Question about Electrical Supplies
What are the valve clearances for a Generac generator with a 10hp B&S engine. The model #09719-2 and Series #SVP5000.
CarlGehrke
  • 169 Answers
SOURCE: Generac Guardian 17.5KW Generator dies
If this is one of the big "taco cart" portables you need to check that the vent on the gas cap is open when you're running the engine. In the center of the gage on the gas cap is a little knurled knob, turn it counter clockwise (lefty loosey), about a half turn or so and run the generator.
If that doesn't solve your problem add to it here, otherwise please give me a rating I'm trying to build a little credibility here and could use the help.
Carl
Posted on Dec 02, 2008
  • 42 Answers
SOURCE: wiring diagram for Generac engine on standby generator
here is a wiring diagram for that engine:
Posted on Mar 13, 2009
gmchat
  • 4 Answers
SOURCE: what carb does the powermate 6875 use?
check this web site http://www.powermate.com/productmanuals.php?cat_id=3 you can down load the manual and parts list for your gen.
Posted on Mar 27, 2009
mydogisk
  • 50 Answers
SOURCE: Guardian generac 10kw model 5502 does not output correct voltage
the instructions says the voltage regulator is automatic/digital. when you check the voltage is there any load on the generator? if applying load to the generator doesn't help, you can manually change the motor speed where the governor connects to the carborator, but it may change the frequency, but the regulator may fix it
Posted on Apr 13, 2009
mamicheddy
  • 79 Answers
SOURCE: I have a Generac portable generator 5000 watts, won't start!
I am assuming the generator worked fine before the oil change. Now that you have done the oil change the genset does not start. These generators have a safety switch, which is basically an oil pressure switch that keeps the engine from running when there is not enough oil in the engine. Make sure that there is enough oil and if there is, look for a wire that runs along side of the engine to a round component. disconnect that wire and try starting. If it does not start then try to ground out the wire to the engine block. If this does not work, then there is other engine problems.
Posted on May 08, 2009
I need a rectifier or avr for generac 3500 xl genarator
Ebay and various places including the maker..
  • VOLTAGE-REGULATOR-3000-3500-WATT-GENERATOR-GENERATORS ... www.ebay.com/sch/sis.html?_nkw=VOLTAGE-REGULATOR-3000-3500-WATT... VOLTAGE-REGULATOR-3000-3500-WATT-GENERATOR ... New listing 3500 Watt Generator AVR Automatic ... 3500W Generator AVR Automatic Voltage Rectifier ...
  • 3500 W 3500 Watt Generator AVR Automatic Voltage Regulator ... https://sites.google.com/site/kltthtyz0i04cd/3500-w-3500-watt... Generac Guardian 22kW Standby Generator NG ... Previously Pay for Shop 3500 W 3500 Watt Generator AVR Automatic Voltage Regulator Rectifier 3.5KW Generator AVR ...
  • How to test your Electricity Generator's AVR, Brushes and ... www.youtube.com/watch?v=tC_LrrZcx38
    • BY GENERATOR GURU
    • 9 MIN
    • 454K VIEWS
    2011-10-21 · Video embedded · When your electricity Generator stops producing power, ... How to test your Electricity Generator's AVR, ... Generac iQ: The Quietest Generator ...
  • Generac Power Systems - Home www.generac.com Generac manufactures the widest range of power products in the marketplace including portable, RV, residential, commercial and industrial generators.
  • Generac Guardian Generator Voltage Regulator Rectifier ... www.ebay.com/sch/sis.html?_nkw=Generac+Guardian+Generator+Voltage... Generac Guardian Generator Voltage Regulator Rectifier ... Generac Guardian Generator Voltage Regulator Rectifier ... Generac Guardian Generator Voltage Regulator ...
  • Automatic Voltage Regulator (AVR) for Generators portable.generatorguide.net/avr.html How automatic voltage regulator (AVR) works in portable generators: ... here you can see a reverse engineered Generac regulator that uses SCRs and UJT.
  • Diagnosing A Generator That Has No Power Output. - YouTube Youtube
    • BY THEDIYGUYDOTNET
    • 3 MIN
    • 150K VIEWS
    2012-11-12 · Video embedded · Diagnosing A Generator That Has No Power Output. ... How to test your Electricity Generator's AVR, ... Generac Portable Generator ...
  • GENERATOR Diagram & Parts List for Model 3500xl Generac ... www.searspartsdirect.com > ... > 3500XL GENERAC Generator-Parts GENERATOR Diagram and Parts List for GENERAC Generator-Parts model # 3500XL ... Generator rectifier Part #: ... Generator voltage regulator Part #: ...
