Question about Frigidaire FRT18FS6C Top Freezer Refrigerator
Icebox not cold - Frigidaire FRT18FS6C Top Freezer Refrigerator
  • Official Brand Answer
  • 4,342 Answers
Hello - From what you have described it sounds like you might be experiencing some form of sealed system issue or a bad door seal. This can include the compressor not working correctly, the evaporator fan not turning, or even coolant in the lines not at the correct levels to properly cool. If the compressor is running, humming, or even a little warm then that is typically normal. However if the compressor is running hot, then it is over working and the issue could be before the compressor in the evap fan, coil or coolant lines. When was the last time you cleaned the condensers? You may do so by removing the toe grille and use extended vacuum attachment and condenser cleaning brush to remove dust buildup from condenser coils usually located on the left side underneath. If you hear the compressor running and if it is providing warm air then that means it is operating correctly and the sealed system is removing heat from the cabinet. Fan motor/evaporator may be the primary issue. However, if you do not hear the compressor and the unit is blowing room temperature then the unit may possibly have a sealed system leak, faulty compressor or overload relay. Try checking if the door seal is bad; place a dollar bill between the body of the freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check the door from closing then replace the gasket. If any proves to be ineffective, you would need to contact your manufacturer and then a professional to move forward accurately.
Posted on Nov 01, 2012
Icebox Not cold
What is the model number?
Oct 27, 2012 | Frigidaire Refrigerators
I have an under the counter integrated fridge with icebox model -Zanussi ZUD9124A The fridge is working fine, however the icebox has stopped working. The other thing i've noticed is that even if i turn...
You need to check on the FREON gas that is necessary for the production of cold energy. If the gas has leaked out, there could be a bad line connection or a pin hole in the line. A technician has the gauges necessary to test lines and gas issues.
Jan 12, 2018 | Zanussi ZUD9124 Compact Refrigerator
Kenmore refrig/freezer. freezer side is cold,
Check your condenser coil (should be below the refrig.). If dirty, you can clean it with a condenser brush from Home Depot or Lowe's. Turn the appliance off while cleaning. Be careful not to damage the refrigerant tubing (copper). If this doesn't solve the problem, then there may be an issue with the defrost thermostat, defrost heater(s) or the main temperature control assembly.
Contact an appliance service company.
Feb 17, 2010 | Kenmore Refrigerators
Kenmore cold spot
The reason to this problem can be due to the
faulty defrost.
Sep 02, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Wireless connect for icebox v3.0
I have no power light comng on when I try to turn on the icebox computer... can anyone tell me any company that could try to diagnose and fix this as it is only 1.2 years old
Jan 12, 2009 | IceBox CT04 12 in. TV/DVD Combo
Ice box
you have a leak or the compressor is not starting,you need to pull the frig. out and see if you see any oil on the lines this would mean the freon is leaking out,also put your hand on the comp. and see if you feel it running if not you would need to go to your local appliance part store and get a 3in1 start kit and install it ,it's easy the directions are to the part,hope this helps you-mike
Oct 26, 2008 | Kenmore 53642 / 53644 Side by Side...
Icebox repair
Try www.lordantech.com . Icebox dealer in NJ, when that company was in business.
Aug 26, 2008 | IceBox IBFS1 LCD Television
Ariston fridge freezer - drips water
I'm afraid if the door isn't sealing properly and staying cold then the ice will always be melting somewhat and dripping. Is there ANY way to glue/epoxy/fiberglass that part back on or repair the door, etc.? If you can't get repair parts either you may be stuck with a broken cooler. It seems like some shop (boat shop, auto bodyshop, etc.) should be able to repair those items with fiberglass or something. I guess it just depends on the cost to repair verses to buy new again.
Jan 23, 2007 | Ariston Technologies CBC96 Wine Cooler...
Frigidaire FRT18FS6C Top Freezer Refrigerator Logo
60 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
