Md 98300 black screen
The screen is not turning on. When I turn on I can hear the fans working. what would be the problem and how to solve it. Thanks for your help
gandhiforyou
  • 275 Answers
SOURCE: Sound
i think you need to uninstall the sound driver and download lastest sound driver for your sound card from your laptop manufacturer website. check this website:-> www.medion.com
Posted on Jun 20, 2008
Geekman
  • 32281 Answers
SOURCE: black screen when I turn on my computer
Defective CCFL backlight may has the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on Apr 03, 2009
  • 700 Answers
SOURCE: IBM thinkpad T40,fan turns on but screen stays
Go to youtube.com then type on its search bar " installing ram module " or something about ram or memory placement for videos and step by step procedure. If desktop add desktop word in the search bar or laptop if you have laptop unit.
Goodluck
Posted on Jul 10, 2009
SOURCE: My computer screen is black
Ummm did you even read the problem? It is an Acer one notebook... your solution is assuming that it is a desktop or using an external monitor which the complain clearly isn't.
Posted on Nov 01, 2009
SOURCE: my fujitsu siemens amilo notebook screen black.
Check num lock key of laptop press num lock if numlock key is on and off when you press it then dispaly working fine only issue with screen resolution .
For that when you power up the computer press F8 key then enter in enable vga mode.
Then go to start menu ->control panel->display->settings.
Change screen resolution to 1024*768 then apply and ok.
But if num lock is constant when you press numlock key then you need to refix RAM memory.Open back cover of laptop then refix RAM memory.
Then check if still same issue then pull cmos cell from motherboard then check again if still same then try with another RAM .
When you power up the computer press F1 or F2 or "del" key if you are able to see bios screen then you not need to open back cover of laptop only make sure SATA is disabled and your harddrive is detected in bios.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on Dec 19, 2009
Hi, I have the Medion LCD-TV model MD 30058 40inch. I cant get a clear picture anymore, there are popping up lines, like there are bad signals. Sometimes the screen goes totally black, and I have to turn...
Medion LCD-TV model MD 30058 40inch is a "troublemaker", the problem you descibe Trond Larsen can probably be solve by replacing a capacitor on the CPU board, costing only NOK10,-
Are you placed in Norway?
Oct 16, 2010 | Medion MD 30262 32 in. LCD TV
Computer shuts off
it may be a deadly virus that has infected ur OS!!
try reinstalling the OS!!!
if it does not work again try reinserting the RAM
Mar 03, 2010 | Medion MD 1804 (MD 1804 / MD 7315) PC...
Puk code for samsung e1410 .i mistakenly entered pin code for my fone thrice and am unable to find my puk code anywhere 1i have vodafone connection.(state kolkata,India)Help PLZ
PUK refers to Personal Unblocking Key. This is a Code which is offered only by Service Provider. There is NO charge. Call up Vodafone and ask for the same and they would be glad to offer that.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 19, 2009 | Samsung Cell Phones
My screen shows black you can hear the computer
The fault sounds like a invert problem, the inverter supplies high voltage to the CCFL lamp which provides the backlight or a faulty CCFL lamp. If you see a dim image when you look at the LCD screen at a sharp angle then this confirms this diagnostics.
For parts, service and DIY info I have use LCD Parts - click on this link to their WEB site :-
www.lcdparts.net
Sep 22, 2009 | Medion MD 7317 17" Flat Panel LCD Monitor
Sound
Jun 18, 2008 | Medion MD-40954 Notebook
MD or power supply?
if the power supply fan is working when you turn on the pc ,it probably is not the power supply,
and is most likely a motherboard problem ,if you have the ability to install another video card that you have (or a friend may have), this may solve your problem.
i am not sure what you mean when you say "my system unit automatically turn on after i turn on my AVR "
good luck
Terry
Mar 10, 2008 | Asrock 775i65GV Motherboard
Medion MD-96032
Are you able to see the screen as if just the back lighting is turned off?
Nov 12, 2007 | Medion MD-40954 Notebook
SCREEN GOES BLACK AFTER 1 MINUTE
In electronics dust has nothing to do. cleaning will not solve your problem your problem is due to trouble in vertical section. mostly it is due to electrolytic capacitor in vertical section is defective.it is common problem. also check supply to vertical section. "THE SCREEN SHRINKS TOWARDS THE TOP OF THE SCREEN FOR A FEW SECONDS BEFORE THE PICTURE TURNS UPSIDEDOWN THEN TURNS BLACK." is called fold over. regards thanks
Sep 12, 2007 | Sony KV-32S42 32" TV
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
