Question about Frigidaire Washing Machines
Letter J showing in display
Power source ok, water begins to run in, then it just stops with the letter J in the display.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 46 Answers
You are going to have to replace the control board.
http://www.repairclinic.com/
This is relatively simple. The letter J just means the memory in the control board is corrupt.
Posted on Oct 27, 2012
5 Suggested Answers
  • 30 Answers
SOURCE: what does it mean when the letter F flashes on the
there should be a number after the f. the f stand for failure and the number that follows tell you what the failure mean. whether it is long drain or board problems door lock. could be a number of things. find out the number and reply back
Posted on Mar 26, 2010
blueextc3221
  • 15935 Answers
SOURCE: Letter "H" then "F" error. Our Kenmore 110 45081 washer
FH error indicates that either you have no water coming into the washer, or very little water. Since you can see it filling, the error indicates low flow. A flow meter
in the unit detects if 10.5 gallons fills the tub within 8 minutes; yours must not be. This will turn off the inlet valves and the error code will be displayed. Check the following:
- Make sure you don't have a siphoning problem. This occurs when there is no air gap for the drain line at the standpipe. The standpipe is the drain pipe at the wall where the washer drain line is placed. With no air gap, a vacuum is created, and water will begin to drain from the wash tub prematurely. To prevent this from occurring, follow this advice:
•The standpipe should be 2 inches in diameter to allow a sufficient air gap between the top of the standpipe and the drain hose.
•The standpipe should be a minimum of 34" from the floor, and should not exceed 72 inches in height.
•DO NOT seal the top of the standpipe. Many consumers seal the standpipe in the belief that this will prevent overflows, or get rid of drain odors. This often creates more problems than solutions.
•DO NOT place the drain hose too far down into the pipe. Water stays in the drain trap area of the standpipe. If the end of the drain hose rests in this area, no air gap is created, and this can also cause siphoning. 4 to 6 inches is sufficient.
•The drain hose length must not exceed 10 feet in length. Excessive drain hose length can cause drain problems and back wash.
- Verify Drain Pump operation. Unplug the washer and take the lower panel under the door off by removing the three screws under the bottom edge. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. Open the pump access and remove, once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there's nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
- Verify Flow meter operation and that the Pressure Switch hoses are intact and connected properly. Remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The flowmeter will be located on the left-hand side of the washer (facing from the front) between the inlet valve and dispenser. It's a small white plastic device with hoses attached. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a hose attached. There should be a tech sheet directly behind the panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics, how to locate the components mentioned, and the specific measurements required in determining if the components are good or bad.
"F/H" indicates that either you have no water coming into the washer, or very little water.
If you have NO water coming into the wash tub after 30 seconds the error code is displayed. Check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on.
- Check inlet hoses for kinks or clogs.
If you HAVE water filling the wash tub, and after 8 minutes, 10.5 gallons of water has been detected by the flowmeter, but there has not been a detected a Pressure Switch trip, the inlet valves are turned off and the error code is displayed. Check the following:
- Make sure you don't have a siphoning problem. Click the following link for instructions: http://www.fixya.com/support/r587481-prevent_washer_siphoning
- Verify Flowmeter operation.
- Verify the Pressure Switch hoses are intact and connected properly.
To access the Drain Pump - UNPLUG the washer and take the lower panel under the door off by removing the three screws under the bottom edge. HINT: Propping the front feet of the washer up can make access much easier. I use a couple small blocks of wood. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. If not, click on the following link to check the pump for obstructions:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
To access the Flowmeter and Pressure Switch – remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The flowmeter will be located on the left-hand side of the washer (facing from the front) between the inlet valve and dispenser. It’s a small white plastic device with hoses attached. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a hose attached.
There should be a tech sheet directly behind the panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics, how to locate the components mentioned, and the specific measurements required determining if the components are good or bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
Daniel S
  • 4323 Answers
SOURCE: we have a Duet Washing
Hi
Error code FH appears when No water is detected entering machine or Pressure switch trip is not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Press PAUSE/CANCEL twice to clear the display. If there is no water entering the unit then make sure that the inlet valves are working fine. You may need to check the continuity at the inlet valves. If the valves are fine then check whether inlet water hose, it may be plugged. Also check for inlet water screen at the valve. However, if the water is entering into the washer then the Drain pump might not be working. Also inspect the Pressure Switch hose whether it is in good condition and properly connected to Tub and Pressure switch. Also check hoses for leak and inspect the flow meter. Hope this helps...
Daniel
Posted on Feb 11, 2011
pctech1
  • 1940 Answers
SOURCE: The washing machine is currently
F21 is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed.
