Question about Maytag MZD2665HE Side by Side Refrigerator
How to replace condensor relay Maytag refrigerator MZD2665HES
2 Suggested Answers
  • 67 Answers
SOURCE: blade falling off condensor fan motor in Maytag refrigerator
When you replacd the motor if you used the factory stamped sheetmetal nut, you will have this situation, rplace the factory sheetmetal nut with a 1/4-20 standard nut and loctite on the threads and this will solve your problem.
Posted on Oct 31, 2009
My refrigerator no working
1 REFRIGERATOR IS IN DEFROST. THE DEFROST CYCLE LASTING 30 MINUTES
2 CHECK CONDENSOR FAN AND EVAPOR FAN
3 CHECK CONDENSOR COIL CLEAN
4 CHECK COMPRESSOR FEEL IT WORK, IF NOT WORK. REPLACE RELAY
GOOD LUCK
Jan 12, 2011 | Kenmore 53642 / 53644 Side by Side...
Freezer works fine air is circulating and temp. is zero degrees refer side is 60 degrees and air does not seem to be circulating. Settings are set on 4 as they have been for five years Do I have to...
Check to see if your hear your evaporator fan is running in your freezer, then check behind the refrigerator and see if your condensor fan is running. Make sure your condensor coils are clean under your fridge. Your symptoms are leaning towards dirty condensor coils. Good luck!
Aug 19, 2010 | Maytag 25.6 cu. ft. Wide-By-Side...
Maytag side by side issue: Refrig works normal. However the freezer defrosted itself, food is thawed. I'd like to repair myself, what's your recommendation i.e. troubleshoot, what to look for prior to...
Pull the refrig out , and remove the back panel . Is the compressor running ? Is it hot ? Is the fan cooling the compressor , running ? If the compressor is not running , the piece on the side , with 2 or 3 wires going to it , is bad . If the fan is not running , replace the fan motor . The part number for the compressor piece ( overload/relay kit ) is 12002784 . It is easily replaceable . If the compressor is running , check the square black coil box ( condensor coil ) , to make sure it is clean . Is clean , check the fan in the freezer , to make sure it is working .
Nov 22, 2009 | Maytag MSD2454G Side by Side Refrigerator
Blade falling off condensor fan motor in Maytag refrigerator
Oct 31, 2009 | Maytag MSD2756G Side by Side Refrigerator
Condensor getting power but not running
Bad overload/relay (part plugged onto the compressor ) Remove and make sure there is contunity between all 3 compressor terminals . See if there is continuity between the terminals and the copper tubing ( indicates a bad compressor ) . If all checks ok , then replace the o/relay .
Jul 19, 2009 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Not cooling fan is working
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
sdfhgfs
Jun 03, 2009 | Maytag MZD2766GES Side by Side...
Frig stopped cooling. Bad condensor Fan Motor.
sounds like a bad thermostat,that tells unit when to kick on and off.
May 15, 2009 | Maytag Refrigerator Light Switch -...
Maytag Refigerator Condensor Fan not Running
yes it is your getting proper voltage, fan simply went bad, center mullkion was the unit trying to disperse the heat the fan was not able to!
Nov 01, 2008 | Maytag MZD2766GES Side by Side...
Maytag MZD2665HE Side by Side Refrigerator Logo
21 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
