Green lines - Televison & Video
    Sergeant:
  • 214 Answers
May be the display itself or the board that hooks up to the display.
Posted on Dec 29, 2012
Vertical green line
EASY HOW TO FIX LG plasma TV - color bars - YouTube
? 4:45
https://www.youtube.com/watch?v=QyaBiSkc1l8
Dec 16, 2010 - Uploaded by Tampatec
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ...
I Have An Lg Plasma It Has A Green Line Down The Center What ...
www.diyforums.net/i-have-an-lg-plasma-it-has-a-green-line-down-the-ce...
i have an lg plasma it has a green line down the center what. .... Essentially I just disconnected the flat cable around where the vertical line was, sprayed it with a ...
LG 50PK550 Plasma Single Thin Green Vertical Line - Fixya
www.fixya.com/.../t12061168-lg_50pk550_plasma_single_thin_green
Mar 10, 2008 - Posted on Mar 17, 2012.
Jan 16, 2016 | LG Televison & Video
Vertical green line screen try
Have you tried to do a reset via the monitors menu options?
Jan 21, 2014 | HP w1907 LCD Monitor
Green line in middle of tv when switched on
Is there a picture with the green line going through the centre. If it`s just a green line with no picture, it sounds like the Frame (Vertical scan) Output IC has failed and possibly the safety feed resistor near the LOPTX. The reason why it`s a green line is to protect the tube from phosphor damage. The older TV`s would produce a VERY bright white line across the screen which could burn the phosphors withing the tube if left turned on in that condition. It`s not an expensive repair, but is it worth it with the price of Modern TV`s nowadays. If there is a picture with a green line, it may be due to phosphor damage, in which case, it`s a new CRT (tube). Ian
Jul 15, 2009 | Panasonic Televison & Video
Screen flashes green a couple times then shuts off
you need a new green CRT. The lines were retrace lines which are the first sign of a tube developing a short eventually the green will short completely and cause the set to shutdown.
Feb 04, 2009 | Sony KP-57WS510 57" Rear Projection HDTV
3500CP green fades to cyan
replace the yellow printhead ,as yellow and cyan mix to give you green .the yellow head has ink shorts
Jan 26, 2009 | HP DesignJet 3500cp InkJet Printer
Green lines
Due to vertical section failure horizontal line apprears. You did not mention about picture. Green horizontal line means with picture or without picture. With picture means there is some leakage. Without picture only singe horizontal line means vertical section totally not working. Particularly green horizontal line means maybe leads to jungle ic failure. Please mention your simptom clearly what you get and what you will not get both video and audio. It will be helpful to answer. Based on your question this is my small information.
May 24, 2008 | Sony KV-35S42 35" TV
Green converge lines are gone!
when you are in factory convergence on your hand unit press buttons 1-9 usally 1,2,3 theses should show r,g,b patterns, try them and see if your green is there,
Dec 16, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Shut-Off Problems with Philips 28ps6515/05
Green Screen with some lines lines are called retrace lines. it is due to maybe dry soldered or no green drive signal. This problem can be fixed by complete soldering in crt board. 1 green video supply absent 2 loose contact in green skt in crt board 3 crt board loose 4 no green drive signal.
Sep 15, 2007 | Philips 32PT6441/37 32" TV
Green horizontal lines
Hi, I have a Philips 29PT9009/12 TV. Recently I have begun to see horizontal green lines on my tv, when either watching a dvd or watch tv. This has gotten worse and now the green lines are more visible and the background is now turned a shaded green. Please help me. Thanks in advance
Apr 30, 2007 | Philips 28PW6506 28" TV
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Electro Med Services...