  1. First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
  2. Check the drain hose to make sure it is not kinked or clogged.
  3. Check the pump strainer. There are three screws at the very bottom of washer. You will need and extension and a star tip. I used a 9/32 socket to remove them. The front cover slides right off. Facing you is the pump strainer. Big white piece of plastic right in the middle. Turn the large white knob counter-clockwise to remove it and clean. It is the only thing you can unscrew by hand. Open it and clean anything you find out.
Posted on Feb 22, 2011
How do i access phone numbers from my phone
Search for a contact
Press the open Menu button
Use the arrow keys to select Personal. Press OK.
Use the arrow keys to select Options. Press OK.
Enter the first letter of the name you are searching, e.g. K
The first name found with the letter K is displayed
If you are looking for a name that begins with Kr, also enter the second letter in the search field:
The first name with the initial letters Kr is displayed
Use the arrow keys to find the name
Press OK to select and call the contact
Oct 03, 2016 | Uniden Cordless Phone
Model #NGD7200TW starts up again after drying cycle stops
TO CHECK ON YOUR PROBLEM YOU CALL AMANA OR WHO THE NAME BRAND .< 1 > GIVE THEN THE MODLE NUMBER / SREAL NUMBER .< 2 >GIVE THEM THE CODE THAT YOU SEE "4" . LOOK VERY CLOSLY AT YOUR DISPLAY AND SEE IF THERE IS A LETTER YOU CAN MAKE OOUT. THIS INFO WILL HELP GREATLY.
Dec 10, 2015 | Amana Dryers
Frigidaire front loading washer, letter J in the display, will not operate.
First I recommend unplugging the washer for a couple of minutes then turning it back on. If that doesn't clear it unfortunately your are going to have to replace the control board. You can find the part here
http://www.repairclinic.com/ Just use your model number to look it up.
Oct 27, 2012 | Frigidaire Washing Machines
There is an EE code. The machine just beeps.
EE
Remove your washer from the power source if you see an "EE" error code, where the first E is missing the top part of the letter. Your washing machine has a serious malfunction, and you must contact a technician.
A bit odd that as error code EE does not exist for washing machines, it's a refrigeration error code. Unless of course part of the display (led) has been damaged and the code isn't displayed properly.
Hope helps.
Jun 27, 2011 | Washing Machines
I got erro 08611, how can i fix?
1. switch on your laptop
2. the screen will display "error 08611
3. click "ok"
4. the screen will show the components in your laptop.
5. click "exit"
6. then, click "configu"
7. press ctrl + the letter D =
8. screen will display the commands to run your laptop.
9. you go to first column and third row change the nomber "02" to "01"
10. press f3
11. reboot your laptop
Source:
http://mailman.linux-thinkpad.org/pipermail/linux-thinkpad/2004-February/015935.html
Hope this helps.
Mar 19, 2011 | IBM ThinkPad 600X Notebook
We have a Duet Washing machine. It keeps sounding the alarm and then the letter F will show up followed by the letter H..do you have any idea what these warnings mean...it just stops working and keeps...
Hi
Daniel
Feb 11, 2011 | Washing Machines
Washer flashing letter
The error indicates that there is no water detected entering machine or Pressure switch trip not detected..If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
  • If there is no water in the unit:
    1. Make sure that both valves at the water source(s) are turned on all the way.
    2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
  • 3. Verify inlet valve operation
  • If there is water in the unit:
    1. Verify Drain pump operation
    2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Verify pressure switch operation
  • Verify flow meter operation
  • Verify CCU operation
Thank you !!
May 31, 2010 | Whirlpool LHW0050PQ Front Load Washer
It is not aligned with the keys or letter or icons
Try a screen calibration. To recalibrate your c-Series touch screen follow these steps:
1. Begin with the unit turned OFF and unplugged from a power source.
2. Power the unit ON, continue to hold the Power button for 1 minute.
3. A screen will display instructing you to Press dot in the lower left corner.
4. Release the Power button and touch the sequence of dots until your unit displays, Calibration complete.
5. Your unit should now function normally.
Sep 20, 2009 | Garmin StreetPilot C330 GPS Receiver
Changing to capital letters in texts.
i might be wrong on this one, but all motorola's are mostly the same on texting. Soto get a capital letter in text just press the 0 before the letter
Mar 11, 2009 | Motorola Mobility L71 Cellular Phone
Error message F on shu 6800
float switch is in the flood position and the drain pump is running.. there is water under the dishwasher or that switch is stuck up..
Aug 16, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Washing Machines Logo
46 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
