Mai 945GCM7 bios
Bios in bin file
  • 1027 Answers
SOURCE: kta pro v1.0 bios problem
You are right - a new BIOS upgrade should give the proper displays. Go to the motherboard's manufacturer's website to download the latest bios.
Posted on Sep 01, 2008
SaintGene
  • 53 Answers
SOURCE: how do I flash my bios on ca63-sn rev. a1
mail755,
Before I continue, I have to tell you that upgrading the BIOS firmware required extra care.
U need to check if you r using the correct firmware or not. If you are not sure, you can download it here.
http://img.lanparty.tw/Upload/BIOS/CM/CA63ESN0319.ZIP
after you have the correct files, you need to have the correct environment to upgrade the firmware,
here's the instruction to make a bootable USB Pendrive for the BIOS firmware upgrade.
http://tw.dficlub.com/tw/modules/newbb/viewtopic.php?topic_id=1837&forum=27&post_id=6679#forumpost6679
When you are boot into the DOS environment, you will see the A:\ prompt, you need to type in this in order to let the upgrade to proceed,
A:\>F780.exe 2A6LGD4N.bin
I have follow the exact filename of the files that you are goinn to download.
These will be the procedure to upgrade ur BIOS firmware. Please be sure that you are understand before you proceed, of not, you can post a comment here and I will follow up to explain to you.
Good Luck,
Don't forget to rate my solution, thanks.
Posted on Jan 15, 2009
Geekman
  • 32281 Answers
SOURCE: i want bios driver (bin file) for my intel destop
The BIOS bin file is a BIOS upgrade file. It is used to flash the BIOS to upgrade the BIOS version.
This file is has to be downloaded from the motherboard manufacturer's WEB site.
Posted on Jul 24, 2009
Geekman
  • 32281 Answers
SOURCE: Bios ROM checksum error (Compaq SR5237CL with M2N68-LA MB)
A BIOS checksum error can be caused by a nearly flat BIOS battery.
I would replace the BIOS battery first before attempting to upgrading the BIOS.
Some motherboard BIOS firmware is upgraded by running a program that has been copy to a DOS boot disk or the upgrage maybe done from within the BIOS setup. These firmware upgrage and instructions are on the motherboard WEB site, in your case the Compaq/HP WEB site. Make sure you select the upgrade for your model motherboard.
NOTE it is possible that if you make a mistake you could ruin your motherboard, if you are not sure seek help from a computer savy friend.
Use this link :-
http://h18000.www1.hp.com/cpq-country/cpq_support.html
Posted on Sep 17, 2009
  • 13433 Answers
SOURCE: Foxconn 45cmx mainboard does not have any BIOS
It depends on what bios the machine has, there are recovery procedures, atleast on laptop bioses. That when a set of keys is pressed it reads the bios image from a floppy or from a usb stick / cd and flashes the bios automatically.
Look online for Bios recovery (find out what bios you have, ami, phoenix, etc and then look for _____ bios recovery)
Posted on Oct 20, 2009
Do you have bios flash file (bin file)?
http://www.lg.com/lgecs.downloadFile.ldwf?DOC_ID=KRSWD000003451&ORIGINAL_NAME_b1_a1=UL1F3G41_UI.zip&FILE_NAME=KRSWD000003451-b1-a2.zip&TC=DwnCmd
DOWN LOAD BIOS FILE EXTRACT ZIP FILE AND INSIDE EXTRACT EXE FILE WITH WIN RAR AND RENAME UL1IA32.FB FILE AS UL1IA32.BIN
IT IS BIOS BIN FILE
May 05, 2014 | LG X130 Netbook
Tip
Intel 845gvsr mainboard no display problem
this problem is normal because of the BIOS chip failure normally
symptoms:
when u get ram out and start computer it gives beeps and when u put back the ram and power on PC it gives no beep no display.
Fix the problem:
tools required:
1. hot air gun
2. 512kb fresh bios chip/ if the old chip is right then no need of newer one
3. p3 mainboard (with the BIOS socket) for reprogramming the chip
4. dos bootable hard disk
5. bios bin file.
have not the file ,
don't worry: this file can be made from the bios chip of a working mainboard using the bios flash utility.
flashing software: best is Uniflash.
Procedure:
1. with hot gun, get the bios chip out of the board,
2. reprogramme the chio with correct bin file.
3. put the bios back
Reprogramming:
copy the file in dos bootable hd
run the hdd on p-3 board
pull the bios out of running board (with slight care)
put the 845gvsr bios chip in place of p-3 bios
run uniflash and flash the bios
power of p-3 computer and get bios out
for how toprogramme bios chip : check the page
http://www.pcnineoneone.com/howto/biosflash1.html
on Jan 24, 2010 | Computers & Internet
Where can i get bios "bin" file for my laptop,dell inspiron 15r 5520
Normally, .bin files of BIOS are not published for public on websites. Contact a chiplevel technician. BIOS.BIN files are the asset of a technician. So you may need to pay.
