Question about Acer 17" AL1706B LCD Monitor
What are bad caps
Monitor not working blue flashing light and flashing light on power source
    Genius:
  • Acer Master
  • 2,432 Answers
You will noticed if the capacitors at the power supply board is bad if has bulged to its casing or blown up. but sometimes even with out sign of bulged but its leak, you can determined this by using a capacitance meter.
Posted on Oct 28, 2012
3 Suggested Answers
tantong
  • 138 Answers
SOURCE: Flashing Blue power light
Hi this is the way how to examine what's wrong with your LCD monitors. After you turned it on and the screen went black or stopped working, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Posted on Mar 26, 2008
budmrtn
  • 11361 Answers
SOURCE: Power button light flashes (blue flashing light)
You may have problem in the power supply section, that wil be the first place to check. Look for caps with bulging/leaking tops first.
Please see my photo albums so you will know what to look for.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 19, 2010
My acer x203h power light flashes yellow and blue
unplug.
take it apart.
look at the Caps.
if the end is bulging out, then it is bad.
replace bulging ones and/or all of them.
get replacements at www.mouser.com
if you have any questions about the caps, they are very helpful.
desoldering wick is helpful, but not necessary.
I have repaired 2 monitors with similar problem by replacing bad caps.
Aug 15, 2012 | Acer X203H bd Monitor
Have A Samsung 940Bw connected via DVI connection and has worked fine for last 3 years. Monitor was on and working fine went out of room and came back to black screen and the blue light flashing on the...
First thing I would try will beusing this monitor with another PC using the same the same setup to see if it works OK. We need to narrow down the cause of the problem first since you have three parts that can be bad; Monitor, DVI cable, PC Video card/PC. It is just a process of elimination to locate the problem.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Apr 14, 2011 | Samsung Syncmaster 940BW LCD Monitor
Two capacitors on my Viewsonic VG2021m popped so had them replaced, no others appeared even slightly dommed to signify they had blownm though the monitor still isn't working. Plug it in to the wall and...
Bad cap can look normal but can have high ESR, I always replace them in a set, and you should use LOW ESR type with 105c rating since we are dealing with switching power supply here. Look at the bottom seals also.
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VG2021/
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Jan 05, 2011 | ViewSonic VG2021m LCD Monitor
LCD model viewSonic vx2235wm 6 months out of warranty, When powered up, the backlight will flash, but then screen is dark. The blue light at the bottom is on and Vista recognizes the monitor. Sometimes, I...
Are you sure about no bad caps? The top of the caps have to be completely flat, and bad caps can also look normal but can have high ESR, you will need meter that can read ESR of the caps.
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX2235W/
Post the pictures of the board and caps.
Sep 05, 2010 | ViewSonic VX2235wm LCD Monitor
Monitor will not come on, blue light just
Check for leaking/bulging caps in the power supply first.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Jun 02, 2010 | Samsung 204T 20" LCD Monitor
It takes an hour or two to come on blue light
Power supply caps should be checked out, look for caps with bulging top first, post back what you see so we can guide you further, see example of failed SAMSUNG monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 26, 2010 | Samsung SyncMaster 540N 15" LCD Monitor
Monitor appears to be in permanent standby mode - - black screen and blinking blue power light. It is a Gateway FPD2185W monitor. It will not turn off or on. Unplugging and re-plugging changes nothing. ...
Look for bad caps with bulging top in the power supply. I would replace all 10 with PANASONIC FM or FC series from DIGIKEY. Post back what you see inside so we can guide you further, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 22, 2010 | Gateway FPD1975W 19" LCD Monitor
Monitor problem
The power light is flashing green can indicate start/restart of the power supply due to shorts circuits or failing power supply due to bad caps, look for bad caps with bulging top first, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see insdie so we can guide you furhter.
Feb 20, 2010 | Acer 17" AL1706B LCD Monitor
Computers & Internet Logo
121 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
