Question about Microsoft Xbox Console
Xbox 360 Wireless controller assembly
Hi guys !! I`m looking for Wireless controller assembly guide but this information is not available on the web. Please, anybody can helpme. My controller fall down and some keys don`t work. Thanks in advanced. Your friend Luis.
  • wizza1914 Mar 19, 2009
    Got a couple sticky buttons on mine i just wanna clean up and need the same info
    Problem Solver:
  • 7 Answers
Have you looked here? http://www.llamma.com/xbox360/mods/XCM-Xbox-360-Wireless-Controller-Shell-Installation-Instructions.htm
Posted on Oct 01, 2007
SOURCE:
Controller doesnt turn on but batterys are good
Connect a game controller
Solutions
Learn how to connect a wireless or wired controller to your Xbox 360 console.
Connect a wireless Xbox controller
  1. Turn on your console.
  2. Press and hold the Guide button on the controller until the controller turns on.
  1. Press and release the connect button on the console.
Xbox 360 E console fbbfb609-f7ed-4e6e-bd35-7543b1c20d61.png?n=xbox360-connect-m-s.png Xbox 360 S console Original Xbox 360 console 342c6e70-9e56-43d8-bb3a-05f5411040bd.png?v=1#xbox360s-connect-m-m.png 170df81e-0a79-49be-8236-a0fb68eec37b.png?v=1#xbox360-connect-m-m.png
  1. Within 20 seconds, press and release the connect button on the controller.
  1. When the lights surrounding the power button on the console stop flashing, the controller is connected.
On the Xbox 360 S console, each connected controller is assigned to one of four positions. Each position corresponds to a lighted section around the console power button and the controller Guide button. On the 360 E console, a solid green light on the front of the console indicates that the controller is connected. To determine the player position associated with your accessory, look at the ring of light that surrounds the Guide button on the controller.
c9341988-8ed5-4217-9b87-353de50efbec.png?v=1#connect-xbox-controller-m-m.png 5e4ab6ab-8cb0-41e6-a037-b88221a430c7.png?n=connect-xbox-controller-360-m-s.png
71add0b7-ddf2-4439-b4b4-f50f156d92b7.png?v=1#controller-batteries-m-m.png If the controller does not turn on, check the batteries. Insert fresh AA batteries, making sure they are correctly positioned in the battery case.
You can also use the Xbox 360 Play & Charge Kit or the Xbox 360 Quick Charge Kit to power the controller. Learn more about Xbox controllers and chargers.
To connect additional controllers, follow these same steps again. You can connect up to four controllers to the console. Each connected controller is assigned a position that corresponds with the lighted sections that appear around the console's power button and around the Guide button located in the middle of each controller.
  • To disconnect a wireless controller, press and hold the Guide button for three seconds, and then choose to turn the controller off.
  • When you turn off the console, the controller will reconnect the next time you turn on the console.
  • The controller can be connected to only one console at a time. You can connect the controller to a different console, but the connection to the previously connected console will be lost.
Oct 11, 2013 | Microsoft Xbox 360 Controller
My controller was working one day and then stop working the next day it had fresh battery
Solutions
Jul 31, 2013 | Microsoft Xbox 360 Controller
Ho w to fix x box from controller to x box is really slow how to make it normal
Connect a wired Xbox controller
5fb17f50-7448-45d5-a294-9ea90994f55b.png?v=1#controller-wired-m-m.png Plug the Xbox 360 Wired Controller into a USB port on the Xbox 360 console. There are two USB ports on the front of the console. To disconnect the controller, pull on the connector, not the cable.
cbe46bf0-3a46-4d53-9d8c-6697aa57622a.png?v=1#controller-cable-release-m-m.png The cable on the Xbox 360 Wired Controller has an inline release. The inline release on the controller cable is a safety feature designed to reduce the chance of the Xbox 360 console falling if the cable is pulled.
Wireless controller troubleshooting
If your wireless controller disconnects or cannot connect to your console, see Xbox 360 Wireless Controller disconnects or can't connect.
If your wireless controller does not turn on or loses power, try the following solutions:
Solution 1: Replace the batteries
Insert a new set of AA alkaline batteries into the Xbox 360 Wireless Controller, and then try to turn it on.
Solution 2: Try a different battery pack
If you have another Xbox 360 Wireless Controller, take the battery pack off that controller and attach it to your controller. Then try to turn your controller on.
If your controller works with the different battery pack, your original battery pack might be defective. If your controller is under warranty, you can order a replacement battery pack from Xbox Support . See the Assistance section at the bottom of this page for more information.
If your controller is out of warranty, you can buy a new battery pack from a retail store.
