Question about Daewoo DW-160C Washing Machine, 8 Kg Capacity, Rust proof plastic base and steel cabinet, High speed spin dryer, Spin dryer safety system, Powerful water flows from big pulsator, Normal & strong wash selector, Spin rinse system, Two lint filters DW160C DW 1
Spinner is not working dw-160c - Daewoo DW-160C Washing Machine, 8 Kg Capacity, Rust proof plastic base and steel cabinet, High speed spin dryer, Spin dryer safety system, Powerful water flows from big pulsator, Normal & strong wash selector, Spin rinse system, Two lint filters DW160C DW 1
Garmin fishfinder 160c sonar failure
Hi Lakshmaan:
The first thing I would check would be the electrical connections from the transducer, and the transducer wire.
Jun 07, 2016 | Garmin Color Fishfinder 160c
How to solve sonar failure(Showing on Display) in garmin 160c fishfinder.
I would guess that "sonar failure" would mean that no signal is being received from the transducer.
Trouble shoot accordingly.
Is vltage 110 or 220 volts
Would that not depend on which country you bought it and where you are trying to use ? Check the back of the Washing machine for voltage details.
the manual is attached. DAEWOO DW 160C Instruction Manual
Apr 27, 2016 | Washing Machines
I am thinking about buying a garmin 451 chartplotter, can I connect this to my garmin 160c fishfinder for sonar capability?
Hi James!
According to the owner's manual, the 451 can be used as a fishfinder when connected to a transducer. I would contact Garmin directly to see if the ducer from your 160c is compatible with a 451. If it is, you're in business! You'll likely have to cut/splice cable, but it'd be far easier than replacing the thru-hulls. (The 451 does come with transducers.)
It has been my experience that Garmin is REAL good when it comes to answering questions from consumers.
http://www.garmin.com/us/support/
Dec 26, 2014 | Garmin Boating
HOW CAN I CKECK HOW LARGE IS THE FISH TO FISHFINDER 160C?
the bigger the icon the bigger the fish no fish finder can tell you how big a fish is
Apr 15, 2013 | Garmin Color Fishfinder 160c
Can I get an inboard transducer for my Garmon 160C fish finder?
Yes you can. You would need Garmin part #: 010-10224-00. You can order this part off the Garmin website if you do a search for 160 and look under the accessories.
Jun 16, 2010 | Garmin Color Fishfinder 160c
My Kenmore 13593 dishwasher has stopped washing properly. It seems like the spray nozzles are not spinning. Almost as though there is not enough pressure or their is an internal leak. I have plenty of...
Look for plugged screens in the pump area... House water pressure has nothing to do with washing pressure as house water only fills, then the dw pump takes over...
Sep 20, 2009 | Kenmore 13593 Stainless Steel Built-in...
To wireup 160c Garmin fishfinder, there are seven clored wires. The book shows red and Yellow to hot. Black and blue to ground. Do the white, green and brown connect? Can the black and yellow be connected...
You only need the red and black wires to supply power to the unit. The red positive wire goes to a positive terminal on your battery or positive side of a bus bar or switch, the black negative wire goes to the negative terminal on the battery or negative common bus bar. Do not try to earth the black wire to an aluminum boat hull... You are asking for trouble! Best to run the black wire straight back to the negative battery terminal or negative bus bar that is wired to the negative battery terminal. The other colored wires on the 160C plug are used for interfacing with NMEA2000 compatible devices, like a compatible GPS.
Jun 14, 2009 | Garmin Color Fishfinder 160c
Daewoo DW-160C Washing Machine, 8 Kg Capacity, Rust proof plastic base and steel cabinet, High speed spin dryer, Spin dryer safety system, Powerful water flows from big pulsator, Normal & strong wash selector, Spin rinse system, Two lint filters DW160C DW 1 Logo
Top Daewoo Washing Machines Experts
Owen Barnes
Are you a Daewoo Washing Machine Expert? Answer questions, earn points and help others
