Question about Kingston Data Traveler 2 GB USB Drive DTI/2GB
Flash drives says when it open that needs to format first before it used?
  • 105 Answers
It because there are a a logical eror
just format it but you will lose all data
to format (on windows 2000/XP) right-click on the key icon and click on "Format" then a litle windows apair on t press "Format" bouton
Posted on Oct 27, 2012
When i insert my USB flash drive called sanDisk cruzer 8GB in the laptop,am told that i need to format the disk in drive G before i can use it,when i try to format it, it says that windows was unable
If there is any Media Error not possible to format the drive otherwise use the following method on Windows 7
Open a Administrator command Prompt and type the command one by one
1.list disk
you can find the avilable disk and note your USB Drive Disk Number
2.select disk 1 (change the number)
3.clean
4.create partition primary
5.format fs=ntfs quick
6.assign
if no problem in usb it will format your USB Drive
Apr 03, 2014 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Tip
How to format Hard drive/flash drive
This is a tip explaining step by step how to format your Hard drive. This is as easy as 1 - 2 -3, so lets get the ball rolling.
Firstly, you need to know that this method can also be used with Flash drives, MP3 players, basically any removable drive.
If the drive you would like to follow is a internal Hard drive, and you would like to format it to NTFS format, here is how we do it. Remember, that you will not be able to format your C(System) drive, because, then you will delete your operating system, hence, all other drives can be formatted.
Open "My Computer" and follow these steps:
The drive shown above is your C(System) drive, If you want to format this drive, you will need to do this when you attempt a clean install of windows.
Say you want to format your flash drive, insert the flash drive into your USB port, and open "My Computer". My flashdrive is Labeled Lexar(H)
Now just follow these steps.
Now you are done, the drive has been formatted. Remember, this also works on internal Hard drives, but not your system drive.
Hope you can find this helpful.
Please rate accordingly.
Kind regards
Andrea
on Feb 28, 2010 | Computers & Internet
Samsung format sgh-790
Hello xanxi_uki, to "Format the Sandisk;
You can (right click), or 2x click to 'open' the "Computer" from the Desktop!
This will 'open' the Computer's Hard Disk Drives.
Or you can click on the "Start Button" and 'open' the "Computer."
Once you are in the Computer Drives; find the "USB Flash Drive."
Next, (right click) to 'open' the 'shortcut menu', choose to "Format."
In the Format UDisk (?), click on the "File System" [Drop down arrow "Box"].
Choose the [NTFS] from the list !
Select 'how much' of the USB Flash Drive you want to use?
This will be in the "Allocation unit size" box !
Now, you want to choose to {Quick Format} the USB Flash Drive.
"Place a [check] in the "Box" by clicking on it, to do so.
Next, click on the [Start] button."
The "formating" of the (USB Flash Drive) will begin.
Once it is 'finished'; use it as you like.
"If you need help with anything else?
"Write a 'comment'; I'll be on "Stand-by!"
If all goes well? Give a "Helpful Rating", thanks, paul7of9
Oct 02, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Dont work and dont format
When the flash drive is inserted and is still detected Kingston, flash drives can be repaired and the data can be saved. Cause, there is damage to the partition table
Solution:
1. Save the data. To saved data, you can use EASEUS Data Recovery software.
2. After the data is saved, to fix the flash drive using the software HP Drive Key Boot Utility (Support Win XP, Vista, 7)
How to install the HP Drive Key Boot Utility to the operating system
Win XP: double click the file cp006049.exe - select Install
Win Vista & 7: double click the file cp006049.exe - select extrack
How to use the software HP Drive Key Boot Utility
For
Win XP, first way:
Insert the flash drive - open the HP Drive Key Boot Utility - Next - select flash drives - Next - Create New or Replace ..., select Next - Next select Hard Drive - Create New File system, select Next - wait for the process is completed - Select Next - HP firmware Flash ..., select Next - wait for the process is completed - finish. Then, quick format the flash drive.
For
Win XP, second way:
Insert the flash drive - open the HP Drive Key Boot Utility - Next - select flash drives - Next - select Backup/Restore - Next - click Restore - click browse, open file C:\Program Files\Compaq\hpdkbu\ flash\initrd.img - Next - wait until the process is complete.