Solution 3: Try a rechargeable battery packIf you or a friend has an Xbox 360 Rechargeable Battery Pack, attach that battery pack to your controller and try to use your controller. If your controller works with the rechargeable battery pack attached, you can buy a new battery pack from a retail store or order a replacement battery pack from Xbox Support. See the Assistance section at the bottom of this page for more information.
Feb 08, 2013 | Microsoft Xbox 360 Controller
My wireless controller/controllers does not connect anymore...i must say though, that they are connecting when i plug them into a wireless convertor designed by microsft for windows OS...so the problem...
There is a XBOX 360 repair guide available that covers this problem and also all other common XBOX problems. You can get your copy XBOX 360 Repair Guide.....you can download it and get help to fix your console.......
Click here to download Microsoft xbox360 repair guide
Jan 03, 2011 | Microsoft Xbox 360 Console
I have a new wireless controller but when i press the sync button on the main controller nothing happens. The sync button on the new wireless controller appears to work with the lights spinning when...
XBOX 360 repair guide available that covers this problem and also all other common XBOX problems. You can get your copy XBOX 360 Repair Guide, you can download it and get help to fix your console...
click here to download repair guide
Dec 28, 2010 | Microsoft Xbox 360 Wireless Controller
I cant sink my new remote to the controller. The controller just blinks when pressed. I cant get the controllers green lights to circle.
XBOX 360 repair guide available that covers this problem and also all other common XBOX problems. You can get your copy XBOX 360 Repair Guide, you can download it and get help to fix your console....
Dec 26, 2010 | Microsoft Xbox 360 Wireless Controller
The Xbox Light doesn't turn on the Xbox 360 Wireless Controller
there are series of problem in xbox which can be solved without much technical knowledge your problem is one amoung that ........ your problem belong to that so dont worry i will give you the link to download the repair guide that will help you a lot Click Here
Jul 29, 2010 | Microsoft Xbox 360 Controller
How to setup two wireless controlers to an xbox
  1. Press and hold the Xbox Guide button until the controller turns on. The Xbox Guide button is the round button with the green "X" near the center of the controller.
  2. Make sure that your Xbox 360 console is turned on. If your Xbox 360 console is not turned on, press the power button. The power button is the large round button on your Xbox 360 console.
  3. On the Xbox 360 console, press and release the Connect button. The Connect button is the small round button on the Xbox 360 console.
  4. On the controller, press and release the Connect button. The Connect button is the small button on the front edge of the controller, between the left bumper button and the charging port.
  5. After the Ring of Light spins and flashes one time on the controller and on the console, the controller is connected. The quadrant on the Ring of Light that remains lit indicates the position in which the controller is connected.
  6. Note If you want help connecting an Xbox 360 Wireless Controller to your Xbox 360 console, you can contact Xbox Customer Support. For more information about how to contact Xbox Customer Support, please visit the Xbox Support (http://www.xbox.com/support/) Web site.
  • The controller remains connected to the Xbox console even when you turn off the Xbox console.
  • The controller is connected to only one Xbox console at a time. You can connect the controller to a different Xbox console at any time, but your connection to the previously connected console is lost. You must repeat these steps to reconnect the controller to the original console after your connection to the console is lost.
  • The controller works within 33 feet (10 meters) of your Xbox 360 console. However, objects between the controller and the console may reduce this range.
  • If the controller does not turn on, the batteries may have to be replaced.
Mar 22, 2010 | Microsoft Xbox 360 Console
Xbox controllerwirless wontconnect to pc
To connect the controller to a computer that is running Windows XP SP2 or a later version of Windows, follow these steps:
  2. Make sure that the Xbox 360 Wireless Gaming Receiver for Windows is plugged in to your computer.
  3. On the Xbox 360 Wireless Gaming Receiver for Windows, press and release the small round Connect button.
  5. The Ring of Light on the controller spins and flashes one time, and the light on the Xbox 360 Wireless Gaming Receiver for Windows flashes. When the controller is connected, the Ring of Light on the controller remains lit and indicates the position in which the controller is connected.
Note If you want help connecting an Xbox 360 Wireless Controller to your personal computer, you can contact Xbox Customer Support. For more information about how to contact Xbox Customer Support, please visit the Xbox Support (http://www.xbox.com/support/) Web site.
Jan 07, 2010 | Microsoft Xbox Console
Can I use my XBOX 360 Elite (Black) Remote to play games on my PC? If Yes, What do I need and where can I find it?
Are you talking about the controller? Or the media center remote control (similar to a tv remote)?
If you are talking about the controller you need to buy this:
Xbox 360 Wireless Reciever for Windows
and here is a guide:
MS Guide
Thanks
Dec 21, 2009 | Microsoft Xbox 360 Wireless Controller
Microsoft Xbox Console Logo
1,050 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