Feb 16, 2013 | Computers & Internet
Not shutdown
i think you do not now how to flash the bios.
first you need the program "wbflash.exe" also you need the xxx.bin file (thad are the bios data) in the program you have to select the xxx.bin file for update the bios if you have done the program screen wil checq the bios and ask for saving old bios if you say yes than thad wil be done after thad you can update the bios with the new one (xxx.bin)if this are done you computer wil restart and the yob are fixed.
NOTE LOOK OUT !!!! if you do not have the right or rong bin file and you update your bios with it the computer wil restat and wil not turn on than you have a bigger problem and it are not reversebile .
only update the bios if you have problems with the computer other wise leave it.
Dec 13, 2009 | Sony VAIO VGN-SZ740N5 PC Notebook
Bad Bios upgrade on Dell M1330
If you cannot start the laptop, you cannot flash the BIOS. You can ship the unit to me, and I'll recover the BIOS. You can email me at buffalonymann@yahoo.com
Nov 02, 2009 | Dell XPS M1330 Laptop
I want bios driver (bin file) for my intel destop board d915gav/d915pgn
Jul 24, 2009 | Intel D915GAV Motherboard
Gigabyte Motherboard wont flash bios
your bios has been corrupted.
The AWARD BIOS has a similar procedure to AMI. To recover an AWARD BIOS you will need to create a bootable floppy diskette and add the desired BIOS file (we recommend using the most recent). Award BIOS's generally are in .BIN format, where as AMI was .ROM format. You will also add an AWARD flash utility (usually awdflash.exe) and an AUTOEXEC.BAT file.
The AWARD BIOS does not automatically restore the BIOS information to the 'system block' like the AMI BIOS does. You will need to add the commands necessary to flash the BIOS in the AUTOEXEC.BAT file. The system will run the AUTOEXEC.BAT file, which contains the flash instructions.
Note: 12345678.BIN represents the name of your BIOS.
Step by Step:
1. Create a bootable floppy diskette or bootable dos cd /usb drive
2. Copy the BIOS file and flash utility to the disk
3. Create an text file with any standard text editor and add the following lines
@ECHO OFF
awdflash 12345678.BIN /py/sn/f/cc/r
Exchange the awdflash with the name of whatever flash utility you are using, and replace the 12345678.BIN with the name of the BIOS file you are using. The parameters are explained here:
py = program yes
sn = save no
f = flash
cc = clear cmos
r = reboot
Remove disk and restart computer
If you found this useful , please rate below
Kind Regards
1234s282
Jul 02, 2009 | Intel Gigabyte GA-8S648FX-RZ Socket 478...
How can i update bios
hiya
first goto the website of your board maker then download the updated bios, make a bootable floppy disk copy then exe file and the bios file it normally a .bin or .rom file when booted from the floppy run the flash utility with the exact name of the bios file so for instance it wud be
amiflash a123456.bin
hopw this helps
Rik
Feb 25, 2009 | Gigabyte Computers & Internet
BIOS BIN Files
I think Ur pc is ibm ok then go to the website and download for ur product bios and install .
ur in operating system download as exe file (or) download as iso image and then bootable for the bios in ibm.
http://www.ibm.com/support/in/en/
Check the site.
Feb 02, 2009 | IBM NetVista PC Desktop
Pcsx2 software
This is because you're using either A.) The wrong bios file for ps2 emulation ex.SPCH1000.bin (this is a playstation 1 bios) or B.) The bios you (obtained) is corrupted.
Here is a few pieces of info you should note about the bios's in question.
SPCH 30004R V6 (PAL EUR) Bios.bin
Filesize: 4,096kb
SCPH 100000.bin (***)
Filesize: 4,096kb
SCPH 39001.bin (standard US)
Filesize: 4,096kb
As you can see they adhere to a certain file size. All of the above bios's can be located by using google or by using bittorrent sites like this one .::HERE::.
Final Note: You're really at the mercy of the person who made the bios file as to whether or not he did it correctly. As you can see by the info I posted above and untampered bios will be 4,096kb in size. This does not mean that a file larger or smaller will not work. I'm just stating what the norm is. Also note that a PS1 bios file will not work in the PS2 emulator, and for that reason it will not play playstation 1 games at all. (or so the creator of PCSX2 says)
Jul 10, 2008 | Sony PlayStation 2 (PS2) Console
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
