Question about Sewing Machines
I WAS SERGERING AND THE MACHINE COMPLETELY LOST POWER , WHAT SHOULD I LOOK FOR ?
IT WAS SEWING BEAUTIFULLY AND JUST STOPPED.
  • Sewing Machines Master
  • 1,564 Answers
First make sure it's still plugged in and that you haven't tripped a breaker. Temporarily move the machine to another area of the house. If you still have no power... take a good look and sniff at your foot pedal (smell burnt?) It may need replacing.
Other than that, I would recommend taking it in. Sergers are tricky and I would not recommend trying to service yourself.
Posted on Nov 12, 2012
Have the Ruby Royale, the bobbin thread is coming to the top side of fabric, not getting full color. Have retreaded, new bobbin, no luck. It's a new machine and worked beautifully this morning.
Tension is probably the problem. Sewing heats up the machine and the tension discs may not like it. Also be sure that your thread, fabric and needle are correct. The wrong needle ( too big?) may draw too much thread from the bobbin.
Jan 22, 2017 | Sewing Machines
My machine has suddenlty stopped working. The top thread is not catching the bobbin thread and so it is not sewing????
You may want to take it back where it was serviced. The timing may need to be tweaked. Also, the broken needle may have knocked it out of time. Be sure to check it again with a brand new needle first--very slowly. Confirm that you are installing the needle properly--flat side facing the correct direction, pushed up all the way, and it is the correct needle for your machine. If it is still hitting, then it definitely needs some service.
Oct 19, 2016 | Sewing Machines
Unlock brothers LS2125i sewing machine
Is the thread caught in gear in top of machine causing it to bind. If you refilled bobbin did the gear switch back completely or you have lost an o ring in bobbin rewind.
Oct 16, 2014 | Brother LS-2125 Mechanical Sewing Machine
Setting the tension for a 3 thread wide serger stitch
The tension depends on the thickness of the knits. Have you checked with the manufacturer about this problem? Check their website too, you may find the answer there. I wish I could help more. Good Luck!
Apr 14, 2014 | Sewing Machines
My machine is stitching beautifully but is incredibly loud and seems to have a lot of resistance on the flywheel- it only goes when the pedal is completely engaged. Its free of fluff and I've oiled it in...
it might be a good time to have the sewing machine checked
to see if there is a part that may be going bad, or the machine may need some type of adjustment.
Oct 03, 2013 | Brother 925D Serger
Bernina frozen, nothing moves
it's possible that something has broken or come loose inside the machine and the machine needs to be checked..
Jun 26, 2013 | Sewing Machines
The hook on my singer 758 isn't moving.
Take it in for repair. It's probably broken some plastic part inside.
Oct 06, 2012 | SINGER 7470 Sewing Machine
Nothng happens when I step on the foot peddle
Check the pins on the machine plug to make sure none have been pushed in, check the cables for any breaks but make sure the plug is out of the wall first, if you can undo the plug on the lead to check it all well and good, failing that take the foot control and lead into a sewing machine shop so it can be tested
Jul 10, 2010 | White Sewing Sewing Machines
Machine has stopped completely
This model is known to blow the fuse (3.0 amp) in the power board. A repair shop can replace it with a new style one (3.15 amp).
Jan 26, 2009 | Janome 6019QC Mechanical Sewing Machine
Sewing Machines Logo
29 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
