Question about Car Audio & Video
I just bought a planet audio amp from a friend,and the protection mode light keeps coming on.What could be the problem?The amp is a 150x2.
    Master:
  • 444 Answers
Not connected up poperly.
Posted on Oct 27, 2012
5 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: protection light keeps comin on
Unfortunately, P/A does not release schematics - even to repair techs. You have to find a knowledgeable repairman, or ship it to P/A.
1-888-990-1236 for support, and RA# info.
Plan to be without your amplifier, as NEW WARRANTY repairs are backlogged approx. 6 mo.
Rule out external problems by hooking it up to an isolated bench power supply.
If planning on doing your own repairs, see this site for info.
P/A has an ONLINE SUPPORT WEBSITE to order parts etc, and may be a useful resource as well. Do some fishing, and you may find what you're looking for.
I will too, and post any findings.
Posted on Jan 19, 2009
etirbynnor
  • 655 Answers
SOURCE: Protection light keep coming on
Make sure your head unit is off.
Reset the amplifier using the manufacturers specified method. Usually this is just power down briefly and then back up. I usually pull the amp fuse and make sure all LED's on the amp go out. Wait 10 seconds, and then put the fuse back in.
If the LED comes back on when you reconnect power, without the HU being on, you've got a bad amp.
If the LED does not come back on after reset, then check for short circuits on the speaker leads. Still leaving everything off, from the amp terminals, remove both wires to a specific speaker and check for shorts.
Posted on Mar 24, 2009
spoopavitch
  • 40 Answers
SOURCE: THE PROTECTION LIGHT COMES ON
make sure your ground is drilled threw thick metal and the paint is scraped off and make sure that all the wires connecting the amp are 4 gauge or higher and if that doesn't do the trick get a better amp that can throw more power
Posted on Apr 01, 2010
jryc32
  • 408 Answers
SOURCE: Protection light is on my REM 4300 planet audio
That means that 2 wires must have touched and the protection light came on to prevent further damage.. There is usually a reset button somewhere on the amp and pressing it should reset that light
Posted on Sep 08, 2011
Protection light came on what cut off
Amp in Protection - Troubleshooting - Basic Car Audio ...
www.bcae1.com/.../troubleshootingbasicsampinprotect.htm
Some simply shut down and the power light will not illuminate when in protect mode. If the power light blinks then goes off, the amp is either going into protect ...
How do I fix my amp it keeps going into protection mode ...
? 2:00
https://www.youtube.com/watch?v=DQ1bdsm6s2c
Apr 24, 2013 - Uploaded by Nathan West
My MTX 600xd amp light won't even come on. ... Red light comes on. ... one.. and some times it goes into protection... once I turn the car off...
Jan 11, 2016 | Car Audio & Video
Planet Audio PX1500M Amplifier Problem
Check the FUSE to ensure that current is not cut off.
Jul 16, 2013 | Planet Audio PX1500M - 1500W MOSFET...
Why this planet audio protection light always comes on when i turn up the car audio
The amp in question is a very entry level amp. Meaning it needs to be ran at moderate ohm load. And have plenty of power to feed it. Check your grounds. Pos. Etc.
Feb 03, 2013 | Planet Audio AC1500.1M ANARCHY CLASS AB...
I have just bought a planet audio ap1500d and when i hooked it up the protection light turns on not the power
disconnect any woofers and retry the ignition sequence (if still in protection get yourself a digital multimeter and check to make sure you have @ least 12volts of power (if under 10 volts the amp will go in protection from under voltage)and good ground as well as remote if you do have all these things return the amp where you bought it or have it checked out) if the amp works you have a blown woofer
Sep 04, 2010 | Car Audio & Video
Red protection light
make sure amp is not grounded out or shorted out like if u miss and touch ground to power or the other way around protect light usaully comes on be resets once u turn the amp power off then back on . if that don't fix it maybe ur amp needs some repairs inside.
Jun 06, 2010 | Planet Audio VX4002 Car Audio Amplifier
What does the red and green light mean ???
red and green light? there is most likely a protection and a power light. The red I assume would either be a protection light or a clipping light signal. Does the amp kick off then these lights kick on red then to green?
May 31, 2010 | Planet Audio VX4002 Car Audio Amplifier
Mar 21, 2009 | Car Audio & Video
Vx4004
More than likely, your speakers are wired up in such a manner that they are creating more resistance than what the amp can handle. That's usually what puts amps into protect mode.
Car speakers should be 8ohm's resistance, but if you're bridging and running a dual voice-coil sub or two subs in series... you could have inadvertedly wired it up so the amp is seeing 4 or 16 ohms of resistance? (depending on which way you went)
Try removing the speaker wire completely, then turn the amp/car on and see if it still goes into protect.
Aug 22, 2008 | Planet Audio VX4002 Car Audio Amplifier
My amp protection light keeps coming on
If the amp is in protect mode, it probably has shorted output transistors. To eliminate other possible problems, read through the following page.
Amp in Protection Mode - Troubleshooting
Let me know if you have any other questions.
Aug 10, 2008 | Sony XM-460GTX Car Audio Amplifier
Kole audio q1-3000d
This amp is similar to many of the planet audio class D amplifiers. These amplifiers have quite a few problems. If the amplifier has failed, it needs to be serviced by someone who is familiar with the amplifier.
Do not repeatedly replace the fuses. It will lead to more damage and a more expensive repair.
Nov 12, 2007 | Kole audio Q1-3000D Car Audio Amplifier
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
