Question about LG WM2688HWMA SteamWasher Front Load Washer, White, 4.2 cu.ft. Ultra Capacity with NeveRust Stainless Steel Drum IEC, Direct Drive Motor for the Ultimate in Durability and Reliability, 10 TilTub for Easy Reach into the Rear of the Drum, UPC 048231009515
How to repair a lg wm2688h*ma with a fe code - LG WM2688HWMA SteamWasher Front Load Washer, White, 4.2 cu.ft. Ultra Capacity with NeveRust Stainless Steel Drum IEC, Direct Drive Motor for the Ultimate in Durability and Reliability, 10 TilTub for Easy Reach into the Rear of the Drum, UPC 048231009515
2 Suggested Answers
SOURCE: LG WM2688H Front Load Washer
I do not have a solution, but have the same exact problem and would like to know if you ever found out where the thermistor is and if you were able to fix it.
Thank you,
Treegirl
Posted on Oct 29, 2007
Need to change stator and rotor assembly in WM2688H*MA
The stator is stationary mounted to the outer tub the rotor attaches to the spindle of the basket which is a shaft that goes thru a bearing to get a definitive answer remove the back panel remove the rotor turn the center bolt till it loosens keep going as this will back the rotor off the stator you will have to pull with a little effort strong magnets to get it off now try to spin the basket by hand if stiff you have a bad tub bearing.
Apr 02, 2014 | LG Washing Machines
My LG front loader is showing an "FE" error. The water seems to continue running into the tub, leaking out the door.
Good morning
I looked this up to make sure I was thinking the right way. The FE means there is too much water in the machine... lol bet you already knew that. Since water is actually coming out of the machine it looks like a bad fill valve. The plastic piece your hot and cold water lines hook into is not shutting off all the way.
I hope this helps
Nov 27, 2012 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Good morning, we have a LG Tromm front loader that started giving us some problems last night. It seems as it will not shut off, the water is continually filling in the machine, and it keeps draining. ...
"FE" means (no surprise here) "Overflow error. The water is automatically pumped out because there has been an overflow.
Since this condition clearly demonstrates that the water level sensor is working fine and doing its job, the very likely culprit is the water inlet valve. You may be locky and find that of you take the valve out, there is an ovstruction in it (sometimes a bit of grit gets trapped in the valve holding it open. More likely, the valve is failing and not shutting once it has opened. You may then need to replace it.
Jul 19, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
What does FE mean? Every load I do it stops and says FE..
Fe should be in the owners manual, it means it is getting too much water in it, could be faulty valve or main board.
Apr 17, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
"FE" error code; won't stop filling
Hello Sheri Tucker,
The "FE" code is referring to a bad or malfunctioning water valve. The machine continues to fill because the solenoid on the valve inside the machine isn't closing to stop the water. The valve should be inspected and/or replaced if bad. This will require some dis-assembly, if washing machine repair isn't something your comfortable with then a service call is the best bet. If you are going to try and inspect yourself please make sure you unplug the machine before starting any dis-assembly. Hope this helps.
Thanks,
edgin96
May 19, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
FE code on LG Tromm washing machine, what is this code?
Hi. this code represents a faulty water valve. I would shut off the tap and inspect the water valve assembly inside the machine. If dissembling this machine is a problem and you are uncomfortable with the disassembling process, i recommend a quick service call. the water valve may have a malfunctioning solenoid.
please rate and god bless.
Mar 24, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Computer display is blank
Suggest you contact store where you purchased item from, or contact repair agent, if you start messing with it , you will invalidate your guarantee.
Nov 30, 2008 | LG WM-2277HW Front Load Washer
LG Tromm front loader-FE error code
The water overfills due to a faulty water valve. The valve needs to be replaced.
Sep 30, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG WM2688HWMA SteamWasher Front Load Washer, White, 4.2 cu.ft. Ultra Capacity with NeveRust Stainless Steel Drum IEC, Direct Drive Motor for the Ultimate in Durability and Reliability, 10 TilTub for Easy Reach into the Rear of the Drum, UPC 048231009515 Logo
41 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
