Question about Rainbow E series Canister Wet/Dry Vacuum
Power head barely turns - Rainbow E series Canister Wet/Dry Vacuum
    Habit-Forming:
  • Rainbow Expert
  • 119 Answers
Need more information but if you are speaking of the brush roll, it is possible that you need a new belt. You should change your belt at least once per year.
RainVac
www.rainvac.com
800-523-0510
Posted on Jun 14, 2013
Brand new dyson DC40 has no suction at bottom
Hi Marin, it's Jack at Dyson.
DC40 is a powerful mid-size Dyson upright vacuums, and we wouldn't expect you to have any concerns about performance on hard flooring or carpet. As long as the machine is used and maintained as described in the User guide we would not anticipate a change in performance, and we're on hand to help if Dyson owners need assistance.
It's important to note that for effective pickup, the cleaner head needs to form a close seal with the floor surface. Simply placing a hand under the cleaner head does not give an accurate idea of suction as you're not creating a seal, as you would be when you place your hand right across the end of the wand or hose. If you turn on and recline the vacuum, turn off the brush bar then lower the cleaner head onto something like a sheet of newspaper, you should see the newspaper held tightly against the soleplate by the vacuum's powerful suction.
We're keen to discuss this with you, and to help ensure your DC40 is working as well as it should be. Please email your full contact details to my colleagues at askdysonUS@dyson.com, and one of our experts will be in touch as soon as possible to provide further assistance.
Feb 14, 2015 | Dyson DC40 Animal Upright Vacuum -...
Power head barely moves
<p>Need more information but if you are speaking of the brush roll, it is possible that you need a <a href="http://www.rainvac.com/belt-pnozzle">new belt</a>. You should change your belt at least once per year.</p>
<p>RainVac </p>
<p><a href="www.rainvac.com">www.rainvac.com</a></p>
<p>800-523-0510</p>
Oct 27, 2012 | Rainbow E series Canister Wet/Dry Vacuum
My broan cv30 purchased in 1996 carpet power head unit sucks up dirt and rocks but will not pick string or yarns up from carpeting. I find myself picking it up. It is sucking fine dirt and small...
It's possible you simply need a new belt or roller brush. Place the power nozzle upside-down turn the vacuum on. Ensure the brush turns. If it doesn't, the belt has broken or is too worn to turn it. Replace the belt. Make sure the tension is properly set prior to reassembling the power nozzle.
Next, with the power nozzle upside down, run the flat of your palm across the brush area. If you can barely feel the bristles, it needs replaced. A good brush will loosen the yarn and strings, but needs to be cleaned periodically.
As long as the powerhead motor is running, there is no need to replace it. If it's not running, look for a reset button and press it. There could also be a broken wire, loose connection, or bad switch causing a power head motor to not operate..
Dec 31, 2010 | Broan-NuTone Vacuums
No suction and rollers not spinning
Hopefully this will help. On the back of the vacuum at the bottom the is a U shaped tube. Depending on what model you have it will either be a thumb release or a quarter turn screw head release. Remove that and check for a plug. Two things can cause the roller to not turn, 1) Broken belt or 2) Shut off switch. On the head, to the right there is a round large knob with a pointer, it must point to the lines (or carpet). If in the other position it is shut off for bare floors. Remember that it automaticly shuts off when the handle is in the upright position.
Nov 02, 2010 | Dyson Vacuums
Dyson DC21 All Floors Stowaway
Simply answer Yes it would be but try and make sure the the old head is clean before dumpin it just in case
Jul 20, 2010 | Dyson DC21 All Floors Stowaway HEPA...
Placing the handle of my Dyson DC07 into its upright and locked position causes the beater bar to stop turning. It will not start turning until the handle is first lowered to the working position and the...
Hi its Darran at Dyson.
The brush control is designed to switch the brush bar off automatically when you stand the machine back into the upright position. It is designed this way to protect any delicate floor surfaces when you have the machine switched on and upright and when you are using the hose.
If the brush control should be in the centre position and move forward to the "on" position when you release the head. If it is not doing this, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dyson Customer Service
Feb 22, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
The knob that turns it from carpet to bare floors makes the head not spin for carpet It was a reburished one. bought in Nov 09
sounds like those wonderful people over at dyson installed the clutch and cover on wrong. it should be fine just use it oposite.
Dec 30, 2009 | Dyson DC07 All Floors Bagless Upright...
Vacuum not picking up dirt
The neck in your power head is likely clogged. Disconnect from the wand and look inside. Also check the wand.Since you have suction on the bare floor the hose is likely not blocked.
Sep 11, 2009 | Kenmore 22512 Bagged Canister Vacuum
Rainbow E series Canister Wet/Dry Vacuum Logo
285 people viewed this question
Top Rainbow Vacuums Experts
Joseph Hoffmann
JoeVacs
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
