi ,JHONPIX
If your computer affected by virus,then your memory card will not show in the pc .so you will install it to another pc,and format it .Flash drive can not recocknize,becayse there are some reason .
  • VIrus affected
  • Sometimes when a flash memory stick or USB external hard drive fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory USB hard drive device appears to malfunction it may be possible to restore it by reformatting it. Insert the flash or USB hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted then it will indicate that it is Healthy.
If this doesn't work then it is faulty.
www.artplus.hr/adapps/eng/dpr.htm
www.CardRecovery.com
hope it will help you
Apr 25, 2011 | Computers & Internet
Usb pulled out during use now not working
Sometimes when a flash memory stick or USB hard drive fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory or USB external hard drive device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
You need to format the external drive. Format the drive as primary drive and in FAT32. (FAT32 will allow data to be exchanged between MACs and PCs).
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Nov 27, 2009 | Western Digital My Book (WDG1U2500)...
I bought one pny pen drive of 2 GB after 4-5 mouths it gout courapted an when I try to explore/open and fromet a mesage is displyed by windows thati please insert disk drive in H:
Sometimes when a flash memory stick fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Nov 14, 2009 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
No access to USB drive when inserted (Windows). ''Malfunction'' error message.
Oct 30, 2009 | SanDisk 1GB Cruzer Titanium USB Flash...
When connected by USB cable removable hard disk does not appear in Windos Explorer. However, on other peoples PCs, the disk is visible.
your computer is probably naming it F: or something, but your PC already has a device issued to that letter.
Right-click on 'My Computer', it will open a 'Computer Management' window. On the left side, under 'Storage'.. click on 'Disk Management'. It will show some devices like your c: drive and d: drive.. does it recognize your removable hard drive?... if it does then right-click on it and choose 'Change Drive Letter'. CLick on the 'Change' button and change the drive letter to Q or X or something ...then apply it close the windows... then open Windows Explorer and see if you see your removable hard drive now.
good luck.
Sep 15, 2009 | Electronics - Others
Drive No Longer Appears as an Available/Accessible Drive
goto disk management - right click and choose assign/change drive letter
Mar 18, 2009 | Electronics - Others
Computers & Internet Logo
79 people viewed this question
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
