Question about Samsung Cell Phones
My phone samsung omnia pro gt b7330 is not turning on
It was flat when i put it on the charger it just beep and it went off now it is not turning on even when i put a charger it not showing that it is bieng charged it not showing anything
  • Samsung Master
  • 14,641 Answers
MY dear Your Phone Ringer Default So Please change Ringer
And Ringing Sound Problem will solved
Posted on Oct 30, 2012
  • 94 Answers
SOURCE: Low Battery, Connected car charger, now is dead
May be the battery won't have charge, keep 1 or 2 hrs continues charges, and if it is not working then you have to replace the battery set full.
Posted on Jul 04, 2009
270rexton
  • 782 Answers
SOURCE: samsung omnia problem trying to charge battery
It looks like battery is damaged... When plugged in to charger phone shouldn't power on. Try put it on charger when on and see if charging icon appear. (top right corner-battery status icon should change -insted of battery to charging.) Battery is fully charged after cca 4 hours, 80% after 2 hours.
Posted on Jul 16, 2009
Ammu9966
  • 410 Answers
SOURCE: samsung omnia pro b7330 how
Go to Setting then to phone setting then select language option from the menu n select your prefered language click ok.......n go back,.
Posted on Feb 06, 2011
  • 4 Answers
SOURCE: my Omnia pro B7330 Samsung
We hope to meet my boyfriends .. hahahaha
Posted on Feb 21, 2011
SOURCE: My Samsung Omnia Pro B7330
Solution is next, and i found it on xda-developers site, all thanks and credits to member xkaiser!!!!! Just go to this folder on your phone: my device/application data/Volatile and delete all 999 empty folders!!!! Dont worry about system, these folders are just temporary cache, it will not damage your system, but it will bring back your WMP and all ringtones!!! i tried and it work!!!!!! If you want to thank a man for resolving a problem, go here: http://forum.xda-developers.com/showthread.php?t=628968 He even made a cab file, after installing his file, just soft reset the phone and problem is solved!! Hope i helped
Posted on Feb 23, 2011
If the batteries needed changing would the green charging light still come on and would the alarm beep when attached to scooter and turned on?
Yup. The alarm beeps if you have the charger plugged in and turn on the key even if the battery is flat. The charger won't bring a totally discharged battery up to full charge. You can charge the battery individually using an automotive style battery charger. The charger should NOT be the automatic type. It may take some time to recover a flat battery. Charge it until you can see at least 10 volts on the battery. The scooter charger can then finish up the charge. If after you go through all this and the batteries will not take a charge, then it's battery time.
Nov 20, 2015 | Health & Beauty
Why did my RCA 10 inch tablet power down and now will not turn back on? It does not show any sign of charging - no battery symbol, no lights, nothing.
battery have residual power which last few minutes to allow safely switch off, as you used this power, it shut down. this residual reserve is usually between 3% to 5% of capacity.
and do not fiddle with it till you recharge it, reset will not work while there is no power, any other "trickery" will not work either.
now, plug battery to known good charger and charge it for 24hrs, do not switch it on during that time nor disconnect from the charger.
after this it should be starting and working normally, if it does not - it is still under warranty and you should return it to the place of purchase for repair or replacement, even if you do not have receipt. tablet have it's serial number and can be traced in the store to day, and even hour and minute when it was sold...
hope this short info will help you - do not forget to vote...
Feb 02, 2015 | Tablets & eReaders
My phone is not turning on at all
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Oct 27, 2012 | Cell Phones
Samsung sgh-a707 won't stay on. Shuts off when batt seems full.
try to go to a local store or through your service provider to run a test on the battery that you are using. It might be defective, tyr using a different battery for the phone. If using a different battery would not resolve this issue, it means that the phone needs service.
Jun 27, 2009 | Samsung SYNC SGH-A707 Cellular Phone
We have charged the battery and when we turn on the scooter all it does it make a beeping sound and the scooter will not move
So the Battery charger is showing a green light (Fully Charged ?) Can you tell me the MAke and Model of the Scooter ?
Jun 12, 2009 | Pride Mobility Products Go-Go Elite...
My Acer Aspire 1710 failed to boot and no Acer logo
use my acer aspire daily, went to put a memory stick in and it just died, no power at all but power light on charger still showing green
Feb 01, 2009 | Acer Aspire 1710 Notebook
Wont start
Sound like a bad battery, The battery wont hold a charge, needs to be replaced. good Luck
Dec 28, 2008 | 2003 Nissan Maxima
Cell Phones Logo
100 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
