How to turn of aygaz gas heater
Do you switch of at the regulater
Where is the pilot lite to the hot water heater
There is a small (usually ) aluminum slide door. You need to air out the immediately area of any possible gas, then turn the knob on the regulater to pilot, hold the button down for a minute or so then use a long match to light the pilot light inside that little door. Hold lit matches up to the little tube until it lights. Then turn knob to temp.
Apr 06, 2016 | Water Water Heaters
My front passenger window does not work. how do i knnow if i need a new motor or a master switch?
Have you checked the fuse? Do you have power to the switch? Do you have power from switch to regulater? If so than you need to replace window regulater. Of you can hear the window regulater working but the windows isn't moving it could be as simple as some plastic clips. If so remember to clean and lube the tracks.
Aug 08, 2014 | Chevrolet 1995 Chevrolet Blazer S10/jimmy...
Propane heater
Are they both ran off of the same regulator? Is the vent open on the regulator? Do you have a full tank of propane or bottle?. Acts like you are running out of gas. Is there any other appliance that use the same gas supply and are they working? Just asking ? so maybe you can narrow down what the cause is..... Hard to tell with out putting a manometer to check gas pressure. Should be 11 to 14" of water column to gas valve and 10 to 11"WC manifold pressure. Hope this helps.
Jan 30, 2014 | Heating & Cooling
Have a vent free lp wall mounted heater.40 lp tank with regulater. pilot light will light but only the tip of pilot light is flame.there is a space between pilot light and tube where lp comes out. does not...
Too much gas pressure. Are you sure that this is a LP heater and not a Natural gas heater? Is the regulator you have rated under 1/2 pound pressure? Try to throttle down the shutoff on the tank to see if pilot gets better. If so, you have a pressure issue. Gas you adjust the pilot gas valve?
Jan 22, 2010 | Procom 10K BTU, Vent Free, 2 Plaque...
Error 11 no natural gas
if you don't have a 3/4 line from the meter with 2lbs and a regulater on it the 3/4 line is for volume and the regulater if for surging and making sure it doen's go below the volume of gas needed. if you have this you will have no problem, if you don't you have a problem good luck
Jun 07, 2009 | Rheem RTG-53PVN Indoor Natural Gas...
Smoke or vapor coming from new h400fdn hayward pool heater.
Not at all uncommon. New heaters have to glaze over the file tile in the burner chamber and will often smoke and smell during the first week or so of operation.
Using a mirror, check to see that your flames are about 4" proud of the burner tubes when running. As long as they are and the color is a nice blue with little to no yellow/orange color, the heater is fine.
May 28, 2009 | Hayward H Series Pool & Spa Heater 400k...
The batery is geting 18volts of charge
First of all make sure your battery is in good condition, and then get a voltmeter attached to battery, before start & after to confirm what your inside gauge is telling you is correct. Check and clean all connections to & from battery. Otherwise it's pointing back at regulator again.
Dec 01, 2008 | 1988 Chrysler Fifth Avenue
Brand new gas range
i would look into the valve/regulater at which you connected the gas line, off to the side or somewhere on the regulater itself there should be a shut off for the oven control, simply flick to open positon and you should start right up. it would shut off gas to oven but allow burners to light.
Oct 18, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Water heater burner flame is low does not heat water it was working this morning pilot stays lit
frist did this heater go under water if so call the pros.this can be do to dirty orfic on burner. clog presure regulater at gas meater check other gas applince.
Sep 17, 2008 | Intertherm Heating & Cooling
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
