Question about SAMTRON 55V 15" CRT Monitor
Samsum samtron crt 56 v monitor ,got a green shade on picture,but looks good at times
Degaussing is the process of decreasing or eliminating an unwanted magnetic field. Due to magnetic hysteresis, it is generally not possible to reduce a magnetic field completely to zero, so degaussing typically induces a very small "known" field referred to as bias.
If you do not have or can not find the degauss function:
Monitors without a degauss function can be degaussed by placing a degauss-enabled monitor face-to-face with the target monitor. Activating the degauss function on the enabled monitor can help degauss the other.
Degaussing may also be accomplished by placing an electric device with a motor in it (fan, drill, pencil sharpener, etc...) near the center of the display while the display is on and turning on your electric device. The screen will distort. Slowly move the device away from the display until distortion dissipates and discoloration is gone.
Degaussing can also help reduce the distortion due to static electricity that often results from long-term usage of the monitor, especially in older monitors
Good Luck.
Posted on Jan 03, 2009
    Scholar:
  • 86 Answers
That has been damaged by some magnetic device.
Solution: You need to degauze it. (Refer to manual for specific degauze instructions)
I am a technician.My Samtron 56 V moniter dead. Some time switch on when power is connected after 10to15 minutes. Please give a solution.
If you have Samtron 56 V monitor that sometimes switch ON for 10 to 15 minutes, then it is a signal of some internal device fault which needs to be rectified from certified hardware technician from monitor manufacturer service center itself. It is recommended to directly contact Samtron for hardware replacement if it is under warranty or ask to repair it.
GuruAid.com
Jun 24, 2016 | Samtron Computers & Internet
I have a samtron 77v the screen will not go on but the green light keeps blinking, what can i do?
I would go to the web site or talk to the Manufacture tech support and they will tell you if your monitor is bad. If the monitor is good I would look for the graphic card gone bad on you..
Mar 25, 2012 | SAMTRON 77V 17" CRT Monitor
Hi, I have a samsung samtron 55V 15 inch monitor. The problem is it is not displaying the actual colors. The red color appears as a greenish/bluish shade. Ex: The Windows Start button is showing as light...
You have to check for dry soldering in the base board of you mointor. The base board is on which is attached to the picture tube neck. In most cases there will be dry soldering in the pins of cathode diver ic in that base board. It will be difficult find out which pin have the dry soldering. Do on thing resolder all the pins of that ic. This ic cotrols the three cathodes of picture tube (red, blue, and geen) is any one did not get the correct drive that color will fail to display. In your case the red cathode is not getting the drive voltage. Thats why it shows only gree and blue. This is a reular complait for crt monitors.
ok
Jul 17, 2011 | SAMTRON 55V 15" CRT Monitor
I have a Samtron 98BDF crt monitor that has a focusing problem. I notice the more I turn down the contrast, the image will eventually get sharper. If I turn the contrast up the image will eventually get...
I have a Samsung Samtron 97BDF and i have problems with the information cable, so i need to change it, how can i do? Maybe someone have pictures about how to make..
Sep 14, 2010 | SAMTRON 98BDF 19 in.CRT Conventional...
BLUE screen problem(monitor)
It is the picture picture board on your monitor that is malfunctioning, since the power led or button is on, but blue shaded screen, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Apr 26, 2010 | SAMTRON 55V 15" CRT Monitor
Samsung samtron monitor does not work
Please check whether the power cable is properly inserted...
The power button of this model fails with time.You need 2 press it tightly and hold it till the LED is on....
try this...
Hope this helped...
Dec 21, 2009 | SAMTRON 55V 15" CRT Monitor
Dead, flyback was short.
It is probably worth purchasing a new monitor -- I have two spare CRT monitors 17" if you are interested.. collection only...
I live in Croydon- london
Jan 06, 2009 | SAMTRON 55V 15" CRT Monitor
Monitor display in blue shade
It may be due to the loose contact of the monitor signal cable
Contact the nearest Repairman
Let me know that your problem is solved and rate me as Fixya!
May 27, 2008 | SAMTRON 55V 15" CRT Monitor
SAMTRON 55V 15" CRT Monitor Logo
191 people viewed this question
Top Samtron Computers & Internet Experts
Daniel Sweetlin
Daniel Sweetlin
Level 1 Expert
Richard Lilja
Richard Lilja
William Miller
William Miller
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
