Question about JVC GR-DX97 Mini DV Digital Camcorder
Says lens cap is closed
Says my lens cap is closed i can't record anything it is almost like it wont let the light in to record
  • Anonymous Feb 05, 2009
    I have the same Problem and no solution yet
  • 1,223 Answers
BAD NEWS ! it is a CCD Failure !!
Good News !
No need to worry u can get it repaired free of charge from JVC even if u are out of warranty they have issued service advisory for this problem see here
pls rate me FIXYA for help !
Posted on Apr 04, 2009
Why does it say remove lens cap when trying to record?
Because the camera can not record when the cap is on just like u cant see with ur eyes closed. So remove lens cap.
Dec 13, 2015 | Video Cameras
My problem is im trying to record and i have the camera switched to tape and have it turned on to camera and it records sound but will not record picture, but will play back other tapes on the screen ok.I...
If the iris is opening to let light in, that light is not being changed to a picture signal or that picture signal is not
going into the camera circuits, What you see in the viewfinder is what is being recorded, Make sure that no cables have been left plugged in to the camera and turn the power on and off several times, I have seen the iris stick when cameras were not used for a while. The iris is inside or behind the lens and closes completely when you turn the camera off, If it is stuck, SOMETIMES it will open with repeated tries of turning it off and on or even removing the battery and putting it back in. And maybe it is just the vibration of opening and closing the battery compartment door or the slight vibrations of pushing the power button repeatedly. If it sticks once, it will stick again. This is not a repair, just a way to get those one time pictures' before.
Jan 08, 2018 | Canon ZR50MC Mini DV Digital Camcorder
My JVC camcorder keeps saying lens cap is on and it wont view any image just plain black. I have had it for about five years first time anything like this has happened. I think it might have been dropped...
That sounds like the shutter is stuck closed. Unless you're highly technical, if will most likely require servicing. Get an estimate first, the repair cost can be worth more than the camera.
Mar 14, 2010 | Panasonic NV-GS11B Mini DV Digital...
Cannot record
if the lens cap auto closes, when it is on, try to tap slowly near the lens, very gently, and check again....repeat several times, it should work. the other options are taking it to qualified service tech, just beacuse its has very fine gears.....try it, reason for tapping is, the switch indicator is stuck, and gives wrong signal...dust paritcals could be the reason for that..
Oct 25, 2009 | JVC Everio GZ-MG21 Camcorder
Lens Cap problem
It is known problem of bad ccd imager in JVC GR-D30U camcorder.
JVC will repair it free of cost. Please click JVC CCD Imager Support for details.
Aug 04, 2009 | JVC GR-D30U Camcorder
My Sony DCR DVD 108 has no image at all with or with out disc says lens cap may be closed but it isnt flashing E:61:11 top right hand side of touch screen plays previously recorded dvd fine but thats it.
You may have lost your image sensor.
  1. Take lens cap off.
  2. Look in lens make sure there is nothing on or blocking lens.
  3. Find bright room & see if image comes up.
  4. Make sure your in video record mode.
  5. If you have eyepiece lens look to make sure it is off. {Most cams will not let you use both at same time.}
  6. Still no image try recording on blank disk then play back see if image is recording.
If that does not work MSG back.
Mar 07, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
I cant find a solution but causes may be :
1. Did you remove the LENSE CAP ?
2. PRobably there is a small switch that tells the camera that LENSE CAP is on or something dunno
About that recording problem
1. LCD Broken?
2. Other technical issues ...
Im not proffesional or anything :P Wish you luck with better people at this D: .
Camcorder says lens cap is on when its not
This is problem of bad CCD Imager in your JVC GR-D32U model. This part need to be replaced.
JVC offers Free of Cost repair for such problem in same model cameras.
Click JVC CCD Program for details.
Nov 09, 2008 | Cameras
Dropped camcorder
When you dropped the camera you ended up jamming the iris closed. There may be additional damage within the lens assembly. In order to repair the stuck iris, the optical lens assembly needs to be partially disassembled. This is not a project for the novice. This should be taken to a JVC authorized service center for a repair estimate. The estimate will cost about $50 or so.
Apr 03, 2008 | JVC Everio GZ-MG57 HDD Camcorder
JVC GR-DX97 Mini DV Digital Camcorder Logo
241 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
