Question about Jacuzzi Pool & Spa
I have a very old Jacuzzi hot tub with an FPI spas control box #EP110. Where can I find replacement parts?
3 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: caldera spas hot tub
Remove all pwoer and then gain access to the heater probe. Read each probe from the center connector treminal to the metal base with an Ohm meter. There should be no reading. If you have low reistance the probe is internally shorted and will need replaced. It is a common failure for a heat probe. If the probe is bad when you do buy a replacement buy the "Coated" element. The extra $15.00 is well worth the investment in the overall lifetime of heating element service.
Replacement elements can be found here
Thanks for using FixYa.
Kelly
Posted on Mar 22, 2010
SOURCE: Can't unlock jacuzzi hot tub control panel
control panel not working, cannot control or work control buttons, stays in econ mode all the time. Nothing else works.
Posted on Dec 22, 2010
My client buy jacuzzi whit light and water jets but is not working the main control not turn on curse water in the plug all connections and not working..not guide any instructions
Jacuzzi Is STILL a viable SPA / Whirlpool Entity...
If you know the age of the equipment...
It may actually date back to when Jacuzzi
headquarters was right here in the San Francisco Bay Area.
Now SFSpas.com ... 510-527-5547
Paradise Valley Spas The Bay Area Top Hot Tub Retailer
Richmond, California (to be specific... (on Jacuzzi Street)).
((I was sad when they left).. but am still a happy customer).
Air "switches" remain their most popular trouble...
and if you know what yours LOOKS like... you
can VERY LIKELY still buy the parts from eBay...
I
recommend going to Jacuzzi... (opinion).
Carnac the Magnificent
Aug 09, 2017 | Jacuzzi Home
Need indicator rings for 3 controls on U640959 Jacuzzi bathtub. These are flat rings 1.5" ID, 2" OD. The two for the air have 5 circles. Also need the on-off ring.
Good luck Scott Jones...
I've been looking for some specifics on Jacuzzi (seacrest) faucets... for a couple of years...
Since before Jacuzzi moved out of the EAST-BAY area (here) they had pretty good stuff.
I have their "washerless" ceramic faucets..
Through trial & error I've been able to keep these working...
No thanks to the so called "Jacuzzi" (moved out of CALIFORNIA).
Not only were they not helpful when I told them I didn't want their NEW STUFF...
I only wanted to service what I've had for 30 years
(controls sound like what you have)
Try calling these folks... At least they know what JACUZZI used to mean... GOOD STUFF:
Jacuzzi of El Cerrito ... (510-) 527-5547
5327 Jacuzzi St Ste 2c,
Richmond, CA 94804
Toll FREE... Call 888-738-5523
Hope this helps.
Hot Tubs Swim Spas Saunas in California Sales Service Paradise Valley Spas
Jacuzzi Whirlpool Bath JWB 1 2 Air Volume Control Elbow PA54000 U775000...
Dec 05, 2016 | Jacuzzi Home
I need to find a service man in the Seattle area to get my tub working. It has power but won't come on.
then look in a phone book for a plumber . I am sure there are more than 1
Feb 11, 2016 | Home
6 month old jacuzzi hot tub has started leaking intermittently , any help here to solve this problem
remove front panel visually inspect pumps to see if leaking if ok check by control box remove cover inspect where plumbing runs through keep eliminating thing until you find it
Sep 02, 2014 | Dream Maker Spas Dream Maker Ez Spa Hot...
Jacuzzi hot tub, Water is too hot. Heats until it trips the system. I have replaced the analog temperature control,
1) Safety question first
Why hasn't the GFCI tripped.
If your spa is not protected by ground fault., then you are at serious personal risk.
http://waterheatertimer.org/How-to-wire-GFCI.html#arc-fault
2) Replace the element.
http://waterheatertimer.org/How-to-test-water-heater-element.html
3) If element is cracked, it can continue heating to ground wire, causing runaway heating.
This applies to spas, and water heaters of all type.
Dec 08, 2012 | Jacuzzi Pool & Spa
My hot tub top control is flashing SPA6,and hot tub is not heating up.
Here is a link for you to resource that error code.
click that link and scroll through them until you find your error code.
Rod
US Parts Center
Aug 19, 2012 | Jacuzzi Pool & Spa
Hello,I have an old jacuzzi vectra II hot tub (1988) 120 volt.the gfci on the unit trips every time the pump is on low speed with the thermostat calling for heat. there is no trip when there is no demand...
hi,
ok so when the pump is on high and the heater is running it doesent trip? you didnt say if it did. undo the heater leads so the pump is isolated completely. run the pump on the control centers gfci and see if it trips. if it does then try wiring directly - with an extension cord to a plug with a gfci in your house and see if it trips the gfci in your bathroom. if no trip inside house then bypass tubs gfci and run it with heater and pump through your bathroom gfci. if no trip then try and replace the tubs gfci, it gets pretty humid in the control center and gfci's have a semiconductor which which do fail after years of rough duty like that. if it trips the gfci in your house with the heater again it has a cracked heater element. craigslist always has old hot tubs and parts. you might have to buy a whole used old hot tub but that may be cheaper than a new heater box.
later
jm
Feb 22, 2011 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
I have a Jacuzzi Z110 hot tub. the top control is broke (pn 51422). Can i use a digital top control PN 33334.
When dealing with a big manufacturer like Jaccuzzi, it is unwise to swap top side controls. They make theirs proprietary on purpose so that swapping is more difficult (especially jacuzzi).
If you use the wrong one, the buttons on the controls will be misleading (such as temp up button cycling jets, or the ozone button cycling the lights, etc)
I would use manufacturer part.
Oct 01, 2010 | Qca Spas Jewel Series Topaz Plus Hot Tub
Need a users manual
Kathy,
I think what you're looking at are the part numbers for the heater and control systems used in some Jacuzzi hot tubs rather than the Jacuzzi model number. I ran into the same issue and discovered through some cross-referencing on the web (jacuzzi parts suppliers) that this is the part number control unit made by Balboa. Odds are they were used in multiple Jacuzzi models.
My suggestion: Look here http://clearcreekspas.com/model_id.html to identify the control panel for your Jacuzzi and then follow the link to the correct manual. Some cover multiple models so you will need to know the electrical requirements of yours (120 V or 240 V?) and then check the layout of each tub shell to determine which model is yours.
I figured out mine is a Jacuzzi Essence Model 350 this way.
Nov 11, 2008 | Balboa Instruments Garden
Pool & Spa Logo
134 people viewed this question
Top Jacuzzi Pool & Spa Experts
Jay Finke
Jay Finke
Mike
john h
Are you a Jacuzzi Pool and Spa Expert? Answer questions, earn points and help others
