Question about Garmin Nuvi 760 Handheld GPS Receiver
Garmin nuvi 760 car gps problem
Did you figure out what the problem was with your garmin nuvi? I have the 760 and it turns on but shuts off after "loading maps" msg. I've plugged it into my computer and at first got the Gramin logo with USB connect icon but now it's just a black screen. I tried resetting too. Any advice before I send it back to the mfg.?
  • Hyteq Redneq Feb 10, 2009
    I have a similar problem. My 760 is 11 months old and has recently started freezing on the 'loading maps' screen when first turned on. It works fine after I turn it off and on. Yesterday though it would not power up at all, not through the cradle and not through the USB on my computer. I figured it was done for but this morning I threw it in the cradle just so it wasn't bouncing around in my truck and it came on, once again freezing on the 'map loading' screen. Turned it off and it took a couple tries to get it to come back on but then it worked fine all day.
SOURCE: NUVI 250w Show Black Screen with ICON of Computer and NUVI
I had this problem. I discovered that I was using the wrong lead in the car. The problem resolved itself when I used the lead that came with it.
Posted on Jun 10, 2008
SOURCE: installing free maps
thanks
Posted on Jul 02, 2008
marcelbakker
  • 174 Answers
SOURCE: deleted maps on my garmin gps nuvi 255w now what???
Wasn't there a dvd with the product?
Posted on Jul 23, 2008
SOURCE: Garmin Nuvi 760
Sounds like you both have a battery problem. I experienced a similar problem when trying to charge via the USB-cable connected to my computer.
Ended up buying an original charger (expensive) and the charging went smooth.
The car charger should in any case work fine, so probably your battery is not very healthy.
Try holding your finger on the battery symbol for about 10 sec. The unit will then switch to a technical page. There you can observe the battery and charging voltage. When I plug in my computer USB-cable, I read around 4,4V and that is not sufficient for charging my battery.
When connected to the original charger, this voltage rises to about 5V which gives a nice charge. When unplugging charger, the unit displays the battery capacity. If the charging voltage is OK, but battery capacity drops quickly after you unplug charger cable, the battery is probably bad. (Of course you have to charge is for some time) I think around 4V battery voltage give 100% capacity. 3,9V gives about 90% capacity.
This will not solve your problem, but can give you an idea about what is wrong.
Good luck.
Posted on Nov 17, 2008
SOURCE: My Garmin Nuvi 255w Car Gps
You must call Garmin at 1-800-800-1020 they will walk you through plugging in nuvi to your computer (must have usb cord) and it will upload then go to my computer and choose garmin drive then click garmin folder and either find the folder they say or make new one like I did with the guy on the phone and put in code. The only information needed is the numbers on the bottom of the device.... super fast fix!
Posted on Mar 12, 2009
Garmin nuvi 760 map update free download
Garmin Express Garmin Express but it probably won't be free. $50 for one time or $90 for lifetime... dont get the lifetime, get a new unit instead.
Jul 29, 2014 | Garmin Nuvi 760 Car GPS Receiver
Garmin nuvi 760 charging problem
The wire may be defective, especially where it plugs into the connectors.
Nov 25, 2013 | Garmin Nuvi 760 Car GPS Receiver
Is it possible to get inland waterway maps (IRELAND)to suit nuvi
GPS City (http://www.gpscity.ca ) sells compatible Inland lake maps. Please note Garmin does not recommend them for that unit but I am sitting at my desk with one in my Nuvi 760 and it is working fine. You will need to turn off the street maps first to see the inland lake maps. I tested it with a Garmin Pre-programmed card for Alberta Canada.
Jul 12, 2010 | Garmin Nuvi 760 Car GPS Receiver
I turn on my nuvi 760. It begins tio startup. Begins to look for maps. Then it shuts down. Now what? Thanks!
i suspect it cannot find the right files to run the maps or that the battery is not properly charged
most likely the latter
Aug 12, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
Late response on turn-by-turn voice directions- garmin nuvi 760
Hi, my 760 had the same problem, and a stutter when speaking street names. I fixed both by upgrading the software to v4.60 using the Garmin Webupdater.
Dec 24, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
Garmin 760 - No Voice Directions
Go back into your tools and settings and re select the voice of american jack and see if it comes back on.
I lost the voice 2 days ago while on a trip from tenn. to florida and this fixed it. we never shut off the voice but somehow while using bluetooth or FM trans it shut off voice transmiting.
Dec 14, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
Garmin Nuvi 760 Handheld GPS Receiver Logo
66 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
