Our Samsung 23" has packed up.the picture and screen has nothing on it.the electric is getting through as the on/off light is illuminated.The remote causes the light to flicker but nothing happens.(no
    Top Expert:
  • Televison & ... Master
  • 74,243 Answers
The main digital board has the fault. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1000 posts to different brand TVs now. Pull up older posts there.
Posted on Oct 27, 2012
4 Suggested Answers
Shuttle83
  • 1139 Answers
SOURCE: No Video, No Sound
Hello, This might be a board with a loose connection or a faulty capacitor on the power board or one of the immediate circuits attached to the power supply board. I would suggest that you have this serviced by a qualified TV Technician. However if you wish to do this yourself, you need the following equipment: 1) Multimeter (to measure the voltages; AC and DC on the various test points on the boards) 2) Oscilloscope (to measure the startup and shutdown circuit ramp voltages) 3) Isolation Transformer (to isolate the Tv from the AC circuit that the test equipment is on) 4) Service manual or schematic diagram (to show where the test points are and what signals and voltages to expect) 5) Signal generator (to generate reference signals for servicing the TV) Now if you know how to use these pieces of equipment your are ready to start, if not again I would advise you to have the set checked by a qualified TV repair technician. I hope this helps Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
Posted on Jun 10, 2009
  • 1779 Answers
SOURCE: Hi, Same Model Samsung
I hope you looked for any bulged capacitors on the power supply? If so then you must now check with the set plugged in find the 5V standby which will be labeled by the appropriate plug. If that is present then you have to look for the PO. when you've located that, with your probe on that pin, press the power button and see if it goes HIGH , usually between 3.8 and 5v. If that does not come up then appears you have a bad main board. You can also disconnect the plug going to the inverter board an see if the PO stays up, if it does you have a bad inverter. The only thing that is puzzling is that you had back light before. If you do all these things the last resort is your lcd display panel is bad the set is ready for the rectangular file.
Posted on Dec 08, 2010
SOURCE: Screen is black even though the green light is lit
sound like you have some bad capacitors inside your tv take the back off and check them if capacitors are raised up on top they are bad
Posted on Sep 02, 2012
How to fix Samsung HL72A650C1FXZA DLP TV with no sound, no picture, bright screen with lamp light flashing?
Check the bulb ballast board. It's the board that the wires from the bulb connect to. That is most likely causing the Sounds like the main board is the culprit for most of the problem. The picture problem can be the color wheel not turning. The lenses in front of the bulb should be taken out and cleaned too.
Oct 12, 2016 | Samsung Televison & Video
Indication Light On, Black Screen, Unresponsive
I happened the same problem and the solution must change the power pack
Jan 25, 2014 | LG M2362D 23 in. LCD TV
Samsung HDTV black screen no picture no sound
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Mar 12, 2017 | Televison & Video
Samsung HDTV no picture no sound
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 13, 2014 | Samsung UN22D5000NFXZA 22 In Led Hdtv...
Turn tv on. green light solid display, no picture or sound
The flashing green light is likely indicative of a self-test failure, indicating the TV has detected some sort of internal fault. With no picture or sound, one strong suspect is the power supply. Flat-panel TV's have an internal DC power supply that converts the inbound AC current, and when these fail, or are unable to supply a minimum level of power to the set, it can behave as you describe, providing only enough power for the green light to illuminate.
Jul 28, 2012 | LG 50PG60UD 50 in. HD-Ready Plasma TV
Screen is illuminated black with no picture.
Same problem with another samsung. Anyone have any ideas?? Please.
Jul 18, 2010 | Samsung Televison & Video
Electric Radiator Fan Does Not Come On
Chevy dealer says will not come on until temperature reaches 219 f
May 16, 2010 | 2007 Chevrolet Silverado 1500 2WD
Red light on power button flashes, but no picture....blank screen
I would suspect a problem in either the backlight assembly, or the power supply that drives it. If it's the power supply, the part may be over $100.
Jan 18, 2007 | Samsung LNR238W 23 in. LCD Television
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
