Question about Coleman Powermate Premium Plus 6250W Portable Generator
Why is there only power coming out of one side of the 30 amp outlet not both
    Prodigy:
    An expert who has answered 500 questions.
  • Coleman Expert
  • 573 Answers
Check that you have power on the generator side of the circuit breaker, check each leg to neutral and you shoudl see 120V approx. If you still only see it on one side you have a bad stator. if you see it on both legs measure across them L1 L2 and you should have 240V, then check again on the receptacle side of the breaker, if you don't have it you need a new breaker
Posted on Nov 15, 2013
Power outlets suddenly stopped working
Did you check 30 amp power outlet fuse? Also, check the power outlet relay, the fuse won't go hot unless the relay is energized.
Apr 10, 2016 | 2006 Kia Sorento
1993 buick 12volt DC power outlet amp rating
it depends on what fuse is used 5 to 30 amps, factory outlets are normally 20 to 25 amps
Jul 06, 2014 | 1993 Buick Park Avenue
1998 komfort 5th wheel electical problem
i am not certin that i have ever encountered a situation that has 2 outside power input plugs, the situation is that your trailer is wired for a 50 amp service, this service has a plug that has 4 connection points and is set up for a 220 volt supply, the only reason for this situation is that some one modified the power input to your trailer , the solution is to eliminate one of the 30 amp power supply connections and in the fuse panel bridge the 2 hot side supply rails, or better yet restore the power connection to the 50 amp service cable and purchase a 50 amp to 30 amp power adapter cable
Apr 05, 2012 | Cars & Trucks
I have a Kenmore 795.5881 side by side refrigerator and I came home this afternoon and it has lost all power, no lights or anything. No breakers had tripped and the receptacle will power other items.
i had same problem, no compressor no lights nothing. power was good at outlet. took cover off top of unit. noticed a blown glass 15 amp fuse. cost less than 30 cents to fix
Sep 05, 2011 | Kenmore 59962 / 59964 / 59969 (25.5 cu....
Need hook up diargam for 240 volt 30 amp washer dryer residential xyo-gnd recepticals.now for free .like your web site said. or i will presume this is just a scam trying to lure people in for some...
Hi Watsonelecco!
No scams here... most of us on FixYa are like me.... we enjoy helping people out with their everyday problems. I work nights and do this as a hobby... I used to teach advanced electronics and Radar for the US Navy.
It is difficult for me to give you a diagram for "xyo-gnd" since the term is not familiar to me, even though I worked as an industrial field service engineer. My guess is that you need to connect your washer/dryer to your electrical outlet.
First thing.... I need to know where you are located, and what type of power service you have coming into your home. Most US homes are wired for 115 Volts and require a separate input for 230 volt appliances. Most European, Australian, and Asian homes are wired for 230 volts and connecting your washer/dryer will be simpler, but still require some work.
The first thing we will need to know is how the power comes into your home and how it is distributed. Look at your circuit breaker panel. You will have a mains coming in that feeds a 2 pole "main" breaker- it will be rated at between 100 and 300 AMPS in most homes.
Next... the other breakers in the panel.... how many are "2 pole" breakers (what looks like 2 switches connected together) and how many are single pole? Only a 2 pole breaker can supply power for your washer/dryer.
Now, you need to determine which of the two pole breakers are rated high enough for 30 amp service. If none say 30 amps or higher, you will need to install a new breaker and run a 10/3 AWG type UF cable to where you are installing the washer/dryer. Find a recepticle that matches your washer/dryer plugs, and install it with the black wire to the brass lug, the white wire to the silver one, and the green wire to the green lug.
Once you have the wiring done, you will be good to go!
If you already have a dual breaker rated at 30 amps supplying an outlet where you are installing the washer/dryer, match up the plugs/outlets the same way... black wire to brass, white to silver, green to ground. You may have to purchase either the correct outlet, or (more likely) the correct plug, since most units do not ship with power cords.
Apr 07, 2011 | Microwave Ovens
I'm wanting to install a combination outlet/switch device. Both will work off the same circuit but be independent of each other. I want the light to work from the switch, with the outlet constantly hot. ...
How many sets of wires are coming into the box?
If the box is in the middle of the circuit you will have a power-source black & white wire coming in and a power-source black & white wire going out. And in this case for the switch - there must be a black and a white wire going to a light.
Typically with a switch/outlet combination all the white wires will splice together with a white pig-tail wire to feed the neutral side of the device. The two black wires from the power-source will splice together with a black pig-tail and feed the hot-side of the device. The black wire going to the light will go on one side of the switch.
