Question about Technics SL-1200 Turntable
Technics multiple play spindle wearing out it seems.
Do you have any multiple play Technics spindles? Mine has taken to dropping several records at once and I am tired of that. Don't have the model number but it is about 25 years old. Works fine except for that.
Sterling
  • 515 Answers
Need the model number. Technics released over 100 turntables between 1970-1990 - so a model number would help us in determining what you need.
- OPTiC
Repair Videos
Turntable Repair
DJ Equipment Sales
Technics Parts
Posted on Jan 17, 2009
Multi-play technics sl-235 spindle occasionally not dropping records
If you have only purchased it in the last 6 months it should still be under warranty and therefore covered by Technics. Don't do anything to it yourself and contact them.
Feb 25, 2014 | Technics Audio Players & Recorders
Ive replaced a stock spindle with a drop spindle on my 95 gmc sierra and i can't seem to get the rotor on the spindle far enough to put the spindle castle nut on?
just remove the spindle as it slows the speed of your engine thus making it to consume a lot of fuel over a short distance
Aug 16, 2012 | 1989 GMC C1500
SL-1200 Turntable: I own two Technics SL-1200mk5 turntables. My probl...
Hi, could just be platter not fitted hard down on spindle. I suggest you remove the platter and place it upon a dead flat surface to check to see that the platter is flat. If it is flat refit to turntable ensuring it is hard down on the spindle. If bent discard and replace with new platter.Platters can be ordered for all model 1200/1210 from styluscity@gmail.com
May 16, 2010 | Technics SL-1200 Turntable
I have a technics 5 changer CD player, model# SL-PD687 and when I place a CD in there it no longer plays the CD. It just moves through all 5 CDs and stops without playing them.
You ever get a solution to this, mate?
I have the same freaki'n issue with mine all of a sudden. Suspect the power supply's not delivering enough power to rotate the spindle-motor anymore, cause if I take this motor out and connect it to a 1.5V battery, it runs...
let me know if you've found the solution please on: tobie dot steyn at gmail dot com.
Oct 16, 2009 | Technics SL-PD687 5-Disc CD Changer
FAILURE TO READ DISCS. TECHNICS SL-DV280 (SC-DV280)
if the disc starts to rotate when helped by hand then you definately have a weak spindle motor. dvds spin faster than cds which gives more wear & tear to the motor. i've repaired these faults numerous times. hope this helps?
May 08, 2009 | Technics SC-DV290 System
Technics turntable model SL-bd27. center spindle rubbing noise.
hi, try to open or remove the platter on the deck, maybee there some small thing inside..
Apr 09, 2009 | Technics SL-1200M3D Turntable
Will not drop 45's
I think the spindle is broke or stuck in some way! if you have another one try that! and if you dont you may be able to use those little plastic adapter thingys and place them on the 45s and try that !
It sounds to me like the spindle is sticking and is pulling the turntable belt and slowing it down!
I would look for a new/used spindle
I think this will fix ya!
Please rate This answer
THANK YOU!
Jan 17, 2009 | Teac AG-V1050 Receiver
Dvd noread
If you put a disk in and it just clicks several times, it's more than likely the spindle motor. It's best just to replace the DVD drive. My own theory is that when you record in the high speed mode, it is just too much for the spindle motor to handle over time. I keep my record speed in the standard mode to play it safe.
Apr 06, 2008 | Panasonic DMR-EH55 DVD Recorder/HDD...
TECHNICS SC-EH750-CD KEEPS SKIPPING
replace travers assy ,because spindle motor is faulty. If you can get spindle only it will be chiper solution for you.
Nov 10, 2007 | Technics SC-EH780 CD Shelf System
Technics SL-1200 Turntable Logo
263 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