For Win Vista & 7
, first way:
Insert the flash drive - double click cp006049.exe - for example, extract to C:\HP Drive Key Boot. Open folder C:\HP Drive Key Boot then double click file hpdkbu.exe - Next - select flash drives - Next - Create New or Replace ..., select Next - Next select Hard Drive - Create New File system, select Next - wait for the process is completed - Select Next - HP firmware Flash ..., select Next - wait for the process is completed - finish. Then, quick format the flash drive.
For Win Vista & 7, second way:
double click file hpdkbu.exe - Next - select flash drives - Next - select Backup/Restore - Next - click Restore - click browse, open file C:\HP Drive Key Boot\initrd.img - Next - wait until the process is complete.
Description
initrd.img files, the image file for the schema partition flash drive capacity <= 2GB. For capacity >2GB, example: 4GB, 8GB, 16GB, 32GB, etc when we use the initrd.img file, will be changed to 2GB capacity. To restore the capacity of flash drives, do the Low Level Format. To make the process of Low Level Format, use software HDD Low Level Format Tool.
How to restore the capacity of flash drive Kingston
Open HDD Low Level Format Tool - select drive - Continue - click S.M.A.R.T - click Get SMART Attributes - click the tab LOW LEVEL FORMAT - click Format This Device - wait for the process is completed - Finish. Then, remove the flash drive from the computer, then insert it again. Then do a quick format the flash drive. Finish
Hope it helps
Sep 06, 2011 | Kingston Technologies 512MB DataTraveler I...
Sudenly kingstone usb changed to skymedi and doesnt formated
How to save data
To save data, use software full version, for example, you can use EASEUS Data Recovery. After the data is saved, do the repair flash drive.
Repair flash drive Kingston
1. Right-click the flash drive, select Format - select quick format. If this does not work, don't repeat, do the second.
2. Format from Administrative Tools.
Win XP: click START - Control Panel - Administrative Tools - Computer Management - Disk Management - right click the flash drive - select Format - select quick format
Win Vista & 7: click START - Control Panel - select View by: Large Icons - Administrative Tools - Computer Management - Disk Management - right click the flash drive - select Format - Perform a quick format - OK. If this does not work, don't repeat, do the third process.
3. Format using the software, the HP USB Disk Storage Format Tool. Make the process quick format. If this does not work, don't repeat, do the fourth.
4. Repair the flash drive using the software HP Drive Key Boot Utility (Support Win XP, Vista, 7)
Win Vista & 7: double click the file cp006049.exe - select extract
For Win XP, first way
For Win XP, second way
For Win Vista & 7, first way
Insert the flash drive - double click file hpdkbu.exe - Next - select flash drives - Next - select Backup/Restore - Next - click Restore - click browse, open file C:\HP Drive Key Boot\initrd.img - Next - wait until the process is complete.
Description
Hope it helps.
Sep 04, 2011 | Kingston Technologies 512MB DataTraveler I...
How do i format the usb stick so i can use it?
With the computer on and you logged in.
  • Plug in the flash drive and open Computer/My Computer
  • The flash drive should appear
  • Right Click it and select format. Leave the defaults and give it a volume name if you want. After it formats it's ready to go.
Comment back if you need more help.
Aug 30, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
My usb can' formate and open
Try formatting it using windows explorer. if the drive where your flash drive is plugged is recognized by windows explorer and the drivers have been installed but if not perhaps your flash drive is defective and need to be replaced..
Jul 02, 2011 | Sony Micro Vault Classic 4GB USB 2.0 Flash...
My pen drive is not open (mic d33193)
u need to formate your pen drive, with low level formatting.
Jan 04, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
How to recover flashdrive transcened 4gb v30, it can detect but i can't open?
Files on a flash drive can be corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
To restore the flash drive you may need to format the flash drive, but you will lose the data stored on the flash drive.
If you need the data on the flash drive this program may help: -
Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
Oct 11, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Storing documents on my sandisc cruzer 4.0GB flashdrive
Scan the pendrive for virus infection, that may be the possible cause.Or try formatting it once and then check again if you cannot fix it using a antivirus.
Jun 24, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Kingston Data Traveler 2 GB USB Drive DTI/2GB Logo
103 people viewed this question
Top Kingston Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