Looking at outlet/switch device from the front the large slot side of the outlet will be the neutral side and the smaller outlet slot will be the hot side. The neutral side screws will be steel colored and the hot side screws will be brass colored. The white wires will go to the neutral side steel colored screws, and the black wires will go on the hot side brass colored screws on the outlet.
The black wire comig into the box from the light is called a switchleg and goes to a brass screw on one side of the switch. The brass screw on the otherside of the switch will be for the black wire coming from the power-source.
Hope this helps - and please:
TURN THE BREAKER OFF BEFORE YOU START WORKING WITH THE WIRES!
Mar 16, 2011 | Cooper Wiring Devices Combination Switch &...
All of the power outlets have stopped working, but the cigarette lighter is still working. Do I need to replace some fuses or replace the outlets? The lights on the right side of the steering wheel are...
The poser outlets have a 20 or 30 amp fuse for them. You will prbably find them in you Power Distribution box under the hood. As for the steering wheel lights, could bee a loose plug in..
Feb 02, 2010 | GMC Yukon XL Cars & Trucks
Refrigerator no power
Plug some other device into these same outlets or use a volt meter to verify power at the outlet.
You definitely have a house wire problem if the interior light does not come on and the bulb is good.
Also check 120 volts power at the fridge cord where it attaches to the terminal box.
Feb 21, 2009 | GE PSS26SHRSS Side by Side Refrigerator
I replaced a fuse but still have no power.
I QUESTION FIRST THE 30 AMP FUSE , FUSES SHOULD BE SIZED TO THE WIRE IN THE CIRCUIT AS FOLLOWS , # 12 -20 AMP FUSE , # 14 -15 AMP FUSE AND # 10 @ 30 AMP FUSE OUTLETS ARE USUALLY # 14 OR # 12 AND SHOULD BE FUSED ACCORDINGLY , ------ NOW TO GET TO THE ORIGINAL QUESTION AS TO THE PROBLEM , MOST POWER DUPLEX OUTLETS ( WHICH IS THE KIND WITH A PLACE TO PLUG 2 DEVICES HAVE WHAT IS REFERRED TO AS A BRIDGE BAR THIS IS ON THE SIDE OF THE OUTLET CONNECTS FROM THE TOP SCREW TERMINAL TO THE BOTTOM SCREW TERMINAL THIS IS ON THERE FOR THE SPLITTING OF A CIRCUIT SO SAY IN A LIVING ROOM YOU WISH TO SWITCH THE BOTTOM FOR A LAMP AND YOU WANT THE TOP TO STAY HOT ALWAYS TO ALLOW YOU TO PLUG IN SOMETHING THAT YOU WISH TO STAY HOT ALL OF THE TIME AND NOT BE SWITCHED , THIS IS ON THE SIDE OF THE OUTLET AND IF I WANT TO SPLIT I WOULD SIMPLY BREAK THIS INTO USING NEEDLE NOSE PLIERS ******-- PROBLEM THESE BARS ARE ONLY GOOD FOR 15 AMPS AND CAN BURN INTO UNDER THE LOAD YOU DESCRIBE REMOVE OUTLET AND HAVE A LOOK HERE FIRST IF THIS IS CASE REMOVE AND REPLACE ( BE SURE TO MAKE DIAGRAM OF WHICH WIRES CONNECT WHERE AND ALWAYS KILL POWER BEFORE WORKING ON ELECTRICAL CIRCUITS )
Jan 13, 2009 | Electrical Supplies
Wireing an a/c plug to a samsung DV316LES dryer I have Black, White, and Red wires coming out of the dryer. the plug I purchased came with Black, White, and Solid Green wires. I am sure it goes color to...
unless you have an a/c outlet close to your dryer the you wont be able to use an a/c cord. also the cord for an a/c i usually rated for 20 amps and your dryer needs to have a 30 amp circuit.
i would not suggest using this cord as it will overheat and probably cause a fire in your house.
if you think the cord can handle 30 amps, then you need to make sure you hook up red and black to the power sides, white to the neutral and green to ground.
seriously, just go back and get a dryer cord that will match the outlet that is close to your dryer.
draw a picture of what the outlet looks like, ie: the position and angle of the plug slots and go back to the hardware store and find the right cord.
it will work properly and be safe to use.
Jan 07, 2009 | Dryers
Coleman Powermate Premium Plus 6250W Portable Generator Logo
69 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
