Question about Cell Phones
My phone is not turning on at all
Battery was flat when i put it on charger it just went off now it is not turning on even when i put on charger it does not show that it on charger red button also not on what can i do.
  • 580 Answers
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Posted on Oct 28, 2012
tamilselvan
  • 45 Answers
SOURCE: My phone will not show it charging and will not turn on, red light flashing
dear
you have mentioned that ur phone is charging and not getting on. that means ON\OFF path is having problem .due to dry solder of ON\OFF switch its happening. please resolder it and then check it
Posted on Nov 07, 2007
  • 4 Answers
SOURCE: my sony ericsson phone wont turn on
When i connect cable USB Sony Ericsson in my computer it have problem and error, can not open it.
How to format short cut key in Sony Ericsson W810i.
Posted on Aug 01, 2008
Bajanguru
  • 7752 Answers
SOURCE: W850i red light prob
not to worry this is a fixable problem..............take te phone to a mobile shop and have them reflash the firmware n custom pack back into the phone and this will correct the problem....the erom needs to be loaded back on the phone.
Posted on Dec 26, 2008
SOURCE: unable to turn on and showing red light
the same happened to me the battery has had it get a new battery and it should work
Posted on Mar 17, 2009
SOURCE: phone will not turn on unless it's plugged in
The battery has a short in it and if you replace it The phone should probubly work.
Posted on Mar 22, 2009
My phone samsung omnia pro gt b7330 is not turning on
MY dear Your Phone Ringer Default So Please change Ringer
And Ringing Sound Problem will solved
Oct 27, 2012 | Samsung Cell Phones
Phone Fired
Phone, you need a new one, fatal error, means something inside of your phone is fried. Charger, are you sure the outlet is good for electronics, sometimes the outlet is a dud after a while, even in newer homes, that is a possible problem, or you're getting the wrong charger, sometimes there isn't enough volts, or too many and can ruin yur battery, if you would like the perfect charger, google it, and figure out the perfect charger for your phone.
Sep 17, 2009 | LG RUMOR Cellular Phone
Charging problem
try to change the battery.........
May 30, 2009 | LG Secret ? KF750 Cellular Phone
Phone will not turn on unless it's plugged in
Try cleaning contacts on the battery. If this does not correct problem replace battery.
Mar 22, 2009 | LG enV VX9900 Cellular Phone
Won't Charge or Turn on
First try drying out your phone for a day or two with lots of dry moving air gently blowing past and around it, the phone must be unplugged and battery removed during this process, then once everything has been dried try charging the battery in another phone just like it, if it charges and see it it will power the phone, if the battery works put t back into your phone and try to turn it on. If it doesn't work in your phone but it does in another then its the phone, if the phone works with another battery its the battery but dry them both totally first, even a few tiny specs of moisture can screw up your phone when power is running through it, so be careful. Cheers!
Mar 02, 2008 | Motorola Mobility RAZR V3
Cell Phones Logo
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
