Question about Samsung LN-T4665F 46 in. LCD Television
Replace Power Board for LNT4016F/XXA Samsung LCD TV?
  • 718 Answers
SOURCE: how hard it is to replace by yourself main board Samsung LN-T4065
You need to do some more diagnosing of the problem. If you get sound and change channels take a bright flashlight and place it again the screen. Look for an image around the edge of the flashlight.
If you see an image that means the LCD controller board (TCON) is probably good.
The problem is probably one of three causes;
1) Inverter board is bad
2) CCFT (cold cathode fluorescent light) are bad.
3) Power to the inverter board is bad. You can also check the connectors.
Posted on Mar 30, 2009
  • 44 Answers
SOURCE: samsung ltn1565x/xxa
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Posted on Jun 25, 2009
  • 927 Answers
SOURCE: Which Replacement Power Board for LNT4665F Samsung LCD TV?
Howdy,
It would be a lot cheaper if you just replace the two caps that have gone bad. Just get a cheap solder pencil from the store and about an inch of solder and you are in business.
The Power Supply Board is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Thaks for using FIXYA, BIG IRISH.
Posted on Jan 02, 2010
  • 8457 Answers
SOURCE: I am looking for A repair manual for a samsung LCD tv LNT5265f
No need for manual or will find one because the tv corporation don't release them.Go to Shopjimmy.com,Ebay.com.Type in tv model Samsung LNT5265F power supply board and compair picture to ur tv power supply board.Ask questions to sellers.Buy it,and replace it.
Posted on Mar 05, 2010
Testimonial: "I ordered the part installed it. It worked problem solved thank you very much."
  • 304 Answers
SOURCE: Samsung TV now takes over 30min to come on
There are a number of Capacitors on the IP/Power supply bd and they have gone bad. Replaced them with the proper Capacitance as the old ones are BUT get the 35 volt Caps. Going from 10v to 35v will fix this problem.
Posted on Apr 16, 2010
Samsung LCD 1080 flat screen tv model LNT4661FX/XXA clicks before taking 30 seconds to turn on.
Delay in turning on in flat panel TVs is mostly caused by weak and defective electrolytic capacitors in the power supply board. Most of the times they are easily recognized by their bulged top. Some times one has to hunt for them. If one can do it, it is a simple job. Good luck to you.
Dec 29, 2013 | Samsung LN-S4041D 40 in. LCD HDTV
My Samsung dlp hlr5667wx/xxa has a signal intermittent problem through antenna connection and hdmi connection. what could this be? the light bulb and color wheel has been replaced 6 months ago. the...
Bad smd capacitors on the digital board. There are many and unlike regular capacitors are small and hard to replace. May just want to get a whole new digital board. Try Encompas parts.
Nov 04, 2011 | Samsung DLP HL-P5663W 56" TV
Samsung LCD TV
hi,
your lcd ip board (power board) capacitor had already exhusted.
got to replace the ip board.
Feb 28, 2010 | Samsung LNT5265F 52 in. LCD HDTV
Howdy,
Dec 30, 2009 | Samsung LN-T4665F 46 in. LCD Television
Tv doesn`t start
Howdy,
It sounds like you have a Power Supply Board problem. The PSB is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM811, CM812, CM817 & CS806; 1000ufd 25volts. The board on left, you will see the cap tops are swollen.
Thanks for using FIXYA, BIG IRISH.
Jun 03, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Power Supply Board for SAMSUNG 40" LCD TV Model LA40R81BX
You'll find some Samsung power supply boards here : http://www.usefulparts.com/index.php?main_page=index&manufacturers_id=11&sort=20a&filter_id=98&alpha_filter_id=0
but you have to open your TV first and find out model number
Apr 02, 2009 | Vizio L32 32 in. LCD HDTV
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Samsung no picture
There are several capacitors that are known, in Samsung TV's that go out.. ( I replaced mine until the board was burnt through.. bought a new board, they went out again.. BOUGHT A LG TV!!)
Samsung settlement warrants older TVs with faulty capacitors
Samsung LCD Plasma TV Capacitor Repair Kit Replacement Parts
replacing these is not hard at all.. if you can use a soldering iron, you can do it..it just takes time..
Repair Samsung LCD TV Relay Clicks Shuts Off Won Come On
WATCH THESE VIDEOS FIRST.
Samsung TV Won Turn On How to Repair Bulging Capacitor for Clicking Noise
My Repair of 46 Samsung LCD TV with Bad Capacitors
Jul 18, 2017 | Samsung - Projection TV replacement lamp...
Black/Dark Colors Fuzzy w/Red Pixel Outline
Sorry, I haven't been on here for a while.
I haven't found the cause. I find that leaving it switched on overnight cures it.
Feb 18, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Samsung LN-T4665F 46 in. LCD Television Logo
43 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
