Question about Delta Faucet DELTA/PEERLESS FAUCET CO. 25901 TWO HANDLE LAVATORY FAUCET - CHROME
Peerless goose neck leak - Delta Faucet DELTA/PEERLESS FAUCET CO. 25901 TWO HANDLE LAVATORY FAUCET - CHROME
2 Suggested Answers
  • 13 Answers
SOURCE: goose neck kitchen faucet is leaking around the
yes a common fault need to replace o ring can diy it yourself
Posted on Nov 29, 2010
How do I replace thermostat for 2007 Suzuki forenza
Like most motors the tstat is located under a goose neck with typically only two blots that the top radiator hose is connected to with a hose clamp, so you drain cooling system, remove top hose, remove goose neck, carefully remove tstat, take note of the direction, scrape old gasket mating areas, clean thoroughly, install new gasket, reinstall goose neck, Do not Over tighten, reinstall top radiator hose, fill system, start vehicle, turn on heat, check for leaks.....
Feb 20, 2015 | 2007 Suzuki Forenza Sedan
Wiggling Goose Neck
There could be loose hardware inside at the base of the goose neck. You will have to remove your carefully installed faucet and take a look inside to find out.
Nov 13, 2013 | Globe Union Glacier Bay 8 In Double Handle...
Motobecane handlebars need tightening
If they are tuning left and right the the center bolt on the top of the goose neck will do it. If they are loose at the goose neck and moving forward and backward then you need to tight the bolt underneath at the point the bars are in the neck. If you can't tighten it anymore you have two choices but you must first determine if it is the handle bars or the goose neck that is stripped. If it is the handle bars then replace them and if it is the goose neck replace that. The other think you can do is make a shim from a piece of metal and wrap it around the bar and tighten the goose neck on that again.
Aug 07, 2012 | Motobecane Jubilee Deluxe
What is the best way to pull the old thermostat out of a 1987 ford bronco?
Drain some antifreeze out of the radiator a QT or so remove the upper radiator hose where it hooks to the engine remove the goose neck that the hose is clamped to two bolts clean off the old gasket from bolth sides of the seal point, The t stat just lifts out its under the goose neck.Make sure the gasket surfaces are clean and i mean clean no old gasket left on eighter side. Install new gasket you may use some sealer it will hold the gasket in place install new t stat bolt goose neak back 18 LBS torque don't try to over tighten thats the gaskets job to seal. Attach hose refill radiator start check for leaks
Dec 10, 2010 | 1987 Ford Bronco II
How do i replace the theromstat
Follow the upper radiator hose back to where is clamped to the engine. The part that the hose clamps to is called the goose neck the t.stat is under this part. You will need to drain some coolant from the radiator not all about a QT. or so remove the upper hose clamp twist the hose to brake the seal remove the hose move to one side. Remove the two bolts that hold the goose neck down remove goose neck remove T.stat it will lift out. Clean all of the old gasket off bolth surfaces THIS IMPORTANT THE SURFACES NEED TO BE CLEAN OR YOU CAN CRACK THE NECK OR HAVE LEAKING AFTER INSTALLITION. Put the new T. stat in place put the new gasket in place you may want to use a gasket sealer it will hold the gasket in place. Put the two bolts in tighten then evenly go back and forth between them so to tighten them in stages they olny 18 ft lbs of torque DON,T TRY TO OVER TIGHTEN that is what the gasket is for reconnect your radiator hose tighten the clamp put your antifreeze back in start and check for any leaks sometimes you have to repisition the hose slightly and your done
Dec 05, 2010 | 1996 Pontiac Sunfire
Need to replace the thermostat and need to know where it is
Find the upper radiator hose follow it down to the enginewhere it clamps to the engine is a part called the goose neck the theromostas is under this part You will need to drain about a qt of antifreeze out of the radiator then you remove the hose from the goose neck then remove the twobolts that hold the neck down remove it and lift out the old tsat make sure you remove the old gasket compeltly you may need a razor blade but don;t nick the casting install new tstat new gasket you may want to use some sealer install bolts don;t over tighten 18 ft lbs is all you need install hose refill radiator start and check for leaks
Nov 23, 2010 | 2005 Pontiac G6
Where dose the thermostate go, in the hose? 1997 saturn 1.9 sc2 i do not see a goose neck
on the passenger side front of the engine on the top you will see the ac compressor go under that to the lower radiator hose follow that to the block and there is a little goose neck,2 10mm bolts hold it on,its behind there,make sure you have a new oring seal for the neck,,,,it will leak other wise,kinda sucks to get to,,
Feb 19, 2010 | Saturn SC2 Cars & Trucks
How do i change a thermostate in a ford fiesta & whr is it located h reg 1.4 petrol?????
follow the bottom radiator hose to the engine. the termostat will be under the goose neck the hose is atached to. remove the hose and the bolts on the goose neck. pull the goose neck off and the thermostat will pull right off. remember to replace the gasket with it
Jan 15, 2010 | 1989 Ford Festiva
How do you replace A thermostat on a chevy impala 95
follow the bottom of the radiator hose till it goes into the goose neck remove the hose and the goose neck the thermostat will be under the goose neck. make sure to replace the gasket with the thermostat
Jan 02, 2010 | 1996 Chevrolet Impala SS
My 454 engine is running hot and has rust colored exhaust when first started. what is the cause?
if the engine is "raw" water cooled than it is possible that the cooling passages in the manifolds, goose necks and even the block may be blocked by rust scale. Removing the goose neck from the exhaust manifold will show you if there is a rust problem developing. If the scale is in the block than it might be too late. If its "Fresh" water cooled than the same still pretains to the Exhaust manifolds and goose necks as they are raw water cooled, if there is scale in the block than it is usualy caused by not using enough anti-freeze in the heat exchanger and there will also be rust in there as well. Keep in mind that the cooling water discharges out the exhaust at the goose neck, so remove them when the boat is out of the water or if the exhaust is not below the water line.
Sep 26, 2009 | Boating
Delta Faucet DELTA/PEERLESS FAUCET CO. 25901 TWO HANDLE LAVATORY FAUCET - CHROME Logo
48 people viewed this question
Top Delta Faucet Plumbing Experts
Donni Steen
Ed Mac
Are you a Delta Faucet Plumbing Expert? Answer questions, earn points and help others
