HOW TO SOLVE hp officejet 6500a c2fe0165 error
mariolands
  • 2296 Answers
SOURCE: How to unjam a paper
Depending where the jam is you need to follow the appropriate solution. There's also a video on HP support website on how to clear a paper jam out of your HP Officejet 6500A Plus printer: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02441153&tmp_task=solveCategory&lc=en&dlc=en&cc=au&lang=en&product=4083977
Posted on Feb 13, 2011
SOURCE: Cannot print on regular letter size paper on my HP
I had same problem. Try this: When you go to print, change your ink quality to "draft". For some reason, I was able to print after trying everything. Hope this works for you!
Posted on Feb 18, 2011
elix0411
  • 3530 Answers
SOURCE: hp officejet 6500A printer won't
Welcome to Fixya
Looks like this is a common issue for this printer when printing checks. Go to printer preferences from the print dialog, and then set the printer paper to "Other Inkjet Paper" and try to print again.
Thank you for using Fixya!
Posted on Apr 03, 2011
  • 1570 Answers
SOURCE: hp officejet 6500a plus error
Hi try these solutions.
Go to START MENU
Choose Commamd prompt, right click mouse and run as administrator (You should be in this command C:\WINDOWS\SYSTEM32- If not type this command when you in the dos command prompt "CHDIR C:\WINDOWS\SYSTEMS32\ and press enter")
Type the letter "cmd"
Type the word "net stop spooler"
Exit
Go to C: drive
Choose to Windows Folder
Click show content
Choose system32 folder
Choose spool folder
Choose printer
And delete all printing jobs pending
Again go back to CMD window and type the word "net start spooler"
Restart your computer and must also turn off your printer and then switch it on.
Please try this solution.
Remove the USB cable into the printer and leave the printer on.
Remove all the cartridges.
Close the cartridge door and wait for the INSERT INK MESSAGE to appear.
Disconnect the power cable and from the power source supply.
Move the carriage using your hand from the original position to the other side of the printer and then move it back to original position. Wait for couple of minutes
Reconnect power cord and turn on the printer.
Return all the ink cartridges and close the door. Wait for the calibration process.
Print the test page to check if it working.
Reconnect the USB cable and try to print again.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
Posted on Apr 18, 2011
manoshar282
  • 94 Answers
SOURCE: how to check ink levels
If your Printer software is installed on your computer only then you can see Ink levels.
Open HP solution center (Start - All Programs - HP) Goto Maintainence and check Ink levels
Posted on Jun 21, 2011
Hp officejet 6500a touch screen not responding
Is the screen damaged or has water stains? If so power off the machine, use a dry microfiber cloth and gently wipe the screen. If the screen is still unresponsive, do a factory default reset - you will find this procedure in the manual.
Oct 16, 2014 | HP Officejet 6500A Plus Wireless...
Hp officejet 6500A giving an error code 0x61011bea
Is the error displaying on the printer... Have you connected the printer to the computer.. Whats the OS on tge computer
. try disconnecting the printer andcheck for the error messages..
Feb 09, 2014 | HP OfficeJet Office Equipment & Supplies
Hp officejet 6500a. ADF's (Auto-Document-Feeder's) little "grabbing" device won't work.
Try cleaning the roller off with a qtip and some isopropyl alcohol. If that doesn't work then you will likely need to replace the roller.
Sep 20, 2013 | HP Officejet 6500A e-All-in-One Inkjet...
HP Officejet 6500A Printer problem. Ser.No.
Try reset the printer after you have cleaned the printheads. http://www.youtube.com/watch?v=31TbWMrTaFk
Sep 18, 2013 | HP Officejet 6500 AllInOne InkJet Printer
How to open and replace the ink cartridge from my 6500a plus
Simple, turn on your HP OJ 6500A printer and open top cover...carriage should move to cartridge access position. If not, then the service station may be in the way or the PRINTHEAD assembly is not properly locked down causing an error condition. Power supply could also cause this kind of failure.
For information on North American ink refill services (i.e. HP920 and HP920XL ink cartridges) at a major retailer near you (should you wish to save ~50% on ink costs), general printing problem resolutions or advanced HP Officejet 6500, 6500A, 6500A Plus, 7000 and 7500A printer diagnosis procedures (advanced cartridge diagnostic tests/cartridge error bypass & printer reset methods, etc.), please visit Inkjet411: http://www.inkjet411.com
Jul 13, 2013 | HP Officejet 6500a Plus E710n Printer...
Hp 6500a plus printhead won't print
As you said that you have already cleaned the print heads it could be the contacts inside the printer has gone bad. Its suggested by HP that if you get any error regarding the print head you should contact them and they will replace the printer. Please do so. Thanks.
Dec 19, 2011 | HP Officejet 6500 Wireless All-in-One...
Hp officejet 6500A Plus error message paper size is incorrect. Cannot get anything to print!
On your PC, what is the default setting for this printer. Check in the printer and accessories of Windows.
The paper size might be defaulted to A4 rather than Letter. That mismatch would cause the printer to
error out every time.
Mar 23, 2011 | HP Officejet 6500 Wireless All-in-One...
How to unjam a paper jam in an HP Officejet 6500A Plus
Feb 13, 2011 | HP Office Equipment & Supplies
206 people viewed this question
jasbo
jasbo
