Question about Flotec Plumbing
I need a wiring diagram for flotec model C48C23A03
I need a wiring diagram that shows how to convert a 230 / 115 volt 3/4 HP Flotec Jet Pump model # C48C23A03 from 230 volts to 115 volts.
Why isn't my pump pumping any water
Flotec FP4012-10 1/2 HP Shallow Well Pump Jet ...
www.amazon-associate.com/Flotec-FP4012-10...Well.../B0002YXB14?...
Find helpful customer reviews and review ratings for Flotec FP4012-10 1/2 HP ... After realizing the failure was due to a high amount of sediment in my well I ...
Aug 30, 2015 | Flotec Pump FP4022-10
I hAVE REPLACED MY 1/2 WATER PUMP FROM MADE FROM GE WITH A FLOTEC 3/4 JET PUMP AN DNOW i AM HAVING PROBLEM WITH THE MOTOR. PUMP DOES NOT START, SOUND A MUMMM SOUND. WHAT IS WRONG WITH THIS PUMP?
Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? have you tested the power?
Jul 27, 2014 | Flotec 3/4 HP Deep-Well Convertible Jet...
STORES THAT SELL FLOTEC 1/3 HP MODEL NO. FPSC2200A-08 115 VOLT 60 HZ 9AMP SUBMERSIBLE PUMPS
Your best bet is to get off this site, go to Google or Yahoo or any other search engine and type in "Flotec Pumps" and you will get several thousand places to shop.
Aug 03, 2012 | Flotec Plumbing
I have a 3/4 hp Flotec 4022 pump. Prior to that I had a goulds 1 hp pump on the same 120 circuit with no issues. The Goulds pump housing started to go so I replaced it. Since replacing it with the Flotec I...
Hi Eglenni,
Here are the specs for your pump:
Thermoplastic Shallow Well Jet Pump 3/4 HP. This new revision of an "old hand" provides good pressure pumping from wells where the depth-to-water is 25' or less.
BODY CONSTRUCTION: Thermoplastic
HORSEPOWER: 3/4
MAXIMUM CAPACITY: 12 GPM
FLOW at 10' LIFT and 40 PSI: 9.7 GPM
MAX LIFT: 25'
MAXIMUM PRESSURE: 78 psi
PRESSURE SWITCH SETTING: 30/50
SUCTION PIPE SIZE: 1-1/4" NPT
DISCHARGE PIPE SIZE: 1" NPT
AMP DRAW (full load): 6.1 amps on 230v / 12.2 amps on 115v
VOLTAGE: 230v / 115v, 60 Hz
RECOMMENDED BREAKER: 15 amp on 230v / 20 amp on 115v
MAXIMUM WATER TEMPERATURE: 140 °F (60 °C)
Note that this pump can be operated at 115 volts or 230 volts (A/C) It may have come wired for 230 volt use from the vendor.
Make sure the pump is piped correctly.
There should be a wiring diagram either on the pump or in the literature so you can check to see how the pump is wired.
MAKE SURE
you have the pump wired for 115 volt use in your case. Also make sure the wire size is #12 awg for the power wiring.
Make sure all connections are tight. If you have an amprobe (an instrument that measures electric current) you can check to see how many amps the pump is pulling when it runs.
You said your old pump was 1 HP. This Flotec pump is 3/4 horse so there could be some pump performance loss depending on the well depth and length of the piping runs.
Here's the link to the website for the pump. There are additional resources available on the website:
Thermoplastic Shallow Well Jet Pump 3 4 HP
Jul 05, 2017 | Northern Tool Electrical Supplies
I have a Flotec 1/2 hp jet pump. Is it posible to get just the pump housing. Mine froze cracked the housing?
Use Google and put in Flotec parts.
I did that and several parts dealers came up.
Pick one and put in your model number.
I'm sure you can find a housing, the pump that I looked at had one available.
Gary
Jan 29, 2011 | Flotec 1/2hp Cyclone Pump
I got a brand new Flotec 2 HP Jet pump and installed it but now it is overheating and smoke is coming out. Why is this happening and how can I fix it?
WAS YOUR NEW PUMP DUAL VOLTAGE? AS IN 115VOLT OR 220VOLT. IS IT WIRED FOR THE CORRECT VOLTAGE? NEED MORE INFO IF THIS DOESNT FIX. HOPE THIS HELPS. JODY
Aug 31, 2009 | Flotec Corrosion Resistant Shallow Well...
3/4 pump -is pumping water - but a a slow pace
Re prime the pump. Make sure the suction line is completly flooded so it will take a good suction from the well.
May 18, 2009 | Flotec Corrosion Resistant Shallow Well...
Schematic for wiring in a Flotec Pump
Remove end casing of Flotec motor housing they have a 115v/220v switch, turn to 220v, see website flowtec water. Flotec parts 1-800-365-6832
Jan 31, 2009 | Flotec Corrosion Resistant Shallow Well...
Plumbing Logo
121 people viewed this question
Top Flotec Plumbing Experts
john h
Andrew Bugbee
Are you a Flotec Plumbing Expert? Answer questions, earn points and help others