  • Jun 28, 2016 | Generac Electrical Supplies
    Valve adj. B&S gen. Model 030246 10 hp. OHV
    Briggs and Stratton Valve Clearances
    outdoorpowerinfo.com/engine_specs/briggs_valve_gaps.asp
    Briggs & Stratton Intake and Exhaust Valve Clearances. Model Series, Engine Type, Intake Valve Clearance ( in. ) Exhaust Valve Clearance ( in. ).
    Briggs and Stratton 10hp Generator Carburetor Repair ...
    ? 6:17
    https://www.youtube.com/watch?v=O-fROtibEvE
    Jun 5, 2010 - Uploaded by IFIXIT4U
    In this video I will show you how to clean the carb on a Briggs10hp. This is a Nikki carb.
    Nov 03, 2015 | Measuring Tools & Sensors
    What is the valve setting for 2004 18.5 HP briggs & stration intek ohv engine?
    31C700 engine? (model number)
    This is pretty generac for all of their engines as a general rule 0.004 - 0.006
    From the service manual for the 31C700 engine:
    ADJUST VALVES
    1. Set No. 1 cylinder at 1/4" (6.4mm) past TDC, compression
    stroke.
    a. Adjust valves and check, Fig. 17.
    Valve Clearance (cold) IN and EX .005" (0.13 mm)
    b. Torque adjusting screws and jam nuts to 60 in. lbs.
    (7.0 Nm).
    2. Set No. 2 cylinder at TDC, compression stroke.
    a. Repeat for No. 2 cylinder.
    Thanks for choosing FixYa,
    Kelly
    Aug 24, 2011 | Craftsman Garden
    I have a Generac 5000 Power Plus 10HP Model 09856-0 Series 401 4891. It works fine but the gas tank petcock leaks. Where can I get a replacement and for reference I'd like to get a parts manual for future...
    The original part number your looking for is 78298 (Plastic tank valve). It has been superseded by part number 080270 and it it available here:
    http://www.ordertree.com/ARI.aspx?Mfg=36&Model=9856-0%20POWERPLUS,%205,000%20Watt
    http://www.ordertree.com/AddtoCart.aspx?&ProductID=78298&ProductQlfr=GEN $5.34
    Part Mfg: GENERAC Part Number: GEN 78298 This Part has been superseded arrowdown.gif Part Number: GEN 080270 Price: $5.34
    When you do parts searches in the future for your generator use 9856-0 (Powerplus 5000Watt) for the model number.
    You can also order the 080270 tank valve here:
    http://www.jackssmallengines.com/searchdb2.cfm
    If you enter the part number on the search page.
    $4.60
    Thanks for using FixYa.
    Kelly
    Jun 10, 2010 | Generac 13,000 Watt / 13,000 Watt Home...
    I have a generator that does not produce any volts. I replaced the brush block because it was bad with no help. I took resistance readings of the rotor and stator. Are these in spec?? briggs and stratton...
    As long as you have continuity through the stator and rotor windings, and no continuity from the windings to the core, you should be good.
    If the brush block was replaced due to it being defective, take a look at the diode and capacitor regulator as well. Using a multimeter, the diode should indicate continuity in one direction, infinite resistance in the other. If you get this, then replace the capacitor. If not, then replace the diode, and likely the capacitor as well.
    May 28, 2010 | Briggs & Stratton Electrical Supplies
    I have a Generac NP-50G Generator with a broken push rod
    The push rod should just go back in where the broken one was. They set into the tappet almost automatically. You can slowly spin it over to verify. I'd replace both push rods if it where mine.
    This is a generic OHV " How to adjust the Valves" YouTube video which should take you thru the process.
    Change the oil. Check/adjust the valve clearance at least yearly.
    How to Adjust Valves on OHV Small Engines Valve Clearance lash
    Sep 19, 2017 | Sport & Outdoor - Others
    What carb does the powermate 6875 use?
    Mar 24, 2009 | Coleman Powermate Powermate 5000W...
    Need carburetor part # 1481K10 for Tecumseh cast-iron sleeve 10hp
    you could try a briggs and strtton dealer as they took over generac but think with it being a tecunseh engine you will have a big problem as that side of the company went under a few years back,sorry cant be of more assistance
    Dec 21, 2008 | Electrical Supplies
    Electrical Supplies Logo
    Top Electrical Supplies Experts
    Craig Butler
    Craig Butler
    Steve
    Gene Haynes
    Are you an Electrical Supply Expert? Answer questions, earn points and help others
